Go Back   HomeSeer Message Board > User Interface Plug-ins > User Interface Discussion
User Interface Discussion User Interface Plug-ins
  #201
Old November 9th, 2017, 11:36 AM
ian351c ian351c is offline
Seer Plus
Hey Antonio,
I just sent you a PM to request access to the iOS app. I'm adding a note here just in case it doesn't go through.
Thanks.
  #202
Old November 9th, 2017, 06:52 PM
avargaskun's Avatar
avargaskun avargaskun is offline
Seer Plus
Hey all,
Unfortunately, I'm currently at the maximum number of devices that can be registered for ad-hoc distribution. So now I'm looking into adding HSBuddy to the app store for iOS. It will take me a few days to get it started, and approval can take a couple weeks. If you've simply replaced a device and know your previous and new UDIDs then I can swap them and you'd be able to use the app in the next couple days. Just send me the details on a PM.
Antonio.
  #203
Old November 10th, 2017, 01:28 AM
TechFan's Avatar
TechFan TechFan is offline
Originally Posted by avargaskun View Post
Hey all,
Antonio.
Thx. Sent my old and new device ids.
  #204
Old November 10th, 2017, 02:56 AM
avargaskun's Avatar
Seer Plus
Version 1.0.22
Quick note:
A new version of the app is out for both iOS and Android. This new version lets you set a 'local' connection override. Set it if you would like your phone/tablet to connect to your HS3 via local WiFi while at home, but still be able to connect using MyHomeSeer or your own DNS when connecting from anywhere else. You can choose this new setting at the bottom of the Connection configuration page.
Also, in this new version you will find at the top-left corner of the app two icons that will show when the 'local' connection override is active (a Home icon) as well as one to let you know when the ASCII connection is established (an @ icon). This new version includes a few reliability fixes for ASCII.
Minimal tests were performed on both iOS and Android Please let me know if you run into any issues.
Links to the new versions below. Cheers!
Antonio.
iOS app: https://rink.hockeyapp.net/apps/55ad...99834344dcf288
Android app: https://rink.hockeyapp.net/apps/e1b5...4d842273ba7e60
Plugin: Available under the BETA section of the Plugin Manager in your HS3 server.
  #205
Old November 10th, 2017, 03:20 AM
TechFan's Avatar
Quick note:
Antonio.
Nice, I have always manually switched to MyHomeseer when away from home. . .
  #206
Old November 12th, 2017, 01:46 PM
pcp pcp is offline
Super Seer
Antonio, it would be great to add support for thermostat setpoint (heat or cool) control. It shows the values but cannot control it in the app. Thanks
  #207
Old November 12th, 2017, 09:16 PM
avargaskun's Avatar
Seer Plus
Version 1.0.23 (Android only)
Hello!
A new version is available in HockeyApp. This update is only for Android. It makes it possible to add dynamic shortcuts to HSBuddy. Dynamic shortcuts show when you perform a long tap on the HSBuddy icon from your launcher/home screen. This feature, which was only available in the iOS version of the app (using 3d touch) is now available for Android devices with Nougat or later.
Light testing was performed before releasing the app - please let me know if anything looks weird after updating!
Antonio
  #208
Old November 19th, 2017, 10:26 PM
mattdb's Avatar
mattdb mattdb is offline
any update on the app store for IOS?
  #209
Old November 19th, 2017, 11:30 PM
avargaskun's Avatar
Seer Plus
Not much yet, cleaning up the project so it can be submitted to the store has been taking me a little longer than expected
Thankfully there were a few people who reached out with UDIDs from old phones no longer in use, which gave me a little room to take in a few more users meanwhile.
  #210
Old November 20th, 2017, 12:13 AM
avargaskun's Avatar
Seer Plus
Version 1.0.25
A couple more updates have gone up to HockeyApp, both for iOS and Android:
  • Support adding shortcuts to cameras.
  • Support pinning shortcuts (Android only). These are independent shortcuts that show up in the home screen, and there is no limit to how many you can add.
  • Minor improvements in reliability for cameras
There is also a new version of the HSBuddy plugin for HS3 (version 3.5.1118.14) which improves reliability and performance for cameras.
As always, let me know if anything looks weird after the update.
Antonio
  #211
Old November 20th, 2017, 01:01 AM
levring levring is offline
Hi Antonio
Any news on the progress of getting the app submitted to app store?
/Jonas
  #212
Old November 20th, 2017, 10:51 AM
mattdb's Avatar
Well, if you have one laying around.....can ya hit me with it?
  #213
Old November 29th, 2017, 11:00 PM
avargaskun's Avatar
Seer Plus
HSBuddy on the iOS app store
After a long time, it's finally there:
https://itunes.apple.com/us/app/hsbuddy/id1317682478
I will continue to post the latest builds to HockeyApp first, but I will try to update the version in the app store regularly. The versions in HockeyApp will now display the name "HSBuddyBeta". That way, if you happen to have both versions installed, you will be able to differentiate between the 2.
If you are using push notifications with a target of "All Devices", those should continue to work if you switch to the new app. Any push notifications that were targeted to a particular phone will need to be updated, as the new app will appear as a new device connected to your HS3 server.
Thanks to everyone who pushed me to get it done
PS. Sending feedback from the app still works. I look forward to your reports of anything that doesn't look right, as they help me prioritize what to do with the limited time I have available to spend on this project
  #214
Old November 30th, 2017, 09:21 AM
Seer Plus
Installed last night from the App Store to my iPhone and iPad. Looks great so far. Thanks so much for this!
  #215
Old November 30th, 2017, 01:49 PM
TechFan's Avatar
  #216
Old December 5th, 2017, 05:39 PM
teladog01 teladog01 is offline
App store version...cannot connect when "Use secure connections" is checked
I'm running nginx reverse proxy for HTTPS on my Windows HomeSeer box and the "Use secure connections" option in HSBuddy was working fine on the old HockeyApp version. But when I switched to the App Store version, I'm unable to connect with "Use secure connections" checked. It does connect if I change to the HTTP port and uncheck the secure connection box.
Did anything change regarding this issue in the new App Store app? Can anyone confirm they are able to connect with the "Use secure connection" option in the App Store version?
Edit:
I am using a self-signed certificate, so that could be a factor. But it was working fine with the self-signed cert on the HockeyApp version.
  #217
Old December 5th, 2017, 11:39 PM
avargaskun's Avatar
Seer Plus
Edit:
Unfortunately I had to remove that functionality from the version in the app store because it relied on an API that wasn't approved by Apple in their store btw, that's the only difference between the app store and HockeyApp versions.
In case it helps, I'm running the same setup (nginx proxy) with a certificate I got for $10/yr from namecheap.com
If you decide to go back to the HockeyApp version and need additional UDIDs authorized send me a PM.
  #218
Old December 6th, 2017, 12:18 PM
Thanks for confirming it was the cert. I setup a trusted cert last night using letsencrypt and now it's working again.
  #219
Old December 12th, 2017, 08:50 PM
bdickhaus's Avatar
bdickhaus bdickhaus is offline
Super Seer
Error on plugin initialization
I'm getting this when I enable the plugin:
Dec-12 7:39:14 PM Info Plugin HSBuddy with instance: has disconnected
Dec-12 7:39:09 PM Error Initializing plug-in(1): HSBuddy Instance::System.TypeInitializationException: The type initializer for 'SQLite.SQLiteConnection' threw an exception. ---> System.DllNotFoundException: e_sqlite3 at (wrapper managed-to-native) SQLitePCL.SQLite3Provider_e_sqlite3+NativeMethods:sqlite3_li bversion_number () at SQLitePCL.SQLite3Provider_e_sqlite3.SQLitePCL.ISQLite3Provid er.sqlite3_libversion_number () [0x00000] in :0 at SQLitePCL.raw.SetProvider (SQLitePCL.ISQLite3Provider imp) [0x00008] in <1087f93847e244b6a7258d70cb1cb617>:0 at SQLitePCL.Batteries_V2.Init () [0x00005] in <9f3b9cff430a4862bf8d33c2fed62fec>:0 at SQLite.SQLiteConnection..cctor () [0x00000] in <49ac49cfb94341128f6929b3ff2090ee>:0 --- End of inner exception stack trace --- at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_generic_class_init (intptr) at HSPI_HSBuddy.Data.Database..ctor () [0x0003b] in <130eda08607345c4ac9bf89cd5feb20e>:0 at HSPI_HSBuddy.Server..ctor () [0x00006] in <130eda08607345c4ac9bf89cd5feb20e>:0 at HSPI_HSBuddy.HSPI.InitIO (System.String port) [0x00011] in <130eda08607345c4ac9bf89cd5feb20e>:0
Dec-12 7:39:09 PM Info Plugin HSBuddy has connected. IP:127.0.0.1:40536
I'm on Linux. Ubuntu 16.04 64 bit.
Mono JIT compiler version 5.4.1.6 (tarball Wed Nov 8 21:20:16 UTC 2017)
Current Date/Time: 12/12/2017 7:43:06 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.387
Linux version: Linux rock64 4.4.77-rockchip-ayufan-118 #1 SMP Thu Sep 14 21:59:24 UTC 2017 aarch64 aarch64 aarch64 GNU/Linux System Uptime: 1 Day 22 Hours 4 Minutes 34 Seconds
IP Address:
Number of Devices: 350
Number of Events: 189
Available Threads: 398
HSTouch Enabled: False
Event Threads: 0
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed:
Enabled Plug-Ins
2.0.38.0: BLLAN
2.0.93.0: BLRF
2.0.71.0: BLSpeech
1.2.2.0: Device History
3.5.1118.14: HSBuddy
2.0.1.6: JowiHue
3.0.1.90: PHLocation
3.0.4.9: SDJ-Health
3.0.6413.20219: UltraNetCam3
3.0.1.165: Z-Wave
  #220
Old December 30th, 2017, 11:53 AM
wb-avl wb-avl is offline
Viewer
Any tips for push messages in ios?
I'm really liking this app!
I have setup a few push messages but I'm not having any luck.
I have notifications enabled for the app on my iphone.
I also checked the hsbuddy plugin and the client info appears correct.
My server log shows "push notification successfully sent to 0 devices"
Tags
app, client, mobile, phone, remote
All-In-One Mobile UI ... iPhone, Windows Mobile, etc alevey Web Server and Interface 11 February 7th, 2013 12:11 PM
Mobile brenton.prettejohn pjc Network 0 September 19th, 2011 04:27 AM
Mobile Backup darren-mc SMS Connector 0 August 23rd, 2010 04:46 AM
Windows Mobile Help 68sting Clients - Windows CE / Mobile 0 October 23rd, 2009 05:53 PM
Help with Windows Mobile Please phillb Clients - Windows CE / Mobile 4 February 25th, 2009 06:49 PM
