Old March 29th, 2016, 04:11 PM
Engelwood Engelwood is offline
Viewer
Question Cloud Refugee. Advice needed about switching to Homeseer?
Current SmartThings user. Iíve been putting up with grief from the wife, system instability, and general poor performance for far too long. The last two weeks just broke the camelís back.
After examining the other options, Iím strongly considering making the switch to Homeseer. Seems like a mature platform with a great community so I thought Iíd ask for some advice before jumping in.
My current setup:
30 z-wave dimmers (Leviton VRMX1-1LZ)
Five z-wave switches (Leviton VRS15-1LZ)
One z-wave siren (Everspring EVS-SE812-US)
Two Schlagle z-wave door locks (Schlage FE599NX and BE469 CAM 619)
10 or so z-wave door sensors (Monoprice, Schlage, and a few everspring)
Four outlets (GE 12721)
Two Mimolites
Two first alert z-wave smoke detectors
Five Sonos Play Ones
One 1 Sonos Play Five
Aeon Mini-mote
Future Expansion:
Amazon Alexa
5~8 Z-wave motion detectors to replace the zigbee ones Iím currently using.
Somfy blinds
A few z-wave bulbs for areas where I donít have a switch installed.
A few more open-close sensors.
Infinity Carrier touch control
Garage door controllers
My Homeseer Plan:
Iíve got a SmartStick+ on order, and Iíll be purchasing a fanless computer to run my setup. Itíll be a dedicated Homeseer computer running windows 7.
Plugins I think I'll be running:
Spud IFFT
UltraSMTP3
Alexa plugin
Sonos
ImperiHome or the new HSBuddy App
Easy trigger
Some sort of location plugin to trigger lighting when I leave or arrive home.
Weather plugin
Iím sure there will be 4 or 5 more that I havenít discovered yet.
My biggest questions/concerns:
Computer: I'm thinking about using a Qotom qs-190. Itís got a Celeron j1900 processor (quad core 2 GHz) with 4gb of ram and a 32gb ssd. Will this have enough horsepower for my needs and future expansion projects? Iíd like to have this setup last me 5 years or so. Would you recommend Windows 7, windows 10 or Linux?
Reliability: Once Iíve got the system running to my needs will I be able to set it and forget it? (obviously setting aside some time for general maintenance, updates, etc.)
Response time for motion detectors: I tested an aeon multi-sensor with motion when using SmartThings and wasnít happy with the response time. Iíd get halfway across the room before the sensor would detect my movement and trigger the lights. I wasnít sure if this was a SmartThings limitation (probably), or a common z-wave motion detector issue? How is Homeseer when it comes to response time?
Presence: The one nice feature that worked semi-reliably for me on SmartThings, was the presence detection. Iíve seen the PHlocation plugin and a few other solutions using Beacons. Ideally Iíd like to have the lights turn off and lock the doors after leaving the house. Itíd also be nice to turn lights on when returning home. Would love to hear how others are replicating this functionality?
Any other potential issues with my setup or planning? Missing any plugins? Thanks a ton in advance! Looking forward to diving in!
Old March 29th, 2016, 04:35 PM
macromark's Avatar
macromark macromark is offline
HomeSeer Technologies
Welcome to the board! Your post was moderated because is had links in it... but now it's visible.
The PC you mentioned should be more than adequate for now and some time to come. Others will no doubt weigh in!
Motion sensor latency with HomeSeer depends more on the motion sensor than on our controller, since the event is triggered and processed locally. In fact, the event will process faster than the web interface (or mobile app) will indicate.
Personally, I don't use occupancy to trigger much since there's a kid or two at home most of the time. I do use a couple motion sensors tied into an HS3 timer to control lighting in my shed/garage, however.
Old March 29th, 2016, 05:43 PM
MrMxyzptlk MrMxyzptlk is offline
I don't think you will have many issues with any of the devices you have listed or the system. Make sure you have the server on a UPS because power outages will bite you in the butt. You can download Blades free backup plugin, and you can create a .zip file on whatever schedule you want. If your system goes to **it, you can just extract the last working backup over the HS3 install, and restart. 5 minutes later you're back in business. I have used just about every software and hardware HA setup you can imagine, and HS3 is the most diverse, stable, active HA software I have run across. The only minor thing that bothers me, is the mobile interface HSTouch. It is kind of Fugly. But there are active 3rd party solutions, and HS3 has a complete API. I say go for it!!!
Old March 29th, 2016, 06:24 PM
Eman Eman is offline
Hi Engelwood,
For multi sensor you should try the FIBARO motion sensor (http://www.fibaro.com/en/the-fibaro-.../motion-sensor). The battry life is incredible. Mine is stuck at 100% since 18/07/2015
Where I am it would be best if locks were triggered on a timely (under 1 min or less) manner after you pressed a button, let say HSTouch or z-wave key-fob for security reasons only. You can't solely rely on location based conditions because the weather sometimes gets in the way.
Thus GPS is not pin point accurate on some days. Things like lights and the rest you can trigger at long distances. But locks, try not to.
For presence and more cool stuff you can also check out this discussion here: http://board.homeseer.com/forumdisplay.php?f=1272 Combined with PHLocation plugin you can do amazing things.
I hope you enjoy HomeSeer.
Eman.
Old March 29th, 2016, 11:11 PM
Viewer
Thanks for the welcome, motion sensor recommendations, and plugin suggestions!
Computer is on the way! Looking forward to diving in over the next few weeks!
Old March 29th, 2016, 11:25 PM
reidfo's Avatar
reidfo reidfo is offline
Regarding stability, I personally would recommend running HomeSeer under Linux. I used to run HSPRO under Windows 7 and 8, but only since switching to Linux have I had a system I can comfortably "set and forget" without worrying about crashes. Just make sure the plugins you need are supported under Linux.
Old March 29th, 2016, 11:49 PM
Automated Automated is offline
Running under Windows here, and HS3 has run for months before, with the only reason it stopped being that I wanted to update Homeseer.
If you have a dedicated box, that does nothing else, Windows can be stable also. I do recommend running HS on Linux if possible, as the OS overhead is smaller. However, if one wants to use some plug-ins only supported on Windows, then it's no big deal.
Old April 2nd, 2016, 04:03 PM
Viewer
Computer is here! Considering installing Linux, but just a bit hesitant because of the potential plugin issues.
I've been looking, but is there some sort of list of plugins that aren't compatible with Linux? If not are there any heavily used plugins that might not work with my setup?
Hoping the smartstick+ ships soon! I'm really itching to get started!
Old April 2nd, 2016, 07:15 PM
reidfo's Avatar
It might take a little more time if you decide later to switch to Windows, but I'd suggest installing HomeSeer under Linux and then looking in the updater to see what's available. If the plugins you want aren't listed you can wait patiently (like I am) or just reinstall with Windows.
Stability for me under Linux has been SO much better. And I've run HS3 under multiple Windows versions, all on their own dedicated virtual machine.
amazon unlimited cloud backup and homeseer collegeboyslive HomeSeer General Discussion Area 14 August 27th, 2015 09:32 AM
HomeSeer Adds Cloud Service to Home Automation System Pete HomeSeer General Discussion Area 6 May 4th, 2014 10:33 PM
Significant Delays Between Nodes and HomeSeer - Advice Needed SouthFloridaMatt HomeSeer Z-Wave Plug-in 3 November 23rd, 2010 02:39 PM
advice needed curlywol RFXCOM Plug-In (3P) 10 July 6th, 2010 07:57 AM
Switching to new Ztroller. Steps needed. pp Z-Trollerô 12 May 11th, 2007 09:24 PM
