Soil moisture sensor supported
    This soil moisture sensor is supported in HS3 version 30.0.0.21 and RFXtrx433E-FW226, RFXtrx433-FW76/176, RFXrec433 FW76
    http://www.ebay.com/itm/Wireless-Soi...item3a8778244b
    Thanks Bert, are multiple sensors supported? If so, what's the max number?
    Al
      The sensor has 3 channels and no other ID, so max 3 sensors.
      I don't know the quality of the sensor but the transmit range is limited to about 5 meter with 1 wall in between. Maybe you can increase the range by replacing the coil antenna by a 17.5cm wire antenna. Drill a 1mm hole and use silicon to make the enclosure water tight at that point.
          Anyone know whether it's a capacitive SMS, or some other technology for measuring soil moisture?
            Specs are here: http://store.imagintronix.com/pm100_...oisture_sensor
            Says it's capacitive. In your testing/research is that the best kind to get?
            Cheers
            Al
              Cheers
              Al
              If you want a simple answer, then for inexpensive soil moisture sensors, I would say yes. If you want a more complete answer, there are a lot of qualifiers you can read on the other thread, but in general capacitive sensors avoid a lot of the pitfalls that come with inexpensive soil moisture sensors that work by measuring electrical resistance. Given the low price, and RFXCOM reception, it's probably worth a try.
              Is it at 433Mhz? I didn't see its RF frequency in the specs. I have the rfxcom433rec.
                Thanks. Yes, it's 433 and will work with your RFXCom (under HS3 at least). It'll work with this console as well: http://www.ebay.com/itm/Wireless-Soi...item3a87780f9f
                Cheers
                Al
                  Bought one to try it out. Will post the results.
                  I own the license for HS3PRO, but I haven't yet migrated. Oh well. I arrived at the tail end of HS2PRO, so I guess I'll be waiting more or less indefinitely to get plug-ins. It's a known quandary with no solution.
                  Which plugins are you waiting for? I was going to wait for a while, but the new features in the RFXCom, SqueezeBox, and other plugins caused me to push the migration through. I still have HS2 running, but I've migrated about 95% of the functionality to HS3 and hope to shut it off by the end of June.
                  Cheers
                  Al
                    Does this work with ACRF-2? The oregon sensors do...
                      This sensor is not an Oregon sensor and only supported by the RFXtrx/RFXrec and the RFXCOM HS3 plug-in.
                        has anyone tired these? i am considering getting 3 of them
                        HS3 Pro on Windows 8 64bit
                        53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
                        Check out my electronics blog here:
                        https://www.facebook.com/RaptorsIrrationalInventions
                          I'm waiting for the one I ordered to show up. I expect it early next week and will post an update towards the end of next week.
                          Cheers
                          Al
                            Hello
                            I have 2 of them and working fine
                            range is not so great but with a little modify i have a range of about
                            15 meters.
                            Ed
                              15 meters.
                              Hi Ed,
                              What kind of modification did you make?
                              Al
