After updating to the newest version (3.0.6265.19154) on the updater the plugin is giving the following error:
System.IO.Ports.SerialPort.get_BytesToRead() at HSPI_ULTRAECM3.BrultechDevice.DataReceived(Object sender, SerialDataReceivedEventArgs e)
Followed by the repeating error:Warning Watchdog Timer indicates No response response from the Brultech device 'COM:5' for 54918 seconds.. Attempting to reconnect ...
I have not changed any settings from the previous version.
The setup(ECM1240) is for serial communications, the com port status is working OK and shows connected in startup log.
