Working through my first installs with the plugin. I have read most of the threads in this foruma nd appreciate the community approach. Does anyone have any information on timelines for overcoming some of the listed issues, like the plugin not recognizing local switch actions, etc? I would be interested in seeing what is coming up when.
Insteon Address
The plug-in is farther along than the SDM will allow, which means that the timeline will be following the SDM closely.
I would say that local control recognition will follow within a day or so of the next major SDM release (about 2 weeks according to SH).
Link/Scene programming should follow a week or two later, assuming the SDM is stable enough to allow for programming the remote units without turning them into bricks.
Jon
Originally posted by DrakeWorking through my first installs with the plugin. I have read most of the threads in this foruma nd appreciate the community approach. Does anyone have any information on timelines for overcoming some of the listed issues, like the plugin not recognizing local switch actions, etc? I would be interested in seeing what is coming up when.Jon Ort
JonOrt@The--Orts.com
I should clarify that a bit... Insteon does not have local control reporting at all. This is a future firmware update to the modules according to SmartHome.
Recognizing that another switch or controller changed a light will be there in the next major release.
Getting something that would be just like "local control reports" to work involves some reprogramming of the remote switches, as well as downloading internal memory locations which can change on a device by device basis. It is going to be some amount of work.
This should be in the major-release-after-next, assuming that it actually works which as far as I know right now is only conjecture.
Jon
Originally posted by DrakeExcellent news. Always nice to hear short timelines are possible. I look forward to seeing what comes out!Jon Ort
Near76
Oman...the module FW updates that you are talking about regarding local control changes, do they require new modules or can the SDM upgrade the FW via the SignalLinc?
In setting up the PLU, does each device that you wish to use have to be manually linked to the PLU? I got a keylinkpad working on its main load, but had linked that to the smart home software prior to playing with Home Seer. I tried to add three lamp linc devices and got a can not communicate.
Thoughts anyone?
The plug-in handles adding the proper records to the PLC. You don't have to tap-link anything.
Is the LED blinking on the PLC? If so use the downlad core option.
If not then use the generate report file option in the config screen *after* you try to add the device. That will show what is going wrong.
Jon
Originally posted by DrakeIn setting up the PLU, does each device that you wish to use have to be manually linked to the PLU? I got a keylinkpad working on its main load, but had linked that to the smart home software prior to playing with Home Seer. I tried to add three lamp linc devices and got a can not communicate.
Thoughts anyone?Jon Ort
I tried to tap link this device after posting and it worked instantly. Will try the next one without and repost in a few.
In the mean time, having issues with an x10 control to. I am using a RR501? X10 reciever to handle recieving RF remote signals. To test it I plugged it in piggyback with the PLU. In using the smarthome software, I can control the device directly with house code a9 (There is a built in lamp module). When testing it through homeseer, I can not control the a9 directly. In my log, the following is seen.
1/27/2006 8:21:49 PM Info Initializing X10 Plug-in: INSTEONBASIC On COM Port 1
1/27/2006 8:21:49 PM Info Initializing Plug-in: INSTEONBASIC
1/27/2006 8:21:49 PM Error Initializing X10 interface INSTEONBASIC: Object variable or With block variable not set.
1/27/2006 8:21:49 PM Info Done initializing X10 interface INSTEONBASIC
Thoughts?
ok,
tried it and here is what I get....
Insteon Basic Plug-in Configuration - BETA VERSION
The Insteon device at 01.45.d7 did not respond. Please check to make sure the address is correct and that the device is powered-up. The device was not registered.
---Decode: Src[00.48.D4] Dst[--.--.--] {Ack/Dir} Cmdevice ID Broadcast, Type:00D6 Firmware Ver:63 Ex: FF
1/27/2006 8:43:57 PM : Got device type broadcast for Insteon ID 00.48.D4
1/27/2006 8:43:57 PM : Found it registered as as Device 2, updating types
1/27/2006 8:43:57 PM : rOLR: 00.48.D4,FF
1/27/2006 8:43:57 PM : Got current level for ID 00.48.D4 Unit code 2, Level: 100
1/27/2006 8:43:57 PM : Setting status and value for device [2 to % based value of 100
1/27/2006 8:44:11 PM : Timed poll for Insteon device ID 01.60.F6 Unit code 1, Last contact 1/27/2006 8:42:57 PM. Polling interval of 1 min. reached, polling...
1/27/2006 8:44:11 PM : Calling DM: GetOnLevelRaw=01.60.F6
1/27/2006 8:44:11 PM : xIns: 00 D6 63 01 60 F6 05 19 00
---Decode: Src[00.D6.63] Dst[01.60.F6] Cmd:Status Request 00
1/27/2006 8:44:12 PM : rIns : 04 01 60 F6 00 D6 63 25 2B 00 - Event: Received ACK msg for PLC
---Decode: Src[01.60.F6] Dst[--.--.--] {Ack/Dir} Cmd:Peek Ex: 00
1/27/2006 8:44:12 PM : rOLR: 01.60.F6,00
1/27/2006 8:44:12 PM : Got current level for ID 01.60.F6 Unit code 1, Level: 0
1/27/2006 8:44:12 PM : Setting status and value for device [1 to % based value of 0
1/27/2006 8:44:53 PM : ref_page -- insteonbasic_config
1/27/2006 8:44:53 PM : special_info -- data
1/27/2006 8:44:53 PM : id1 -- 01
1/27/2006 8:44:53 PM : id2 -- 45
1/27/2006 8:44:53 PM : id3 -- d7
1/27/2006 8:44:53 PM : name -- Lamp 2
1/27/2006 8:44:53 PM : location -- Family Room
1/27/2006 8:44:53 PM : interval -- 1
1/27/2006 8:44:53 PM : button -- Confirm Add Device
1/27/2006 8:44:54 PM : rTxt: addid=True,01.45.D7
1/27/2006 8:44:54 PM : Calling DM: SendInsteonRaw=00 00 00 01 45 d7 0F 10 00
1/27/2006 8:44:54 PM : Waiting for Insteon raw message: 02 01 45 d7 ** ** ** 8F 01
1/27/2006 8:44:54 PM : xIns: 00 00 00 01 45 D7 0F 10 00
---Decode: Src[00.00.00] Dst[01.45.D7] Cmd:Ping 00
1/27/2006 8:44:55 PM : rTxt: sendinsteonraw=True
1/27/2006 8:44:58 PM : Did not see the message in time.
1/27/2006 8:44:59 PM : Delete Device Index: 3, Currently 3 Installed.
1/27/2006 8:45:11 PM : Timed poll for Insteon device ID 00.48.D4 Unit code 2, Last contact 1/27/2006 8:43:57 PM. Polling interval of 1 min. reached, polling...
1/27/2006 8:45:11 PM : Calling DM: GetOnLevelRaw=00.48.D4
1/27/2006 8:45:11 PM : xIns: 00 D6 63 00 48 D4 05 19 00
---Decode: Src[00.D6.63] Dst[00.48.D4] Cmd:Status Request 00
1/27/2006 8:45:12 PM : rIns : 04 00 48 D4 00 D6 63 25 01 FF - Event: Received ACK msg for PLC
1/27/2006 8:45:12 PM : Got device type broadcast for Insteon ID 00.48.D4
1/27/2006 8:45:12 PM : Found it registered as as Device 2, updating types
1/27/2006 8:45:12 PM : rOLR: 00.48.D4,FF
1/27/2006 8:45:12 PM : Got current level for ID 00.48.D4 Unit code 2, Level: 100
1/27/2006 8:45:12 PM : Setting status and value for device [2 to % based value of 100
1/27/2006 8:45:26 PM : Timed poll for Insteon device ID 01.60.F6 Unit code 1, Last contact 1/27/2006 8:44:12 PM. Polling interval of 1 min. reached, polling...
1/27/2006 8:45:26 PM : Calling DM: GetOnLevelRaw=01.60.F6
1/27/2006 8:45:26 PM : xIns: 00 D6 63 01 60 F6 05 19 00
1/27/2006 8:45:27 PM : rIns : 04 01 60 F6 00 D6 63 25 2B 00 - Event: Received ACK msg for PLC
1/27/2006 8:45:27 PM : rOLR: 01.60.F6,00
1/27/2006 8:45:27 PM : Got current level for ID 01.60.F6 Unit code 1, Level: 0
1/27/2006 8:45:27 PM : Setting status and value for device [1 to % based value of 0
1/27/2006 8:45:47 PM : ref_page -- insteonbasic_config
1/27/2006 8:45:47 PM : special_info -- data
1/27/2006 8:45:47 PM : button -- Continue
1/27/2006 8:45:50 PM : ***:Forced error / log generation
--------* End Pre-Error Log*--------------
Please use the generate report and post it when reporting problems. Pretty Pretty please?
That error will occur if you disable and re-enable the X10 part of the plug-in. This is the only plug-in that supports both IO and X10 as an option and there is something whacky in HomeSeer when enable and disable them separately in a session. If this is the problem then restarting HomeSeer will fix it. If not then the error report will tell me what is up.
Jon
Originally posted by DrakeI tried to tap link this device after posting and it worked instantly. Will try the next one without and repost in a few.
Thoughts?Jon Ort
It is a new way to do things but it should speed up finding problems by a factor of about 10. I thought I would throw an extra "pretty" in there just in case you were in an especially bad mood :>
Jon
Originally posted by Drakepretty please always does it for me. I promise to do that going forward.Jon Ort
Here is what I get in regards to the x10.
Tried to control device A9 as a device in homeseer.
PLU Log:
InsteonBasic Processor Error Log Generated 1/27/2006 8:54:06 PM
-----------*Error Message*----------------
Error: Forced error / log generation -- 1/27/2006 8:54:06 PM
--------*Initialization Log*--------------
1/27/2006 8:52:32 PM : Host System: HomeSeer 2.0.2041.0
1/27/2006 8:52:32 PM : RegisterCallback Completed
1/27/2006 8:52:32 PM : Enter InitX10
1/27/2006 8:52:32 PM : Enter InitPlugin
1/27/2006 8:52:32 PM : Global initialization of plug-in required, starting up.
1/27/2006 8:52:32 PM : Connecting to SDM component...
1/27/2006 8:52:33 PM : Connected to SDM component, Checking PLC connection...
1/27/2006 8:52:33 PM : ***:Error In InitPlugin: System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure
at SDM3Server.ISDM3.set_blocking(Boolean Value)
at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/27/2006 8:52:33 PM : Exit InitPlugin
1/27/2006 8:52:33 PM : Exit InitX10
1/27/2006 8:52:33 PM : Enter InitIO
1/27/2006 8:52:33 PM : Enter InitPlugin
1/27/2006 8:52:33 PM : Global initialization of plug-in required, starting up.
1/27/2006 8:52:33 PM : Connecting to SDM component...
1/27/2006 8:52:33 PM : PLC found, Firmware Version 2.12
1/27/2006 8:52:33 PM : PLC Insteon Address: 00.D6.63
1/27/2006 8:52:33 PM : IO/Insteon Interface Initializing...
1/27/2006 8:52:33 PM : In TransmitMessageThread
1/27/2006 8:52:33 PM : In CreateDevices
1/27/2006 8:52:33 PM : Found exising HS device: Insteon ID:01.60.F6
1/27/2006 8:52:33 PM : Found exising HS device: Insteon ID:00.48.D4
1/27/2006 8:52:33 PM : Exit CreateDevices
1/27/2006 8:52:33 PM : Exit InitIO
-----------*Pre-Error Log*----------------
1/27/2006 8:52:39 PM : rTxt: DM=active,1.01.10.146,1/27/2006 8:52:39 PM,responded,00.D6.63,2.12
1/27/2006 8:53:33 PM : Timed poll for Insteon device ID 01.60.F6 Unit code 1, Last contact 1/27/2006 8:52:33 PM. Polling interval of 1 min. reached, polling...
1/27/2006 8:53:33 PM : Calling DM: GetOnLevelRaw=01.60.F6
1/27/2006 8:53:33 PM : Timed poll for Insteon device ID 00.48.D4 Unit code 2, Last contact 1/27/2006 8:52:33 PM. Polling interval of 1 min. reached, polling...
1/27/2006 8:53:33 PM : Calling DM: GetOnLevelRaw=00.48.D4
1/27/2006 8:53:33 PM : xIns: 00 D6 63 01 60 F6 05 19 00
1/27/2006 8:53:34 PM : rIns : 04 01 60 F6 00 D6 63 25 2B 00 - Event: Received ACK msg for PLC
1/27/2006 8:53:34 PM : rOLR: 01.60.F6,00
1/27/2006 8:53:34 PM : Got current level for ID 01.60.F6 Unit code 1, Level: 0
1/27/2006 8:53:34 PM : Setting status and value for device [1 to % based value of 0
1/27/2006 8:53:34 PM : xIns: 00 D6 63 00 48 D4 05 19 00
1/27/2006 8:53:34 PM : rIns : 04 00 48 D4 00 D6 63 25 01 FF - Event: Received ACK msg for PLC
1/27/2006 8:53:34 PM : Got device type broadcast for Insteon ID 00.48.D4
1/27/2006 8:53:34 PM : Found it registered as as Device 2, updating types
1/27/2006 8:53:34 PM : rOLR: 00.48.D4,FF
1/27/2006 8:53:34 PM : Got current level for ID 00.48.D4 Unit code 2, Level: 100
1/27/2006 8:53:34 PM : Setting status and value for device [2 to % based value of 100
1/27/2006 8:54:06 PM : ***:Forced error / log generation
HomeSeer log on start up.
1/27/2006 8:52:30 PM Start
1/27/2006 8:52:30 PM Start ************************************************************ ********
1/27/2006 8:52:30 PM Start HomeSeer version 2.0.2041.0 Starting Now
1/27/2006 8:52:31 PM Startup Loading Settings
1/27/2006 8:52:31 PM Startup Settings Loaded.
1/27/2006 8:52:31 PM Startup Loading configuration file ...
1/27/2006 8:52:31 PM Info Loading device types file...
1/27/2006 8:52:31 PM Database Opening up HomeSeer database C:\Program Files\HomeSeer 2\config\sample.mdb
1/27/2006 8:52:31 PM Info Loading Devices...
1/27/2006 8:52:31 PM Load Config 2 total devices loaded.
1/27/2006 8:52:31 PM Load Config Checking device type settings for all devices...
1/27/2006 8:52:31 PM Load Config Finished checking device type settings.
1/27/2006 8:52:31 PM Load Config Loading Events...
1/27/2006 8:52:31 PM Load Config 3 total events loaded.
1/27/2006 8:52:31 PM Info Loading TV Timers...
1/27/2006 8:52:31 PM Database HomeSeer configuration database C:\Program Files\HomeSeer 2\config\sample.mdb has been closed.
1/27/2006 8:52:31 PM Info HomeSeer version is: 2.0.2041.0
1/27/2006 8:52:31 PM Info Saving address book
1/27/2006 8:52:31 PM Info Saving mailboxes
1/27/2006 8:52:32 PM Startup Checking for available plug-ins
1/27/2006 8:52:32 PM Info Found plug-in: X10 CM11A/CM12U, version: 1.0.2.0
1/27/2006 8:52:32 PM Info Found plug-in: INSTEONBASIC, version: 0.0.0.6
1/27/2006 8:52:32 PM Info Found plug-in: Is Speaking, version: 2.2.0.0
1/27/2006 8:52:32 PM Info Found plug-in: SmartHome PowerLinc USB, version: 1.0.0.7
1/27/2006 8:52:32 PM Startup Restoring device status
1/27/2006 8:52:32 PM Startup Initializing Plug-Ins
1/27/2006 8:52:32 PM Info Initializing X10 Plug-in: INSTEONBASIC On COM Port 1
1/27/2006 8:52:32 PM Info Initializing Plug-in: INSTEONBASIC
1/27/2006 8:52:32 PM INSTEONBASIC RegisterCallback Completed
1/27/2006 8:52:32 PM INSTEONBASIC Connecting to SDM component...
1/27/2006 8:52:33 PM INSTEONBASIC Connected to SDM component, Checking PLC connection...
1/27/2006 8:52:33 PM INSTEONBASIC ***:Error In InitPlugin: System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure at SDM3Server.ISDM3.set_blocking(Boolean Value) at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/27/2006 8:52:33 PM INSTEONBASIC Writing new InsteonBasic Error log file - C:\Program Files\HomeSeer 2\Config\INSTEONBASIC Error Report.Log
1/27/2006 8:52:33 PM Error Initializing X10 interface INSTEONBASIC: System.Runtime.InteropServices.COMException (0x8000FFFF): Catastrophic failure at SDM3Server.ISDM3.set_blocking(Boolean Value) at HSPI_INSTEONBASIC.HSPI.InitPlugin(Int32 Mode)
1/27/2006 8:52:33 PM Info Done initializing X10 interface INSTEONBASIC
1/27/2006 8:52:33 PM Startup IR Label file (config\irlbl.cfg) missing or corrupt, creating new file
1/27/2006 8:52:33 PM Info Done initializing infrared interface
1/27/2006 8:52:33 PM Info Initializing Plug-in: INSTEONBASIC
1/27/2006 8:52:33 PM INSTEONBASIC Connecting to SDM component...
1/27/2006 8:52:33 PM INSTEONBASIC PLC found, Firmware Version 2.12
1/27/2006 8:52:33 PM INSTEONBASIC PLC Insteon Address: 00.D6.63
1/27/2006 8:52:33 PM INSTEONBASIC IO/Insteon Interface Initializing...
1/27/2006 8:52:33 PM Info Done initializing plug-in INSTEONBASIC
1/27/2006 8:52:33 PM Info Local IP address is: 192.168.1.72
1/27/2006 8:52:33 PM Info Web Server thread started on port 80
1/27/2006 8:52:33 PM Startup Initializing text to speech
1/27/2006 8:52:33 PM Info Listening for remote speaker connections on port 8742
1/27/2006 8:52:33 PM Startup Start remoting
1/27/2006 8:52:33 PM Startup Start event processing
1/27/2006 8:52:33 PM Info This version of HomeSeer is not registered and is running as a trial, 29 days remaining.
1/27/2006 8:52:33 PM Startup Running startup script
1/27/2006 8:52:33 PM Startup Scripting is OK
1/27/2006 8:52:33 PM Info Done with scripting
1/27/2006 8:52:33 PM Startup Starting scheduler
1/27/2006 8:52:33 PM Startup Start up complete.
1/27/2006 8:52:34 PM Info Web Server authorized local login successful from: 127.0.0.1 User: default
1/27/2006 8:52:48 PM Info Speaker client connected from: 127.0.0.1
1/27/2006 8:52:49 PM Info Speaker client connected from: 192.168.1.103
1/27/2006 8:53:48 PM Info HomeSeer is performing database maintenance on sample.mdb
1/27/2006 8:53:48 PM Info Database maintenance Completed Successfully.
1/27/2006 8:53:48 PM Database Item Saving Device Unknown
1/27/2006 8:53:48 PM Database Opening up HomeSeer database c:\program files\homeseer 2\config\sample.mdb
1/27/2006 8:53:49 PM Database HomeSeer configuration database c:\program files\homeseer 2\config\sample.mdb has been closed.
1/27/2006 8:53:53 PM Info Device: Unknown Unknown (A9) OFF
1/27/2006 8:53:56 PM Info Device: Unknown Unknown (A9) ON
1/27/2006 8:54:06 PM INSTEONBASIC ***:Forced error / log generation
1/27/2006 8:54:06 PM INSTEONBASIC Writing new InsteonBasic Error log file - C:\Program Files\HomeSeer 2\Config\INSTEONBASIC Error Report.Log
1/27/2006 8:56:15 PM Info Web Server authorized local login successful from: 192.168.1.106 User: default
In most cases the whole log would help since it has initialization information in it :> but here I can clearly see that the device did not respond in any way to the ping request, it did not send an ACK (that it got the message) and it did not send the requested ping response. This pretty much indicates that the device can not be reached. I do see that 00.48.D4 worked just fine, so everything with the plug-in and SDM seem to be working.
Now I have had instances where I could control a device but it would never respond. Essentially there was just enough signal one way to work but not the other.
As well your log shows a bug that I had to struggle today to fix, in that some ACK messages can look like other types of messages because the ack message follows a competely different message format that can be virtually indestinguishable from a regular message given the right data.
Jon
--------* End Pre-Error Log*--------------Last edited by Oman; January 26, 2006, 10:51 PM.Jon Ort
These devices are literally next to each other. I figure if I try to tap link 0145d7 it will work....
As I tried to do this I realized the D is a 0. Worked like it should, added with no tap link.
Trying to add a second.
Tested it and yep.... It works clean.
Jon, sorry for wasting your time with my typo.
The X10 problem in this thread..... Has been verified to ensure that I am not mistyping addresses!
