Release Notes
    Release Notes
    This thread contains list of improvements introduced with each version.
    v3.0.2.3 - Fixing what appears to be a subtle change to the NEO API in it's interpretation of vital INFO command.
    v3.0.2.2 - Creating function, from config page, to update devices to latest version. Changing battery device value pairs to: 100=Normal, 0=Low Battery
    v3.0.2.1 - Increasing delay to 100msec in INFO read to minimise problems with incomplete packets being received
    v3.0.2.0 - Added support for Battery status for Neo Air thermostats. Configured via the izHeatmiserNEO tab on each thermostat root device (see manual for furhter detail)
    v3.0.1.15 - Better debug messages
    v3.0.1.11 - Improved error message logging
    v3.0.1.10 - Updated to support linux
    v3.0.1.6 - Fix to allow setting hold mode from actions
    v3.0.1.4 - Updated to better support larger systems. Tested and working with 17 zone system
    v3.0.1.2 - Moving NewtonsoftJSON dll to \bin\izHeatmiserNEO directory to avoid clashes with other plug-ins
    v3.0.1.1 - Additional child devices per thermostat including Floor Temperature when additional sensor discovered
    v3.0.1.0 - Improved handling of multiple thermostats and auto-discovery/device creation
    v3.0.0.8 - Improved handling of TCP comms messages on root devices
    v3.0.0.7 - Tidy up on web config page
    v3.0.0.6 - Added ability to set IP address of HUB on settings page
    v3.0.0.5 - Initial release
    Nicolai L
