Go Back   HomeSeer Message Board > User Interface Plug-ins > User Interface Discussion
User Interface Discussion User Interface Plug-ins
Old July 21st, 2014, 11:05 AM
Richel Richel is offline
Seer Master
Lost remote web access to HomeTroller - Solved!
Yesterday, while enroute home from a trip, I found I could not access remotely my HS2 PRO (version 2.5.0.81). When I got home, I found that Homeseer had thrown an exception and had to be restarted. I rebooted the computer and still could not access HS2 PRO remotely ("This webpage is not available.").
I can ping the device with its local IP address. I can ping the device using ***.myhomeseer.com. The firewall is off on my HomeTroller. I can access HS2 PRO remotely with HSTouch on either an iPad or my android phone.
Suggestions for fixing the web browser access problem would be appreciated.
Elliott
Old July 21st, 2014, 11:11 AM
Rupp's Avatar
Rupp Rupp is offline
OverSeer
When you attempt to access the web interface are there any errors logged in the HomeSeer.log file?
-Rupp
Old July 21st, 2014, 11:38 AM
Seer Master
Quote:
Rupp:
Thanks. There are no error messages logged no matter whether I try to access with the internal IP address or with ***.myhomeseer.com.
Elliott
Old July 21st, 2014, 12:11 PM
Seer Master
Fixed!
I have no idea how this happened, but the server port on the web server set up page got changed from 80 to 81, which was reserved for one of my IP cameras. When I set the port back to 80, which was reserved for HomeSeer, everything worked fine.
Old July 21st, 2014, 12:16 PM
Rupp's Avatar
OverSeer
If HomeSeer sees the port set as busy it will attempt to bump up the port to the next available port.
Old July 21st, 2014, 01:20 PM
Seer Master
Interesting! Thanks.
HTML code is Off
HomeTroller Zee remote access dentbla HomeSeer General Discussion Area 2 December 13th, 2013 03:34 PM
Lost communication - Solved! cjin Aprilaire 2 November 23rd, 2012 01:28 PM
Cannot access web control on Hometroller - Solved! michael.h HomeTroller™ 19 October 8th, 2012 11:14 AM
remote access troubleshooting - Solved! pacollier HS2 / HSPRO 1 June 3rd, 2012 11:28 PM
Remote access stopped working on my HomeTroller 3 Smiley HomeTroller™ 3 February 13th, 2011 01:48 PM
