Old March 1st, 2017, 08:24 AM
ArbWare's Avatar
ArbWare ArbWare is offline
Something not quite working as expected
Two events... one works .. one doesn't
Both load playlist
First pic below
If i have genre = Rock.. it works (Puts all albums from artist in playlist)
Second pic below
If i have genre = all genre .. it doesn't (doe not put anything in playlist)
Any thoughts on what i might be doing wrong..
If it is a bug... it isn't critical.. the work around is that i just need to pick genre... and make sure that the artist i want to play albums from are all a single genre.
More likely... it is something i'm doing wrong... or "unique" in my setup.
Thanks in advance
HS3 Pro Edition 3.0.0.297 (Windows)
Squeezebox plugin 3.1.4.10
Andrew B.
Old March 1st, 2017, 08:41 AM
pcp pcp is offline
Super Seer
I will look into this. I am working in this area due to changes for Spotify.
Old March 14th, 2017, 11:46 PM
pcp pcp is offline
Super Seer
Try version 3.1.4.12 in the updater. I made updates for the "All genre/artist/album" selection. It should work better though found a few edge cases where LMS does not search them correctly even if the command is send to search all. Give it a try.
Old March 25th, 2017, 03:47 PM
ArbWare's Avatar
3.1.4.12 seems to have done the trick, can now do an event for all Pink Floyd songs!
HTML code is On
Plug-in not working as expected doppiaemme BLOccupied (3P) 1 December 1st, 2016 12:38 AM
How much support is expected? larhedse HomeSeer General Discussion Area 21 September 8th, 2016 11:26 AM
Script not working as expected mikee123 HS3 Scripting 5 September 4th, 2016 04:55 PM
Alert Triggers not working as expected slbuck WeatherXML 10 February 7th, 2016 06:01 AM
Send Message to Client Not Working as Expected zakrzep Clients - Android 2 April 8th, 2011 12:02 PM
