notice yhat the kinect stop working. I restarted PI and got this errorwhat can I do?:
Jul-11 10:14:50 AM Plug-In Finished initializing plug-in Kinect
Jul-11 10:14:47 AM Info Plugin Kinect with instance: has disconnected
Jul-11 10:14:47 AM Error Initializing plug-in(1): Kinect Instance::System.IO.IOException: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Logs\Kinect.txt' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append) at System.IO.File.AppendText(String path) at HSPI_KINECT.Logger.Init() at HSPI_KINECT.KinectApp.Init()
Jul-11 10:14:47 AM Kinect ERROR System.IO.IOException: The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Logs\Kinect.txt' because it is being used by another process. at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost) at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost) at System.IO.StreamWriter..ctor(String path, Boolean append) at System.IO.File.AppendText(String path) at HSPI_KINECT.Logger.Init() at HSPI_KINECT.KinectApp.Init()
Jul-11 10:14:46 AM Info Plugin Kinect has connected. IP:127.0.0.1:63032
