BLControl app screenshots
Here is a screenshot of the locations page.
This page allows you to add locations to the plugin that will allow you to execute an action in HS3 once you are at the location (or near the location within the range defined for each location in feet).
The person icon on the map indicates your current location. The red arrow indicates all the locations that you have added to the plugin. When the map loads it loads all locations you have added. If you select the icon on the action bar on the right it will give you a list of all of your locations, If you pick one the map will change to that location. If you tap the red arrow then it will show you the name of the location.
If you tap on Add Location it will popup a dialog showing your current location and ask you for a name for the new location. Once you click Add it will add the location to the pluginLast edited by Blade; November 10, 2013, 06:55 PM.
