Server on NSA320 NAS
i connect fine...
It sees the library stats (total artists/genres/etc)
It sees the player o.k. (running local on
hs3 machine squeezelite)
But it keeps disconnecting.. (then reconnecting,... )
The error in the log is:
Dec-14 8:10:51 AM SqueezeBox Warning Communication error upon sockDataArrival Receive: An existing connection was forcibly closed by the remote host
Dec-14 8:10:51 AM SqueezeBox Error An unexpected error occured in the QueryServer() function/subroutine: [System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.Socket.Receive(Byte[] buffer, Int32 offset, Int32 size, SocketFlags socketFlags) at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.IO.StreamReader.ReadBuffer() at System.IO.StreamReader.ReadLine() at HSPI_SqueezeBox.hs_socket_io.ReadString() at HSPI_SqueezeBox.HSPI.QueryServer(String query)]
Things i have tried:
Make sure firewall is off on HS3 machine
Changed CLI port (in plugin and on LMS server) from 9595 to 9095
Rebooted nas several times.. rebooted hS3 machine several times.
HS3 Pro Edition 3.0.0.297 (Windows)
SqueezeBox Plugin 3.1.4.9
LMS Server info
Logitech Media Server Version: 7.7.1 - r33735 @ Mon Nov 28 16:49:58 MST 2011
Hostname: NSA320
Server IP Address: 192.168.1.123
Server HTTP Port Number: 9000
Operating system: Linux - EN - utf8
Platform Architecture: armv5tel-linux
Perl Version: 5.10.0 - armv5tel-linux
Database Version: DBD::SQLite 1.34_01 (sqlite 3.7.7.1)
Total Players Recognized: 1
I can music without issue if i go to the 192.168.1.123:9000 screen.
Any ideas of where i should look for issue?
