I got two motion detector floodlights and wired the motion detectors to a zwave relay. When motion is sensed it trips the relay and turns on the light. I can also turn the light on and off remotely using hSTouch to trigger the relay. I wanted both floodlights to go on whenever one was triggered so I programmed my Zee2 so that if the state of motion detector light 1 changed to on it would trigger light 2 to go on. It works perfectly if I turn light 1 on remotely but it does not work if light 1 turns on because motion is detected.
I thought that if the motion detector triggered the relay the controller would pick up the changed state of the light and turn on the second light just like if I turned light 1 on manually but it doesn't. Can anyone tell me why this does not work and what I can do to get it to work?
