V6 of mcsTemperature replaces V5. V6 will be the supported version going forward. Prior discussion thread is at http://board.homeseer.com/showthread.php?t=116165. This is an incremental change with the primary difference giving the user the abilty to select the axis to be used on an individual sensor basis.
PR 643 6.0.2 Relay output changes are not logged as discretes to database
PR 644 6.0.4 CSV wind direction angle not saved to Device Value correctly
PR 645 6.0.7 Remove exclusion logic for zero data values
PR 646 6.0.6 Discrete axis-specific labels missing and right opaque
PR 647 6.0.6 Discrete Minutes-on not quantized correctly
PR 648 6.1.1 Allow Calculations in "Calc/Bias" column
PR 649 6.1.1 Allow user selection to include/exclude zero data values
PR 650 6.1.2 Transition from group to graph looses settings
PR 651 6.1.3 DS2408 does not function correctly as relay
PR 652 6.1.3 Skew on Group Edit page columns starting at DC
----- above in updater -----
PR 653 6.1.4 Draw checkbox not honored on initial page draw
PR 654 6.1.5 Debug code remains in 6.1.4
PR 654 6.1.6 Improve tolerance for xml content in forecast download
PR 655 6.1.11 DS2408 Relay outputs are inconsistent
PR 656 6.1.13 Substitute decimal for expressions resolving to DeviceString contents
PR 657 6.1.14 Allow use of & house code devices in expressions
PR 658 6.1.25 Add conditional for weatherplug
PR 659 6.1.26 Round rainfall counts after calibration rather than before
PR 660 6.2.14 Add Temp08 1WIO support (Relay, Input, LED)
PR661 6.2.21 Dont send 1WIO commands when Temp08 reporting
PR662 6.2.22 Exclude group sort key prevents use of Group page
PR663 6.2.24 Exclude house code "-" as possible Cal bias device
PR664 6.2.25 Limit RLY and LED address to two digits
PR665 6.3.4 Support Current Condition Icon paths from WeatherXML
PR666 6.4.0 Dont modify device properties for Zwave devices
PR667 6.4.3 Substitute decimal for expressions resolving to DeviceString contents
latest hspi_mcsTemperature.exe http://mcsSprinklers.com/mcsTemperature643.zip
