Advice on transitioning from old house to new house
    I am moving to a new home, before my old home has been sold. I need to maintain minimal home control at the old house, while adding home automation at my new house. I have HS3Pro, currently. The transition will take more than 30 days, so a trial period for new software will be too short. Is there a way to make this transition that would avoid buying a second software license, when, ultimately, I will only need one license?
    Elliott
    "Living with technology means living in a [constant] state of flux." S. Higgenbotham, 2023
    If your trial runs out put in a support request and it can be reset once.
      Excellent! Thanks and Happy Thanksgiving.
      Elliott
        Depending on your setup: you could move the server over and set up a VPN tunnel back to the old home (or control the new home from the old one). If you are a Zwave guy; you can add a new zNet to your new house and control them both. Once the old house sells; delete that zWave network.
        HS3 Pro Edition 3.0.0.435 (Windows Server 8.1 on ESXi box)
        Plug-Ins Enabled:
        Z-Wave:,RaspberryIO:,AirplaySpeak:,Ecobee:,
        weatherXML:,JowiHue:,APCUPSD:,PHLocation:,Chromecast:,EasyTr igger:
          Thanks for the suggestion. Elliott
            Elliott
            Sounds like you're not planing on leaving the system at the old house. Leaving it could be a plus to prospective buyer.
            That's one reason I'll keep my ZEE S2 around even after switching to pro. I'll just have to avoid anything that needs the pro license unless I want to purchase just that feature such as a plugin.
            Something you might think about.
            HomeSeer Version: HS3 Standard Edition 3.0.0.548
              Thanks. I have been thinking about leaving home automation in place, but on a much simpler scale than what I am currently running.
              For several reasons, I decided to buy a license for a second HS3 program, but just the standard version. I have 2 Z-Nets, one of the original models and a newer one with built-in wifi. Each program is running on a separate mini-PC (Tangents). I discovered that my Z-wave devices cannot be on both Z-Nets at the same time. I still have many installed X-10 devices, which work nicely with both setups. So, I am focusing on the X-10 devices and plan to remove the Z-wave devices and replace them with either non-automated devices (e.g., light switches) or X-10 devices that I still have.
              Elliott
