  #161
Old June 9th, 2017, 08:15 AM
pcp pcp is offline
Super Seer
Originally Posted by skarragallagher View Post
Thank you for getting this done for the events.
I do still see the players in the device control section of the LMS devices
The updated version is in the updater. Give it a try
  #162
Old June 9th, 2017, 12:46 PM
skarragallagher skarragallagher is offline
Thank you I will try
  #163
Old June 9th, 2017, 02:25 PM
Looks good, had some initial start up problem but I think it is more a homeseer issue than your plugin. After I reset the plugin and gave it some time it looks like it is now accomplishing the filtering of devices
Thank you for you attention to this matter, I really appreciate it.
  #164
Old June 21st, 2017, 03:14 AM
lunkan lunkan is offline
In the past I've used the plug-in but now I'm on Linux (Rpi). Is there a chance that the plug-in will be compatible with Linux in the future?
  #165
Old June 24th, 2017, 08:56 AM
pcp pcp is offline
Super Seer
No plans for this a this point.
  #166
Old August 9th, 2017, 08:29 AM
edwin2008 edwin2008 is offline
Will the plugin work if homeseer is running on windows and lms on raspberry pi? Sorry if asked before but confused by previous post.
  #167
Old August 9th, 2017, 09:45 AM
sparkman's Avatar
sparkman sparkman is online now
Yes. LMS can be on a different server which can be linux based. That's how I use it myself.
Sent from my Phone using Tapatalk
  #168
Old August 9th, 2017, 11:54 AM
But squeezebox plugin does work with that config (lms on raspberry pi and homeseer on windows box)?
  #169
Old August 9th, 2017, 12:11 PM
sparkman's Avatar
Yes
  #170
Old August 9th, 2017, 12:54 PM
Great!
  #171
Old August 10th, 2017, 07:16 AM
pcp pcp is offline
Super Seer
As sparman said, LMS can run an different server. Over the years I used different configurations with LMS on Windows, NAS, etc and HS2 or HS3 on Windows (XP or Windows 7). These days (on my prod environment) I have a fast I7 server running both LMS, HS3 and other server apps.
If you run them oon different servers, the one thing too possibly configure / check are firewall issues blocking the TPC/IP ports used by the plugin too communicate with LMS
  #172
Old August 10th, 2017, 07:41 AM
IanIreland's Avatar
IanIreland IanIreland is offline
You can also run the LMS on a Pi should the mood take you!
  #173
Old February 20th, 2018, 06:03 PM
pcp pcp is offline
Super Seer
There is a new version in the Beta section of the Updater with support for Linux.
  #174
Old February 23rd, 2018, 04:26 PM
larhedse larhedse is offline
I just installed this plugin - config done - in the plugin for squeezebox I see both players (I have a Radio and a Touch) - however when I press "HOME" to see all devices, I only see squeezebox "LMS" - no device for my Radio, nor any device for my Touch - am I missing something here?
Also, when first started, the SqueezeBox "LMS" device, Selected Player, only showed "None", "Touch" and then a very smal blank button "". Disable / Enable the SqueezeBox Radio fixed that.
But as I wrote above, I have no devices.
Running Ubuntu 16.04LTS - so it is the BETA Linux version I have.
  #175
Old February 24th, 2018, 08:10 AM
Pete's Avatar
Pete Pete is offline
Here too running Homeseer 3 Pro on Ubuntu 16.04 64 bit. On drop down for one player see 35 devices which fill up the screen. IE: if you hit all devices for squeezebox you should see 70 devices for your two players. Note too that it gets your stuff from your Squeezebox server. I am not using any sort of authentication here for the Squeezebox server. I am guessing your squeezebox server sees the two players fine.
Just updated server this morning to new version.
My base XPe touchscreens (15) multitask - running HS3 touch, Squeezebox player or Leviton security touch on either Ubuntu 16.04 or Windows XPe. Numbers over 15 (16-20) are running ubuntu.
I am using them along with tiny KODI players next to my Russound zoned amps. IE: you can create an HSTouch screen which has Russound controls and is a remote squeezeplayer controller.
Automator
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers | Openpeak Intel Atom SoC tabletop touchscreens (15 HS tabletop tablets)
HS3 Pro & Lite
Edition Beta 3.0.0.435 | HS3 Wintel Touch | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
  #176
Old February 24th, 2018, 01:57 PM
Sorry to say: No I do NOT have ANY devices (except LMS) - so clearly I am missing something...
I have attached a picture that shows the only device I have (after pressing Show All):
Also includes a picture that shows that the plugin HAS discovered the two players I do have (and it is correct):
It just failed to create the devices in question?
  #177
Old February 24th, 2018, 02:03 PM
I decided, just for fun, to click "HS3 Dev." - that made a difference, now I got the two players.... And if I remove that option, they are missing again. I seem to clearly miss some sort of knowledge....
  #178
Old February 24th, 2018, 04:41 PM
pcp pcp is offline
Super Seer
This is as expected. When checked it creates HS3 devices for that player otherwise and when unchecked it removes any existing HS3 devices.
  #179
Old March 9th, 2018, 10:29 AM
ServiceXp's Avatar
ServiceXp ServiceXp is offline
Can this plugin use Chromecast Audio's as a destination (Cast to Chromecast Audio)?
RJ_Make On YouTube
  #180
Old March 9th, 2018, 10:54 AM
Pete's Avatar
Relating to LMS there appears to be a Castbridge (integrate Chromecast players with LMS (squeeze2cast) ) that was announced in 2015.
See here:
Announce: CastBridge = integrate Chromecast players with LMS (squeeze2cast)
HTML code is On
