My mistake I misread the post
Omni connection issue
Curious what the difference is between the EU UK English version of the Omni Panel versus the US version?- Pete
Yeah I thought the firmware was identical as there is limited programming space on those flash chips and the HW ID was utilized more for localization.
You mention Frequency. Is this related to the 24Volts AC used for powering the bus?
Wow reading now it was incorporated in 2015 - 2 years ago - there are some major differences between the Omni panel here in the US and that using EN50131 compliance.
The EN50131 versions include special features not found in the standard Omni control systems, such as controller enclosures that include required tamper switches, ensuring the door remains closed and that the enclosure remains installed against a solid surface. Additionally, the ENTMP- 9EU is now used with existing Omni security consoles as a tamper indicator. Additional special features in the EN50131 versions include:
- Double end of line resistors for tamper detection
- New arming/ disarming methods
- Shunt lock incorporation
- Confirmed alarms for police response
- Temporary lockout when entering an invalid code
- Enhanced event log
- User authorized firmware updates
- Entry/exit follower
- Adjustment to security code usage and visibility
How do you do a double end of line resistor?
Personally thought only the installer code was used for a firmware update.
Here utilize HAI keypads / HAI Omnitouch screens (serial and IP) and never noticed any tamper stuff.
Noticed only the adds here in the firmware of the HAI Email board, Omnitouch 7 screens and a redo of the CCTV stuff.- Pete
Yea it a big difference, regards to the double resister
When the sesnor is secure and no tamper is triggered, the current flows straight throught the 1K resitor and back to the panel. This is secure. If the PIR detects motion then the Alarm contact opens and the circuit becomes open circuit which is infinite resistance which is an alarm state. If the temper trips then it forces the current through the 2.7K resistor aswell as the 1K resistor giving it a total of 3.7K Ohms which is a tamper state.
Ahh...
Yes here utilize one 1K ohm resistor at the end of every Zone run. Never seen the use of a 2.7K ohm resister and 1K ohm resistor. Door switches / PIRs are all the same. Temperature / Humidity sensors do not have end 1K Ohm resistors. I have them installed on the negative side of the zone. All of the zone values are the same when looking at the status. Secure loop value is 148. What is the loop value with two resistors?
I had a door stretch and pull on the wires causing a tamper state a few years ago. I had pulled the wires a bit too tight. Fixing it was a PITA.- Pete
Yea the loop value is still the same with two resistors when secure and when not ready the value is 253, think tamper is 164.
rmasonjr could you tell me if its possible to have the source code updated with the EU model names in so that they are recognised be the system? In doing this hopefully we will get control of all but the security side.
Yeah, I opened a ticket with Leviton and havent heard back. The EU models are not in the SDK for some reason. If they can give me the panel types for EU, I can add them easily.
I'll ping them for an update.HS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Unfortunately, EU panels cannot be supported by the plugin. I had a discussion with Leviton and it's just not possible due to EU regulations.
I had HST update the plugin website to note this.
RobHS4Pro on a Raspberry Pi4
Hi, rmasonjr Have you had any look installing thesource code updated with the EU model names yet?? Ive had the same issue with Myro control they asked for my firmware which is 4.0b plus PC access version 3.17.0.843. they said all they had to do was to make sure they had referenced all the available variants of the Omni’s. They have since fixed the issue and are just waiting on apples approval of the app. in the mean time they have sent me a test flight app which works fine. Hope this helps
Originally posted by peterborg View PostHi, rmasonjr Have you had any look installing thesource code updated with the EU model names yet?? Ive had the same issue with Myro control they asked for my firmware which is 4.0b plus PC access version 3.17.0.843. they said all they had to do was to make sure they had referenced all the available variants of the Omni’s. They have since fixed the issue and are just waiting on apples approval of the app. in the mean time they have sent me a test flight app which works fine. Hope this helps
That said, you can try the plugin and some pieces might work, but it is not officially supported.HS4Pro on a Raspberry Pi4
