I just changed this setting on a Windows 10 machine running HS3
Start -> Control Panel -> Time and Language -> Formats -> Additional date, time & regional settings -> Region -> Change data, time, or number formats -> Additional settings -> Numbers -> Decimal Symbol changed from , to .
I need this for the temperature values to become 19.5 instead of 19,5 since i cannot send 19,5 to an MQTT broker to get it in grafana succesfully
But now it seems it broke the JowiHue database in some sort of way
mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:57 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:51 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:51 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:51 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:51 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue ============================================================================================== mrt-01 12:58:49 JowiHue -------------------------------------Bridge info --------------------------------------------- mrt-01 12:58:49 JowiHue 10 lights connected to bridge 'Meterkast' mrt-01 12:58:49 JowiHue 7 Groups available on bridge 'Meterkast' mrt-01 12:58:49 JowiHue Bridge Meterkast is at version 01041302 of type BSB001 mrt-01 12:58:49 JowiHue -------------------------------------Plugin info --------------------------------------------- mrt-01 12:58:49 JowiHue 0 Presets available for use in the JowiHue plugin mrt-01 12:58:49 JowiHue 0 Local scenes available for use in the JowiHue plugin mrt-01 12:58:49 JowiHue 0 Animations available for use in this plugin mrt-01 12:58:49 JowiHue Device of reporting bridge and light firmware updates is enabled mrt-01 12:58:49 JowiHue ============================================================================================== mrt-01 12:58:49 JowiHue Plugin succesfully started mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:LWB004 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:TRADFRI bulb E14 WS opal 400lm Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow All Lights : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow Woonkamer : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow Dylan : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow Elin : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow TV Kamer : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow Buro : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (Groupcheck): Error on grouprow Hektar : Object reference not set to an instance of an object. mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:TRADFRI bulb E14 WS opal 400lm Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:LWB004 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:LWB004 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:RB 162 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:TRADFRI bulb GU10 WS 400lm Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:49 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:49 JowiHue Warning: Unknown lighttype found:TRADFRI bulb E14 WS opal 400lm Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:48 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:48 JowiHue Warning: Unknown lighttype found:LWB006 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:48 JowiHue Error: (UpdateLampTypes):constraint failed column ModelID is not unique mrt-01 12:58:48 JowiHue Warning: Unknown lighttype found:LWB006 Please report this type to plugin owner with extra information (color enabled, color temperature enabled etc.)? mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (UpdateLight):Object reference not set to an instance of an object. mrt-01 12:58:48 JowiHue Error: (InitialLights):DataTable internal index is corrupted: '5'. mrt-01 12:58:48 JowiHue Error: INITDevices: unknown related device found: Bridge update ref:795 with devicetype: Scene mrt-01 12:58:48 JowiHue Upgrading devices to latest version 10 mrt-01 12:58:47 JowiHue * Connected to bridge Meterkast at 192.168.110.84:80 mrt-01 12:58:40 JowiHue InitIO:Plugin basic initialisation done mrt-01 12:58:40 JowiHue Error: (InitDatabase):Input string was not in a correct format.Couldn't store <0,45> in StandbyPower Column. Expected type is Double. mrt-01 12:58:40 JowiHue Error: (InitDatabase):error occured at table: LampTypes with statement select * from LampTypes mrt-01 12:58:40 JowiHue Starting plugin JowiHue 2.0.1.6 on Windows mrt-01 12:58:31 JowiHue JowiHue Plugin is stopped. Thanks for using it :-)
