Originally posted by mnsandler
View Post
Date/Time Pri Type/Error Message/Source
Feb-14 8:16:15 AM Plug-In Finished initializing plug-in Insteon
Feb-14 8:16:15 AM Insteon Generic Event Raised: Ready for Registration
Feb-14 8:16:15 AM Insteon External Device Registration complete.
Feb-14 8:16:15 AM Insteon Note: External device support script does not exist in the HomeSeer scripts directory.
Feb-14 8:16:15 AM Insteon Exit InitIO
Feb-14 8:16:15 AM Insteon Exit InitPlugin
Feb-14 8:16:15 AM Insteon Waiting to initialize External Devices...
Feb-14 8:16:15 AM Insteon I/O(Insteon Protocol) Interface Initialized.
Feb-14 8:16:15 AM Insteon Exit CreateDevices
Feb-14 8:16:15 AM Insteon Scheduled polling resumed.
Feb-14 8:16:15 AM Insteon 0 matching HS device records were found and updated for the Insteon group database.
Feb-14 8:16:15 AM Insteon 1 Matching HS device records were found and updated for the Insteon device database.
Feb-14 8:16:15 AM Insteon Reloading 1 Insteon device information tables...
Feb-14 8:16:15 AM Insteon Scheduled polling temporarily stopped.
Feb-14 8:16:15 AM Insteon In CreateDevices
Feb-14 8:16:15 AM Insteon Scheduled polling enabled.
Feb-14 8:16:15 AM Insteon In TransmitMessageThread
Feb-14 8:16:15 AM Insteon I/O (Insteon Protocol) Interface Initializing...
Feb-14 8:16:15 AM Insteon Insteon hardware interface initialized.
Feb-14 8:16:15 AM Insteon ..Got RF PLM Response 02 6B 48 06
Feb-14 8:16:14 AM Insteon ..Retry #1 required. Pausing 250ms for RF PLM to clear...
Feb-14 8:16:14 AM Insteon ..Got NAK from the RF PLM for command
Feb-14 8:16:14 AM Insteon Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:16:14 AM Insteon RF PLM contacted on COM1 with an Insteon address of 44.32.1C and firmware version 9E
Feb-14 8:16:14 AM Insteon ..Got Interface Response 02 60 44 32 1C 03 11 9E 06
Feb-14 8:16:14 AM Insteon Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:16:13 AM Insteon ..Retry #2 required. Pausing 300ms for Interface to clear...
Feb-14 8:16:13 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:16:13 AM Insteon ..Retry #1 required. Pausing 250ms for Interface to clear...
Feb-14 8:16:12 AM Insteon Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:16:12 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:16:12 AM Insteon ..Retry #2 required. Pausing 300ms for Interface to clear...
Feb-14 8:16:11 AM Insteon ..Retry #1 required. Pausing 250ms for Interface to clear...
Feb-14 8:16:11 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:16:11 AM Insteon Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:16:11 AM Insteon ..Got Interface Response 02 60 44 32 1C 03 11 9E 06
Feb-14 8:16:10 AM Insteon ..Retry #1 required. Pausing 250ms for Interface to clear...
Feb-14 8:16:10 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:16:10 AM Insteon Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:16:10 AM Insteon In PLMBuffer_ProcessBufferThread
Feb-14 8:16:10 AM Insteon Initializing Interface...
Feb-14 8:16:10 AM Insteon Initializing Insteon hardware interface...
Feb-14 8:16:10 AM Insteon In ProcessRawReceiveThread
Feb-14 8:16:10 AM Insteon Global initialization of plug-in required, starting up.
Feb-14 8:16:10 AM Insteon Enter InitPlugin
Feb-14 8:16:10 AM Insteon Enter InitIO
Feb-14 8:16:10 AM Insteon RegisterCallback Completed
Feb-14 8:16:10 AM Insteon Insteon Support library (Insteon.dll) version: 1.0.6.0
Feb-14 8:16:10 AM Insteon Plugin HSPI_Insteon.exe version: 3.0.6.0
Feb-14 8:16:10 AM Insteon Host System: 192.168.1.233 (HomeTrollerS) 3.0.0.368
Feb-14 8:16:09 AM Info Plugin Insteon has connected. IP:127.0.0.1:50025
Feb-14 8:16:00 AM Info Plugin Insteon with instance: has disconnected
Feb-14 8:16:00 AM Insteon Exit ShutdownIO
Feb-14 8:16:00 AM Insteon I/O plug-in shutdown requested.
Feb-14 8:16:00 AM Insteon Enter ShutdownIO
Feb-14 8:16:00 AM Plug-In Shutting down Plug-In: Insteon
Feb-14 8:15:06 AM Warning Error handling UPNP request: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host.
Feb-14 8:14:51 AM TTS Speak ():Welcome to Home-Seer
Feb-14 8:14:51 AM Speaker Speaker host added, Name: HomeTrollerS Instance: Default IP address: 127.0.0.1
Feb-14 8:14:49 AM Web Server Web Server authorized local login successful from: 192.168.1.233 User: default
Feb-14 8:14:47 AM Info System connected to MyHS Service successfully with license ID 78461.
Feb-14 8:14:47 AM Info System connected to MyHS Service, waiting for acknowledge...
Feb-14 8:14:46 AM Startup Start up complete.
Feb-14 8:14:46 AM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
Feb-14 8:14:46 AM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
Feb-14 8:14:46 AM Startup HSSentry is disabled in Setup, sentry will not be started.
Feb-14 8:14:46 AM Startup Starting Event Scheduler...
Feb-14 8:14:45 AM Startup Running the startup script Startup.vb
Feb-14 8:14:45 AM Info Starting speaker client...
Feb-14 8:14:45 AM Startup Starting Find service...
Feb-14 8:14:45 AM Startup Updater services starting...
Feb-14 8:14:45 AM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
Feb-14 8:14:45 AM Speech Listening for remote speaker connections on port 10401
Feb-14 8:14:45 AM Startup Initializing Speaker Client Interface
Feb-14 8:14:45 AM Startup Start automation engine...
Feb-14 8:14:43 AM Startup Creating ASP.NET application host...
Feb-14 8:14:43 AM Web Server UPNP Discovery started
Feb-14 8:14:43 AM Web Server Web Server started on port 80
Feb-14 8:14:43 AM Web Server Local IP address (subnet) is: 192.168.1.233 (255.255.255.0)
Feb-14 8:14:42 AM Startup HStouch server started, waiting for clients to connect.
Feb-14 8:14:42 AM HSTouch Server Server started on port 10200
Feb-14 8:14:42 AM Plug-In Finished initializing plug-in Insteon
Feb-14 8:14:42 AM Insteon Could not set the Interface configuration. Init failed.
Feb-14 8:14:42 AM Insteon Exit InitIO
Feb-14 8:14:42 AM Insteon Insteon hardware interface initialization failed.
Feb-14 8:14:42 AM Insteon ..Got NAK from the RF PLM for command
Feb-14 8:14:42 AM Insteon ..Retry #2 required. Pausing 300ms for RF PLM to clear...
Feb-14 8:14:41 AM Insteon ..Retry #1 required. Pausing 250ms for RF PLM to clear...
Feb-14 8:14:41 AM Insteon ..Got NAK from the RF PLM for command
Feb-14 8:14:41 AM Insteon Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:14:41 AM Insteon RF PLM contacted on COM1 with an Insteon address of 44.32.1C and firmware version 9E
Feb-14 8:14:41 AM Insteon ..Got Interface Response 02 60 44 32 1C 03 11 9E 06
Feb-14 8:14:41 AM Insteon ..Retry #1 required. Pausing 250ms for Interface to clear...
Feb-14 8:14:41 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:14:40 AM Insteon Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:14:40 AM Insteon ..Got Interface Response 02 60 44 32 1C 03 11 9E 06
Feb-14 8:14:40 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:14:39 AM Insteon ..Retry #2 required. Pausing 300ms for Interface to clear...
Feb-14 8:14:39 AM Insteon ..Got NAK from the Interface for command
Feb-14 8:14:39 AM Insteon ..Retry #1 required. Pausing 250ms for Interface to clear...
Feb-14 8:14:38 AM Insteon Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
Feb-14 8:14:38 AM Insteon ..Got Interface Response 02 60 44 32 1C 03 11 9E 06
Feb-14 8:14:38 AM Insteon In PLMBuffer_ProcessBufferThread
Feb-14 8:14:37 AM Insteon Initializing Interface...
Feb-14 8:14:37 AM Insteon In ProcessRawReceiveThread
Feb-14 8:14:37 AM Insteon Initializing Insteon hardware interface...
Feb-14 8:14:37 AM Insteon Global initialization of plug-in required, starting up.
Feb-14 8:14:37 AM Insteon Enter InitPlugin
Feb-14 8:14:37 AM Insteon Enter InitIO
Feb-14 8:14:37 AM Insteon RegisterCallback Completed
Feb-14 8:14:37 AM Insteon Insteon Support library (Insteon.dll) version: 1.0.6.0
Feb-14 8:14:37 AM Insteon Plugin HSPI_Insteon.exe version: 3.0.6.0
Feb-14 8:14:37 AM Insteon Host System: () 3.0.0.368
Feb-14 8:14:37 AM Info Plugin Insteon has connected. IP:127.0.0.1:49798
Feb-14 8:14:37 AM Startup Initializing Plug-Ins
Feb-14 8:14:37 AM Plug-In Found plug-in: Z-Wave, version: 3.0.1.190
Feb-14 8:14:36 AM Plug-In Found plug-in: Insteon, version: 3.0.6.0
Feb-14 8:14:35 AM Startup Checking for available plug-ins
Feb-14 8:14:35 AM Info Remote plug-in API interface started on port 10400
Feb-14 8:14:35 AM Startup This version of HomeSeer is registered as a HS3PRO version.
Feb-14 8:14:35 AM Startup Creating Speaker Client Interface Object...
Feb-14 8:14:35 AM Startup HomeSeer version is: 3.0.0.368
Feb-14 8:14:34 AM Load Config Loading TIMERS...
Feb-14 8:14:34 AM Load Config Loading COUNTERS...
Feb-14 8:14:34 AM Load Config 3 total events loaded.
Feb-14 8:14:34 AM Load Config Loading Events...
Feb-14 8:14:34 AM Load Config Loading Event Groups...
Feb-14 8:14:34 AM Load Config 23 total devices loaded.
Feb-14 8:14:34 AM Database Loading Devices...
Feb-14 8:14:34 AM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\HomeSeerData.hsd
Feb-14 8:14:34 AM Startup Loading configuration file ...
Feb-14 8:14:34 AM Startup Database SAVE process started.
Feb-14 8:14:34 AM Startup Local voice recognition class started.
Feb-14 8:14:34 AM Startup HSPhone external interface class started.
Feb-14 8:14:34 AM Startup Plug-In Interface class started.
Feb-14 8:14:34 AM Startup E-Mail RECEIVE class started.
Feb-14 8:14:34 AM Startup E-Mail SEND class started.
Feb-14 8:14:34 AM Startup Web server class started.
Feb-14 8:14:34 AM Startup Application interface class started.
Feb-14 8:14:34 AM Startup COM port classes started.
Feb-14 8:14:34 AM Startup Creating Class Objects...
Feb-14 8:14:33 AM Startup
Feb-14 8:14:33 AM Startup ************************************************************ ********************
Feb-14 8:14:33 AM Startup HomeSeer version 3.0.0.368 Edition: HS3 Pro Starting Now
Feb-14 8:14:33 AM Startup Settings Loaded.
