  #41
Old January 27th, 2014, 02:14 AM
travisdh travisdh is offline
Super Seer
Also, not sure if it just my system but whilst LMS, and LMS:* works fine, if I don't specify a LMS in the speaker client (to speak TTS) then in my case it does not appear to send the TTS message to the Squeezeplayers
I should clarify, this is when using the direct scripting command
&hs.speak("This is a simple tts message")
  #42
Old January 27th, 2014, 08:16 AM
pcp pcp is offline
Super Seer
SqueezeBox plugin V3.0.0 Beta for HS3
Originally Posted by travisdh View Post
Just wondering if it would be possible in a future version to add an "All Players" field in the player selection (e.g. rather than an individual player) for player / playlist control etc.
It would be nice to be able to set the speak volume of all players to x, and to set all players on start / stop etc rather than having to issue multiple event actions.
The new version seems to be working quite well, I have not yet had the chance to do full testing (e.g. with HSTouch yet) but once that is up and going I should be able to provide some feedback.
Thanks. I will have a look at possibly adding an all player option. Regarding HSTouch integration, HSTouch does not yet support the new media APIs and is work in progress.
  #43
Old January 27th, 2014, 08:18 AM
pcp pcp is offline
Super Seer
Hmmm... I need to double check this but was one of my testing use cases. Is the speaker client plugin configuration name empty?
  #44
Old January 27th, 2014, 06:39 PM
Super Seer
So in the settings page (of HS itself) I have no default speaker client set (e.g. left blank), and in the Squeezebox plugin itself I have the speaker client set to LMS.
Interestingly if I call a speak message through an event (with no speaker client specified in advanced settings) it does do the TTS to all clients, however if I use hs.speak("This is a test") as is then it does not speak to all clients (including the LMS).
  #45
Old January 27th, 2014, 09:28 PM
pcp pcp is offline
Super Seer
Interesting and will need to play with this as well. If you check "Speak Proxy Debugging" in the SqueezeBox plug-in and speak some text with the different form/arguments, does the the plug-in speak proxy generate log messages for all combinations of speaker clients. As said I will need to play with this as well but might only be later in the week.
  #46
Old January 28th, 2014, 11:40 PM
Super Seer
I am still yet to debug the speaker proxy issue (but will do that over the weekend). That said I have come across a few more issues (might just be my system).
My log is filled with these:
Jan-29 2:44:03 PM Warning Cannot access remote plugin SqueezeBox
Jan-29 2:43:33 PM Warning Cannot access remote plugin SqueezeBox
Jan-29 2:43:02 PM Warning Cannot access remote plugin SqueezeBox
Jan-29 2:42:32 PM Warning Cannot access remote plugin SqueezeBox
and the Interfaces tab reports:
SqueezeBox
Player_000c29b3b0ff
EnabledN/A3.1.0.3N/AN/ACRITICAL: Plugin has disconnected.
SqueezeBox
Player_004518fd53c9
Jan-29 2:48:16 PM Error Getting web page from plugin page squeezebox_status:Object reference not set to an instance of an object.
Jan-29 2:48:05 PM Warning Cannot access remote plugin SqueezeBox
Jan-29 2:48:05 PM Warning Plugin SqueezeBox is not responding but it is still running, not restarting yet.
So the first question is how can I fix this issue, I know some of the clients do connect and disconnect a bit (which i don't mind) but I would be keen to stop the log being bombarded as I am getting hundreds of these messages .
There is also no firewall on etc, and the plugin does seem to be able to connect to the LMS server.
  #47
Old January 29th, 2014, 02:52 AM
w.vuyk's Avatar
w.vuyk w.vuyk is offline
I see the same issue now and then too. Don't know where it comes from, but seems to start after updates of other plugins etc. For me switching the plugin off and on solves the issue?
I think HST has to review the update process for plugins as it looks it is not 100% proof yet.
Wim
-- Wim
Plugins:RFXCOM, HSTouch Server, Squeezebox, BLGData, Restart, Jon00's Perfmon and Network monitor, WeatherXML, BLBackup, TenScripting, BC4, Pushover, PHLocation, JowiHue, Zwave, Sonos
650 devices ---- 336 events ----- 40 scripts
  #48
Old January 29th, 2014, 06:23 PM
pcp pcp is offline
Super Seer
For the installation issues you mention, check the Bugzilla #1448 I created for I believe similar issues. If you have additional details/stack traces/screenshots it might be helpful to HomeSeer.
  #49
Old February 1st, 2014, 12:42 AM
pcp pcp is offline
Super Seer
EDITS: Removing initial post.... Actually was able to reproduce it using some scripting command. I will fix it next version. The issue is that the scripting API specifies all players if non provided differently than in when no client is specified in an event.
  #50
Old February 10th, 2014, 03:45 PM
w.vuyk's Avatar
Philippe,
Installed 3.1.0.3 a week ago. Everything worked just find, but I do not see device grouping being active. Or did I have to remove all devices again?
Also, I see an update to 3.1.05 in the list. What has changed?
Wim
  #51
Old February 10th, 2014, 07:19 PM
pcp pcp is offline
Super Seer
Originally Posted by w.vuyk View Post
Philippe,
Wim
Hello Wim,
The latest version 3.1.0.5 (3.1.0.4 was never in the updater) was uploaded this morning. I updated the first dialog of this thread with the changes a few minutes.
To get device grouping to work you will need to delete and re-create the devices. Once devices are created, I try not to touch them (so that you can change names, different icons if really desired, etc) besides changing the value (and string in very few cases).
  #52
Old February 10th, 2014, 07:27 PM
pcp pcp is offline
Super Seer
This should be resolved with 3.1.0.5 uploaded earlier today. Give it a try.
  #53
Old February 10th, 2014, 07:46 PM
Super Seer
Is anyone else having trouble getting the update installed, when I tried to install it my homeseer system errored as per the below message, then crashed:
PHP Code:
11/02/2014 10:54:46 AM
HomeSeer version3.0.0.55
Source
Scheduler
Target
Void InitSingleIOPlugin(System.StringSystem.String)
Stack trace
at Scheduler.clsHSPI.InitSingleIOPlugin(String PlugNameString InstanceName)
at A.cfa0c175bbbe8b3f641749e50d5de5c9c.cf62203fbe33ebe16b6cb35a44cafaba4()
at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContextContextCallback callbackObject stateBoolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContextContextCallback callbackObject stateBoolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContextContextCallback callbackObject state)
at System.Threading.ThreadHelper.ThreadStart()
Please specify what you were doing at the time of this error
  #54
Old February 11th, 2014, 08:31 PM
pcp pcp is offline
Super Seer
PHP Code:
Source
Scheduler
Target
Stack trace
I have not seen this problem or encountered it when I tested the package I sent for the updater. Will try to see if I can reproduce it plus check the package that was added to the updater. UPDATE: I just tried it from the updater and worked fine. I had to disable the plugin before the update (see earlier dialog about updates and related bugzilla). Check the hspi_squeezebox.exe in the HS3 folder to see if it is really V3.1.0.5. if not try to delete it and update again. The plugin also requires HS3 .55 (or later), but it should tell you when you install it.
  #55
Old February 11th, 2014, 10:52 PM
Super Seer
I didn't have any luck, had to delete the exe file and then installed the plugin and it worked fine after that.
  #56
Old February 17th, 2014, 11:56 AM
w.vuyk's Avatar
Philippe,
In the plugins page you see every device that was in the network with squeezebox functionality. In my family we have several Iphones with Ipeng in use. Every now and then I give them access to my network and they can then search the library and choose the music they like to play.
At the end an extra player is visible in the plugins window. I expected I could use the red cross next to the device to remove it from the list.
But instead I am seeing a page with html codes and the device is still there if I return to the plugin page.
Is there a way to clean the unused players?
Wim
  #57
Old February 18th, 2014, 09:02 AM
pcp pcp is offline
Super Seer
The plugin is setup as a HS3 multiple interface single instance, and for each player you see an instance in the plugin page as a child of the primary process. There is no way currently to disable specific players. Would you want specific players to be completely ignored from the plugin (i.e no HSTouch - when supported - , triggers when alarm goes off, etc...)? The red X is something coming from HS3 and not sure if I can disable/hide it or use it. I have to look into it.
  #58
Old February 18th, 2014, 06:15 PM
w.vuyk's Avatar
Philippe,
I would like to be abletoremove those devices once in a while. Those devices could be 'old' squeezeboxes I am not using anymore or indeed devices from visitors who have been playing around in the house. I do not need to to see them once they are gone. Especially a replaced phone should not linger there as it replaced every year or so. If I am using the system for a few years more, those would really polute the view?
Wim
  #59
Old February 25th, 2014, 05:16 AM
Jingoro Jingoro is offline
I can't seem to get TTS to work with my Squeezebox Radios.
Here's my HS3 Configuration :
HS3 Speaker Clients setting : default (network port 10401, default cients blank)
SqueezeBos HS3 Plugin Speak Proxy Settings :
Enable Speak Proxy and Primary Speak Proxy : Both checked
Speak Proxy Mode : Normal
Speaker Client : LMS
TTS as MP3 : checked
Device Management :
Player 1 Power : Powered On
Player 1 Status : Stopped
Player 1 Speech Volume : 75%
Speak Proxy Count : 0
I try to run this script command :
&hs.speak("Hello world where oh where oh where are you why don't you speak?", False, "LMS:Player 1")
And this is what I see in the logs (NOTE : player name removed for privacy):
Feb-25 1:22:56 AM         SqueezeBox Debug    Exiting speechTimer_Elapsed
 Feb-25 1:22:56 AM         SqueezeBox Debug    Exiting SpeakOutNextInQueue. New status: stopped. PendingSpeechTrackEnd: False
 Feb-25 1:22:56 AM         SqueezeBox Debug    StopSpeechTimer.
 Feb-25 1:22:56 AM         SqueezeBox (Player_) Debug    Kitchen - SpeakerClientDisable
 Feb-25 1:22:56 AM         SqueezeBox Debug    Entering DisableSpeaking
 Feb-25 1:22:56 AM         SqueezeBox Debug    SpeakOutNextInQueue - Stopped.
 Feb-25 1:22:56 AM         SqueezeBox Debug    Entering SpeakOutNextInQueue. Status: stopping. PendingSpeechTrackEnd: False
 Feb-25 1:22:56 AM         SqueezeBox Debug    Entering speechTimer_Elapsed
 Feb-25 1:22:55 AM         SqueezeBox Debug    Exiting speechTimer_Elapsed
 Feb-25 1:22:55 AM         SqueezeBox Debug    Exiting SpeakOutNextInQueue. New status: stopping. PendingSpeechTrackEnd: False
 Feb-25 1:22:55 AM         SqueezeBox Debug    StartSpeechTimer. Duration: 0:1:0 (1000)
 Feb-25 1:22:55 AM         SqueezeBox Debug    SpeakOutNextInQueue - Stopping.
 Feb-25 1:22:55 AM         SqueezeBox Debug    SpeakOutNextInQueue - Deleting TTS URLs.
 Feb-25 1:22:55 AM         SqueezeBox (Player_) Debug    Kitchen - SpeakerClientSpeakRemoveURL. Play index: 0
 Feb-25 1:22:55 AM         SqueezeBox Debug    Entering SpeakOutNextInQueue. Status: started. PendingSpeechTrackEnd: False
 Feb-25 1:22:54 AM         SqueezeBox Debug    Entering speechTimer_Elapsed
 Feb-25 1:22:53 AM         SqueezeBox Debug    StartSpeechTimer. Duration: 0:1:0 (1000)
 Feb-25 1:22:53 AM         SqueezeBox Debug    StartSpeechTimerForTTSTrackEnd. From: Kitchen. SpeakerSpeechEndPending: False Extra duration: 0:1:0 (1000)
 Feb-25 1:22:53 AM         SqueezeBox (Player_) Debug    Kitchen - SpeakerClientSpeakCheckIfDone. PendingSpeechTrackEnd: True
 Feb-25 1:22:48 AM         SqueezeBox Debug    Exiting speechTimer_Elapsed
 Feb-25 1:22:48 AM         SqueezeBox Debug    Exiting SpeakOutNextInQueue. New status: started. PendingSpeechTrackEnd: True
 Feb-25 1:22:48 AM         SqueezeBox Debug    StartSpeechTimer. Duration: 1:1:0 (61000)
 Feb-25 1:22:48 AM         SqueezeBox Debug    Entering SpeakProxyUpdateDevices
 Feb-25 1:22:48 AM         TTS    Speak: (LMS:Player 1):Hello world where oh where oh where are you why don't you speak?
 Feb-25 1:22:48 AM         SqueezeBox Debug    SpeakOutNextInQueue - Started Speech:  playlist index 0
 Feb-25 1:22:48 AM         SqueezeBox (Player_) Debug    Kitchen - SpeakerClientSpeakStart. Play index: 0
 Feb-25 1:22:48 AM         SqueezeBox Debug    SpeakToFile(). Call Duration=00:00:00.7499700
 Feb-25 1:22:48 AM         SqueezeBox Debug    SpeakToFile mp3 start. cmd: E:\HomeSeer3\lame.exe args: --silent "E:\HomeSeer3\html\SqueezeBox\SpeakIn_6.wav" "E:\HomeSeer3\html\SqueezeBox\SpeakIn_6.mp3"
 Feb-25 1:22:47 AM         SqueezeBox Debug    SpeakToFile. WAV: E:\HomeSeer3\html\SqueezeBox\SpeakIn_6.wav MP3: E:\HomeSeer3\html\SqueezeBox\SpeakIn_6.mp3 Text: Hello world where oh where oh where are you why don't you speak? IsFile: False FileExists: False
 Feb-25 1:22:47 AM         SqueezeBox Debug    SpeakOutNextInQueue - Added URLs:  playlist add http://192.168.0.100:81/SqueezeBox/SpeakIn_6.mp3
 Feb-25 1:22:47 AM         SqueezeBox (Player_) Debug    Kitchen - SpeakerClientSpeakAddURL. URL: http://192.168.0.100:81/SqueezeBox/SpeakIn_6.mp3 Play index: 0
 Feb-25 1:22:47 AM         SqueezeBox Debug    SpeakOutNextInQueue - SpeakProxy. Remaining Queue Length: 0 SpeakerClient: LMS Host: LMS:Player 1 Text: Hello world where oh where oh where are you why don't you speak?
 Feb-25 1:22:47 AM         SqueezeBox Debug    Entering SpeakOutNextInQueue. Status: starting. PendingSpeechTrackEnd: False
 Feb-25 1:22:47 AM         SqueezeBox Debug    Entering speechTimer_Elapsed
 Feb-25 1:22:46 AM         SqueezeBox Debug    Exiting speechTimer_Elapsed
 Feb-25 1:22:46 AM         SqueezeBox Debug    Exiting SpeakOutNextInQueue. New status: starting. PendingSpeechTrackEnd: False
 Feb-25 1:22:46 AM         SqueezeBox Debug    StartSpeechTimer. Duration: 0:1:0 (1000)
 Feb-25 1:22:46 AM         SqueezeBox (Player_) Debug    Kitchen - SpeakerClientEnable. speakVolume: 75
 Feb-25 1:22:46 AM         SqueezeBox Debug    Entering EnableSpeaking, Client: LMS:Player 1
 Feb-25 1:22:46 AM         SqueezeBox Debug    SpeakOutNextInQueue - Starting. Queue Length: 1 SpeechAudioEnabled: False SpeakerClient: LMS Speak Host: LMS:Player 1
 Feb-25 1:22:46 AM         SqueezeBox Debug    Entering SpeakOutNextInQueue. Status: stopped. PendingSpeechTrackEnd: False
 Feb-25 1:22:46 AM         SqueezeBox Debug    Entering speechTimer_Elapsed
 Feb-25 1:22:46 AM         SqueezeBox Debug    Exiting SpeakIn. Queue Length: 1
 Feb-25 1:22:46 AM         SqueezeBox Debug    StartSpeechTimer. Duration: 0:0:4 (4)
 Feb-25 1:22:46 AM         SqueezeBox Debug    Entering SpeakProxyUpdateDevices
 Feb-25 1:22:46 AM         SqueezeBox Debug    Entering SpeakIn host: LMS:Player 1, device: 100, Text: Hello world where oh where oh where are you why don't you speak? , Enabled: True
 Feb-25 1:22:46 AM         System    Control Panel Immediate Script: &hs.speak("Hello world where oh where oh where are you why don't you speak?", False, "LMS:Player 1")
What am I doing wrong?
  #60
Old February 25th, 2014, 08:05 AM
pcp pcp is offline
Super Seer
Is it specific to the radio player?
HTML code is On
