Originally posted by drmcp
View Post
Major Upgrade for HomeSeer Amazon Echo Skill!
Originally posted by macromark View PostTry using a complete phrase instead of trying to open a session for each command. In other words, just say (all at once) "Alexa, tell HomeSeer to turn my light on". Don't say "Alexa, tell HomeSeer..." and then wait for a response.
Programming an Event with the Echo and New Skill!
Check it out: http://board.homeseer.com/showthread.php?t=179720
To implement the skill, as opposed to the API, you need to have at at least HS3 version 243.
You also need to have your myHS account set up (a single user is free)
Once this is done, go to the list of skills in your Alexa app.
You'll find the HomeSeer skill there.
Enabling this skill brings up a login that will link the echo to your system through myHS.
Use the username and password you use to gain access to your system through myHS.
You can ask for help through the echo by saying "Ask HomeSeer for help', which will give you the HomeSeer echo url http://www.homeseer.com/echoWade
"I know nothing... nothing!"
Originally posted by Sgt. Shultz View PostTo implement the skill, as opposed to the API, you need to have at at least HS3 version 243.
You can ask for help through the echo by saying "Ask HomeSeer for help', which will give you the HomeSeer echo url http://www.homeseer.com/echoHector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Originally posted by Rotech View PostWade, I have all those steps done. How do I know when I am using the skill and I am using the api? What's the difference? I also read some where that you can change the name of echo other than Alexa and Amazon is this true?
Alexa tell homeseer to turn on my bedroom light = skill
API - on/off/dim and set thermostat
Skill - run events, get statuses, on/off/dim, control and report on most devices.
Alexa/Amazon/Echo are current awake words for the echo - choose one. You can not use an arbitrary word at this time. For my kitchen unit I call echo and my living I call Alexa.
Originally posted by wkomorow View PostAlexa/Amazon/Echo are current awake words for the echo - choose one. You can not use an arbitrary word at this time. For my kitchen unit I call echo and my living I call Alexa.Hector
Win.2003 OS, HS3
