Int32 value
    Int32 value
    I get all int16 value to read correctly and working.
    I have one value of 1703469,00 that I can't get Homeseer to read.
    Register adress: 0125 = 60866 = Hex EDC2
    Register adress: 0126 = 00259 = Hex 0103
    Hex 0103 EDC2 = Decimal 170346,90
    I have set HS device as Int32 register adress 125.
    Only error in the log and no value.
    Hi Jonas, try checking the "Big Endian" checkbox on the Modbus tab of the gateway device and see if that solves the issue? What error are you getting in your log file?
    Author of Highpeak Plugins | SMS-Gateway Plugin | Blue Iris Plugin | Paradox (Beta) Plugin | Modbus Plugin | Yamaha Plugin
      I have version Modbus Plugin v3.8.6121.22741
      Where can I find the settings
        advanced
        <TABLE cellSpacing=0 width="100%"> <TBODY> <TR> <TD class=tablecell_label align=left>Status</TD> <TD class=tablecell colSpan=9 align=left>-3,21279780651246E+33 = Unknown</TD></TR> <TR> <TD class=tablecell_label align=left>Value</TD> <TD class=tablecell colSpan=9 align=left>-3,21279780651246E+33 </TD></TR></TBODY></TABLE>
          Look at the settings page for the gateway, not the specific register.
            Cant find it
              One more thing Jonas, can you set the multiplier to 1 rather than 0.1 please?
              I think that may be the issue. We're trying to divide an Integer by 10 and that does not produce another integer.
                changed to 1 same problem.
                  You can find the "Big Endian" setting on your Modbus IP Gateway" device settings, in the "Modbus" tab.
                  Also, I checked the code, and you can ignore the multiplier, that only gets applied much later, so that is not the issue here.
                    Found it, same problem.
                      Can you:
                      1. Stop the plugin
                      2. Make a copy of the HSPI_MODBUS.EXE file in your HS3 folder
                      3. Extract the one supplier over the old HSPI_MODBUS.EXE
                      4. Start the plugin and test again (with and without the Big Endian checkbox)
                        Great work, looks fine now.
                          Ok. Bug fix will be in the next release.
