Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion
Irrigation Discussion Discussion of irrigation integration with HomeSeer systems.
Old June 12th, 2017, 01:38 PM
AttilaHooper's Avatar
AttilaHooper AttilaHooper is offline
Resolved! OpenSprinkler HS3 problem after update - Failed to get interface
After installing the latest update to HS3, Opensprinkler errors out
I also can't get to the Plugins | OpenSprinkler | config page.
I tried removing the OS plugin.
HS 3.0.0.318
OS plugin 2.1.6.0 is failing to get interface
OS fw 2.1.6
Initializing plug-in(2): OpenSprinkler Instance::Object reference not set to an instance of an object.STACK: at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.InitIO(String port) at Scheduler.clsHSPI.CheckInterfaces() uler.clsHSPI.CheckInterfaces()Startup Complete, 1 errors detected, check the log for more information
Solved:
The IP address of the OpenSprinkler hardware was changed. Deleted the HSPI ini file, reinstalled the plugin. Don't forget to change you firewall rules if you have separate homeauto vlan.
Update to 17.0.4 failed vasrc mcsSprinklers 2 January 21st, 2017 04:48 PM
update to (2.0.30.0) failed ajachierno BLLAN (3P) 3 August 12th, 2016 05:33 AM
Problem on Ztroller - Failed getting interface jetek Harmony Hub 1 April 22nd, 2016 04:48 AM
Update failed TomTom SqueezeBox Plug-In (3P) 12 August 31st, 2015 10:06 AM
update failed garycc HS2 / HSPRO 2 July 21st, 2009 08:14 PM
