Support for displaying and controling in Celsius?
    When the thermostat and plug-in are configured for Celsius the HS interface makes no mention of current temperature settings (HeatSetPt, CoolSetPt, Current Temperature, etc) that are at 0.5 degree intervals.
    The web plug-in interface: When choosing 22.5 from the select box the HSLog shows that the thermostat is being set to 23. Luckily, tt appears that the thermostat is being set to 22.5 properly.
    The "up" and "down" features always increment in a full degree instead of 0.5 increments. This applies to:
    -Plug-In web page -allows control of 0.5 increments but only shows status rounded up
    -Device (Heat Setpt, CoolSetpt) - Up and Down buttons increase the thermostat by full degrees instead of 0.5 increments.
    -HS Touch built in "ActionsWhenPressed" -> Thermostat -> "Raise or Lower SetPoint" - Up and Down buttons increase by full degrees instead of 0.5 increments.
