after update Kinects no longer work
    No matter what I do. I can not get them to work anymore... I have re copied all the files..
    removed plugin. reinstalled..
    Not sure where to go with this...
    Is there anyway to make this more stable?
    if you want some help, please provide more details.
    what's not working? does the plugin start? can you provide some logs? do you get any error message? Do you run a local instance or a remote instance of the plugin? multiple instances? what version?
    thanks
      thanks
      3 kinects currently 2 remote 1 local. none work. They show up. everything looks like its right... they just do nothing now. No errors in the event log.
      I did when the update happen. that's how I found out to copy the new files..
        - from the config page set the log level to Trac
        - shut down all your kinect instances
        - in task manager make sure there is no HSPI_Kinect.exe running, if there is some, kill them
        - start the local instance only
        - try to say a command (I'm assuming you are using the VR and this is what doesn't work)
        - post your logs here
        thanks
          thanks
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5350602 Y=-0.2758507 Z=1.03745
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5280217 Y=-0.2655044 Z=1.046761
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5289469 Y=-0.2458587 Z=1.060024
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5303462 Y=-0.2314101 Z=1.070029
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5323133 Y=-0.216534 Z=1.077083
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5350063 Y=-0.2011547 Z=1.085111
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5375312 Y=-0.1904658 Z=1.092752
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5402608 Y=-0.1787125 Z=1.101775
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5443323 Y=-0.1642677 Z=1.113979
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5452798 Y=-0.1547615 Z=1.122258
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5442466 Y=-0.1435556 Z=1.129629
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5405836 Y=-0.1363564 Z=1.134339
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5346851 Y=-0.1307837 Z=1.138352
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5292947 Y=-0.1176205 Z=1.143124
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5264091 Y=-0.1033704 Z=1.149011
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5213125 Y=-0.08848677 Z=1.156428
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.5153278 Y=-0.06735695 Z=1.164592
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.508184 Y=-0.04725971 Z=1.178475
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.4987395 Y=-0.03000319 Z=1.199451
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.4822839 Y=-0.0229998 Z=1.223479
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.4494155 Y=-0.004857219 Z=1.246078
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.4196809 Y=-0.01062592 Z=1.259527
          Oct-10 08:52:58 Kinect TRACE TrackedX=0.3820091 Y=0.000558658 Z=1.26196
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.3055613 Y=0.07410455 Z=1.240722
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.2777024 Y=0.07611055 Z=1.246082
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.2606423 Y=0.07474353 Z=1.255501
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.2432552 Y=0.07367652 Z=1.261935
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.22705 Y=0.07411994 Z=1.266795
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.2108943 Y=0.07304139 Z=1.272172
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.19773 Y=0.07258542 Z=1.275696
          Oct-10 08:52:57 Kinect TRACE STABLE
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1870521 Y=0.07141007 Z=1.280439
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1791514 Y=0.07056467 Z=1.283014
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.171478 Y=0.07312392 Z=1.28607
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1637322 Y=0.06922315 Z=1.288889
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1556316 Y=0.06793491 Z=1.290518
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1510527 Y=0.06725573 Z=1.292096
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1480072 Y=0.06534908 Z=1.294211
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1449024 Y=0.06823264 Z=1.294878
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1432434 Y=0.06619036 Z=1.296757
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1428555 Y=0.06721506 Z=1.296934
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1422481 Y=0.06721331 Z=1.298663
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1413777 Y=0.06506839 Z=1.298456
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1423433 Y=0.06459605 Z=1.299007
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1408454 Y=0.06534915 Z=1.298389
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1410865 Y=0.06649034 Z=1.29842
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1410614 Y=0.06549118 Z=1.298647
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1415226 Y=0.06397102 Z=1.299075
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1415711 Y=0.06671514 Z=1.298737
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1420555 Y=0.06556042 Z=1.299304
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1396103 Y=0.0660715 Z=1.299531
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1411777 Y=0.06466263 Z=1.300113
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1409372 Y=0.06566467 Z=1.300097
          Oct-10 08:52:57 Kinect TRACE TrackedX=0.1411553 Y=0.06610032 Z=1.300321
          Oct-10 08:52:56 Kinect TRACE STABLE
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1423388 Y=0.06601309 Z=1.300682
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1419012 Y=0.06614039 Z=1.300698
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1424034 Y=0.06523041 Z=1.301118
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1416119 Y=0.06477242 Z=1.301154
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1415966 Y=0.06539866 Z=1.301356
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1412593 Y=0.06395026 Z=1.301737
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1404873 Y=0.06556995 Z=1.300408
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1397404 Y=0.0655475 Z=1.301612
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1413227 Y=0.06521494 Z=1.302174
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1402701 Y=0.06607078 Z=1.301543
          Oct-10 08:52:56 Kinect TRACE Phrase rejected =
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1417092 Y=0.06596792 Z=1.302305
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1402455 Y=0.06659208 Z=1.301387
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1393826 Y=0.06515345 Z=1.30143
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1404093 Y=0.06610951 Z=1.30165
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1407698 Y=0.06432723 Z=1.301982
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1416982 Y=0.06667621 Z=1.301559
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1395757 Y=0.0661136 Z=1.299984
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1397941 Y=0.06647274 Z=1.299484
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1398512 Y=0.06668258 Z=1.299738
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.139063 Y=0.06612694 Z=1.298412
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.138511 Y=0.06523595 Z=1.297049
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1387228 Y=0.06582683 Z=1.29713
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1397738 Y=0.06532729 Z=1.296586
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1381709 Y=0.06645326 Z=1.2952
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1395885 Y=0.06598583 Z=1.294857
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1388214 Y=0.06576902 Z=1.293812
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1370574 Y=0.06530756 Z=1.292765
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1371485 Y=0.06676233 Z=1.292442
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1367492 Y=0.06743854 Z=1.292244
          Oct-10 08:52:56 Kinect TRACE TrackedX=0.1360226 Y=0.06978562 Z=1.29057
          Oct-10 08:52:55 Kinect TRACE STABLE
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.135661 Y=0.06864852 Z=1.289433
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1353523 Y=0.06887941 Z=1.288204
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1357383 Y=0.06905026 Z=1.288403
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1332204 Y=0.06866874 Z=1.286804
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1343676 Y=0.06897152 Z=1.286631
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1328723 Y=0.06914987 Z=1.285837
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.132277 Y=0.06819779 Z=1.285127
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1314286 Y=0.06835701 Z=1.283958
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1302154 Y=0.07007201 Z=1.283087
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1321482 Y=0.070891 Z=1.282407
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.130578 Y=0.06947054 Z=1.281192
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1312417 Y=0.06925754 Z=1.280885
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.129649 Y=0.06878623 Z=1.279459
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1293804 Y=0.0681935 Z=1.279055
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1273633 Y=0.06875775 Z=1.279838
          Oct-10 08:52:55 Kinect TRACE Phrase hypothesized = computer what is the weather, Confidence=0.6207125
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1270513 Y=0.06915338 Z=1.280031
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1273373 Y=0.06870583 Z=1.280577
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1275096 Y=0.06807064 Z=1.281273
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1272594 Y=0.06902809 Z=1.281632
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1268406 Y=0.06947001 Z=1.282809
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1233299 Y=0.06934594 Z=1.282227
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1223089 Y=0.06739689 Z=1.283372
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1240108 Y=0.06612948 Z=1.284799
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1244126 Y=0.06562481 Z=1.284869
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.123059 Y=0.06505709 Z=1.285725
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1236117 Y=0.06449732 Z=1.285695
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1246603 Y=0.06653144 Z=1.286034
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1232635 Y=0.06533138 Z=1.285283
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1227972 Y=0.064449 Z=1.285274
          Oct-10 08:52:55 Kinect TRACE Phrase hypothesized = computer what is the, Confidence=0.6899103
          Oct-10 08:52:55 Kinect TRACE TrackedX=0.1251439 Y=0.06645001 Z=1.286206
          Oct-10 08:52:54 Kinect TRACE STABLE
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.123843 Y=0.0664953 Z=1.285692
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.124352 Y=0.06620473 Z=1.286453
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1243836 Y=0.06531937 Z=1.286758
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1247156 Y=0.06401283 Z=1.286139
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1238988 Y=0.06565787 Z=1.286445
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1253414 Y=0.06568018 Z=1.286
          Oct-10 08:52:54 Kinect TRACE Phrase hypothesized = computer what is, Confidence=0.7864644
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1261198 Y=0.06717827 Z=1.286387
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1255299 Y=0.06565601 Z=1.285932
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1249048 Y=0.06657515 Z=1.2853
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1254276 Y=0.06551754 Z=1.285991
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1240311 Y=0.06523997 Z=1.28607
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1229535 Y=0.0642505 Z=1.284677
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1260859 Y=0.06573269 Z=1.286219
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.126551 Y=0.06558555 Z=1.285796
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1257181 Y=0.06550469 Z=1.285628
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1248155 Y=0.0659163 Z=1.284901
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1260596 Y=0.06511934 Z=1.284966
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1236401 Y=0.06458713 Z=1.284582
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1244741 Y=0.0657891 Z=1.283946
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1251265 Y=0.06400648 Z=1.283675
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1252151 Y=0.06531848 Z=1.283832
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.124189 Y=0.06346554 Z=1.28398
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1233098 Y=0.065373 Z=1.283216
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1237874 Y=0.06646406 Z=1.283291
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1260045 Y=0.06569807 Z=1.283083
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1258668 Y=0.06458951 Z=1.282479
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1245294 Y=0.06313794 Z=1.28149
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1275346 Y=0.06377918 Z=1.282083
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1257622 Y=0.06408036 Z=1.28091
          Oct-10 08:52:54 Kinect TRACE TrackedX=0.1249767 Y=0.06457669 Z=1.27971
          Oct-10 08:52:53 Kinect TRACE STABLE
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1246472 Y=0.06544529 Z=1.279813
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1251344 Y=0.06584547 Z=1.27944
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1247071 Y=0.06418154 Z=1.278067
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1254851 Y=0.06585689 Z=1.277161
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1259503 Y=0.06530782 Z=1.276221
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1262295 Y=0.06630179 Z=1.275185
          Oct-10 08:52:53 Kinect TRACE Phrase hypothesized = computer, Confidence=0.01522845
          Oct-10 08:52:53 Kinect TRACE Speech Detected:
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.126514 Y=0.06715147 Z=1.274491
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1261916 Y=0.0669236 Z=1.274204
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1259474 Y=0.06733813 Z=1.273553
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1248014 Y=0.06719648 Z=1.271851
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1259148 Y=0.06648267 Z=1.271453
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1263276 Y=0.0669388 Z=1.270561
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1256498 Y=0.0679685 Z=1.269677
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1257738 Y=0.06727508 Z=1.269336
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1263517 Y=0.06855448 Z=1.268437
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.126955 Y=0.06914712 Z=1.268239
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1272779 Y=0.06852405 Z=1.268642
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1261411 Y=0.07076567 Z=1.268286
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1270178 Y=0.06917625 Z=1.269146
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1256035 Y=0.07015902 Z=1.269497
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1277439 Y=0.06857622 Z=1.270522
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1270973 Y=0.06746569 Z=1.270726
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1283518 Y=0.06758392 Z=1.272906
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1277041 Y=0.06711852 Z=1.273656
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1273687 Y=0.06990653 Z=1.275432
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1287756 Y=0.06964705 Z=1.277248
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1271895 Y=0.0693075 Z=1.277604
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1279411 Y=0.06930596 Z=1.279055
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1292544 Y=0.07064194 Z=1.279119
          Oct-10 08:52:53 Kinect TRACE TrackedX=0.1277217 Y=0.07018542 Z=1.279583
          Oct-10 08:52:52 Kinect TRACE STABLE
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1281244 Y=0.06957444 Z=1.279795
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1275315 Y=0.07087498 Z=1.280926
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1261196 Y=0.06958696 Z=1.280731
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1252052 Y=0.06812542 Z=1.281104
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1262551 Y=0.06919598 Z=1.281946
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1259546 Y=0.06868295 Z=1.283348
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1260617 Y=0.06812407 Z=1.283046
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1256856 Y=0.06585835 Z=1.283382
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1254414 Y=0.06853657 Z=1.284748
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1242667 Y=0.06834747 Z=1.286267
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1240914 Y=0.06907663 Z=1.286749
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.120801 Y=0.07031175 Z=1.285859
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1234108 Y=0.07074256 Z=1.287592
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1232113 Y=0.07093729 Z=1.287826
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1213721 Y=0.07085779 Z=1.288127
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1215477 Y=0.0691379 Z=1.287777
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1205461 Y=0.06966375 Z=1.287954
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1214133 Y=0.06876682 Z=1.28747
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1197833 Y=0.07005427 Z=1.287886
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1210301 Y=0.06856936 Z=1.2864
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1218194 Y=0.06944357 Z=1.28713
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1227333 Y=0.06811592 Z=1.28518
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1255906 Y=0.0680149 Z=1.285451
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1259408 Y=0.07067988 Z=1.28431
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1267586 Y=0.06840917 Z=1.282479
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1296961 Y=0.06999508 Z=1.28154
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1358603 Y=0.06893627 Z=1.280252
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1368328 Y=0.06912331 Z=1.278614
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1424733 Y=0.0689261 Z=1.276157
          Oct-10 08:52:52 Kinect TRACE TrackedX=0.1468541 Y=0.06897017 Z=1.273045
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.1552297 Y=0.07002134 Z=1.271857
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.1659179 Y=0.0712496 Z=1.267926
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.1718284 Y=0.06977837 Z=1.266194
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.1832963 Y=0.07110806 Z=1.262731
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.1951437 Y=0.07074774 Z=1.260106
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.2098246 Y=0.07133015 Z=1.256963
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.2376924 Y=0.04694303 Z=1.253923
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.2764217 Y=0.01639502 Z=1.249524
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.3117795 Y=-0.002334813 Z=1.242049
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.3382569 Y=-0.01394924 Z=1.235487
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.3572587 Y=-0.002755477 Z=1.234739
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.3798167 Y=0.00689586 Z=1.234699
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.4008009 Y=0.01665718 Z=1.234204
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.4247111 Y=0.02815141 Z=1.228941
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.4467126 Y=0.01341918 Z=1.222025
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.4675261 Y=0.001098844 Z=1.21312
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.4855583 Y=-0.01168006 Z=1.20691
          Oct-10 08:52:51 Kinect TRACE TrackedX=0.5000812 Y=-0.02277616 Z=1.2035
          Oct-10 08:52:51 Kinect TRACE PositionOnlyX=0.5141022 Y=-0.02658631 Z=1.19953
          Oct-10 08:52:51 Kinect TRACE PositionOnlyX=0.5239367 Y=-0.027381 Z=1.195808
          Oct-10 08:52:50 Z-Wave Device: Kitchen House Motion Sensor Set to On/Open/Motion
          Oct-10 08:52:48 Z-Wave Device: Living Room House Sensor Binary Reserved Set to On/Open/Motion
          Oct-10 08:52:25 Event Event Trigger "Lighting Living Room Lights OFF by NO Motion"
          Oct-10 08:52:25 Z-Wave Device: Living Room House Sensor Binary Reserved Set to Off/Closed/No Motion
          Oct-10 08:52:13 Z-Wave Device: Kitchen House Motion Sensor Set to Off/Closed/No Motion
          Oct-10 08:52:01 Z-Wave Device: Energy House Amperes 2 Set to 10.046 (10.046 Amperes)
          Oct-10 08:52:01 Z-Wave Device: Energy House Amperes 1 Set to 4.415 (4.415 Amperes)
          Oct-10 08:52:01 Z-Wave Device: Energy House Volts 2 Set to 124.508 (124.508 Volts)
          Oct-10 08:52:01 Z-Wave Device: Energy House Volts 1 Set to 124.508 (124.508 Volts)
          Oct-10 08:51:48 Kinect DEBUG Speech Recognition Started
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to Off
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to Low
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to Medium
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to High
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to Off
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to Low
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to Medium
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to High
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Virtual] [System] Master Bedroom Motion Control to On
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Virtual] [System] Master Bedroom Motion Control to Off
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] [House] Door Lock to Lock
          Oct-10 08:51:48 Kinect DEBUG Rule (Devices) set [the] [Living Room] [House] Door Lock to Unlock
          Oct-10 08:51:48 Kinect DEBUG Rule: [] [] [the] [ days] [] []
          Oct-10 08:51:48 Kinect DEBUG Ruleget|tell|check|whats|what is) (me|the|this)* (todays|tonights|tomorrows|sundays|mondays|tuesdays|wednesda ys|thursdays|fridays|saturdays|next) (two|three|four|five)* (days)* (temperature|weather|forecast) (for|in)* (Willis Ranch)*
          Oct-10 08:51:48 Kinect DEBUG Rule:Turn TV
          Oct-10 08:51:48 Kinect DEBUG Building Grammars
          Oct-10 08:51:48 Kinect DEBUG Speech Recognition Stopped
          Oct-10 08:51:48 Kinect DEBUG Reloading Grammars
          Oct-10 08:51:29 Blue-Iris Refreshing data from Blue Iris server
          Oct-10 08:51:29 Blue-Iris Successfully logged in to BlueIris server: Willis Ranch (ver 4.1.9.2) as Admin.
          Oct-10 08:51:01 Z-Wave Device: Energy House Amperes 2 Set to 9.645 (9.645 Amperes)
          Oct-10 08:51:01 Z-Wave Device: Energy House Amperes 1 Set to 4.43 (4.43 Amperes)
          Oct-10 08:51:01 Z-Wave Device: Energy House Volts 2 Set to 124.708 (124.708 Volts)
          Oct-10 08:51:01 Z-Wave Device: Energy House Volts 1 Set to 124.708 (124.708 Volts)
          Oct-10 08:50:01 Z-Wave Device: Energy House Amperes 2 Set to 10.018 (10.018 Amperes)
          Oct-10 08:50:01 Z-Wave Device: Energy House Amperes 1 Set to 4.421 (4.421 Amperes)
          Oct-10 08:50:01 Z-Wave Device: Energy House Volts 2 Set to 124.55 (124.55 Volts)
          Oct-10 08:50:01 Z-Wave Device: Energy House Volts 1 Set to 124.55 (124.55 Volts)
          Oct-10 08:49:36 Z-Wave Device: Kitchen House Temperature Set to 71.9 (F)
          Oct-10 08:49:36 Z-Wave Device: Kitchen House Luminance Set to 232 (Lux)
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5408794 Y=-0.2353759 Z=1.032228
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5256522 Y=-0.232024 Z=1.032246
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5158824 Y=-0.2238238 Z=1.030859
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5093973 Y=-0.203179 Z=1.024976
          Oct-10 08:49:12 Kinect TRACE Phrase rejected =
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5048528 Y=-0.1934412 Z=1.024146
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5069298 Y=-0.1842634 Z=1.030606
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5083093 Y=-0.1760092 Z=1.03555
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5100388 Y=-0.1705811 Z=1.042647
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5119342 Y=-0.1684751 Z=1.049714
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5149502 Y=-0.163571 Z=1.058255
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5167916 Y=-0.1593057 Z=1.065824
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5168245 Y=-0.1545136 Z=1.071253
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5155728 Y=-0.1528703 Z=1.073258
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5123679 Y=-0.1473978 Z=1.073298
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.5060037 Y=-0.1400305 Z=1.071015
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4985011 Y=-0.1314395 Z=1.066887
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4898292 Y=-0.1264665 Z=1.062246
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4788982 Y=-0.1203508 Z=1.056774
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4646338 Y=-0.1047696 Z=1.046002
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4510389 Y=-0.09155358 Z=1.041752
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4348815 Y=-0.07025944 Z=1.034672
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.4158256 Y=-0.04350393 Z=1.024747
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.3872429 Y=-0.00968523 Z=1.008751
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.3561375 Y=0.02947008 Z=0.9889629
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.3259071 Y=0.0503111 Z=0.9694474
          Oct-10 08:49:12 Kinect TRACE TrackedX=0.3011184 Y=0.0576088 Z=0.9558007
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.2827688 Y=0.06621911 Z=0.9451122
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.2622855 Y=0.07009677 Z=0.9371349
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.2393138 Y=0.07163616 Z=0.9297213
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.2191916 Y=0.07436879 Z=0.9241412
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1996649 Y=0.07473176 Z=0.9196205
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1800758 Y=0.0760632 Z=0.9146326
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1639181 Y=0.07745162 Z=0.9112896
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1496196 Y=0.08002772 Z=0.9075351
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1343093 Y=0.08047755 Z=0.9051952
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1203203 Y=0.08214835 Z=0.9031354
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.1099212 Y=0.08338082 Z=0.9031324
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.09685747 Y=0.08508138 Z=0.9031431
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.08744553 Y=0.08720722 Z=0.9032413
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.07714865 Y=0.08926051 Z=0.9053445
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.06825487 Y=0.09121946 Z=0.9082669
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.0585374 Y=0.09309854 Z=0.9122393
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.05155222 Y=0.09497957 Z=0.9146247
          Oct-10 08:49:11 Kinect TRACE Phrase hypothesized = computer what is me forecast, Confidence=0.7978526
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.04245823 Y=0.0969873 Z=0.9178936
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.03938063 Y=0.09722565 Z=0.9246746
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.03365025 Y=0.09687434 Z=0.9278995
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02932616 Y=0.09768645 Z=0.9309354
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.0266596 Y=0.09803011 Z=0.9326485
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02575885 Y=0.09948094 Z=0.9357894
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02485504 Y=0.1002077 Z=0.9368222
          Oct-10 08:49:11 Kinect TRACE Phrase hypothesized = computer what is the weather for, Confidence=0.7500698
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02468119 Y=0.09882693 Z=0.9397613
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02551393 Y=0.09864162 Z=0.9411824
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02600055 Y=0.09723155 Z=0.9421108
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02639947 Y=0.09807873 Z=0.9440734
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02696925 Y=0.09792159 Z=0.9451655
          Oct-10 08:49:11 Kinect TRACE TrackedX=0.02573035 Y=0.09854943 Z=0.9459358
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02656112 Y=0.09717628 Z=0.9472939
          Oct-10 08:49:10 Kinect TRACE Phrase hypothesized = computer what is me, Confidence=0.7238114
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02682659 Y=0.09712584 Z=0.9482234
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02725502 Y=0.09839157 Z=0.9493027
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02771742 Y=0.09790098 Z=0.9509746
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02520066 Y=0.09963867 Z=0.9511427
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02488335 Y=0.09884965 Z=0.9520726
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02461545 Y=0.09875499 Z=0.9523184
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02578687 Y=0.1001479 Z=0.9525813
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02461694 Y=0.1001516 Z=0.9522803
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02345702 Y=0.1001219 Z=0.9521756
          Oct-10 08:49:10 Kinect TRACE Phrase hypothesized = computer what is the, Confidence=0.8677307
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02450254 Y=0.09931701 Z=0.950785
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02430486 Y=0.09810574 Z=0.9490673
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02546977 Y=0.0993223 Z=0.9490911
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02518696 Y=0.09760135 Z=0.9486609
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02648395 Y=0.09838884 Z=0.9477908
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02713785 Y=0.09685083 Z=0.9472401
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02729817 Y=0.09800784 Z=0.9459838
          Oct-10 08:49:10 Kinect TRACE Phrase hypothesized = computer what is, Confidence=0.9175057
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02815691 Y=0.09731597 Z=0.9459107
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02731885 Y=0.09672724 Z=0.9465904
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02769933 Y=0.09656464 Z=0.9473178
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02603395 Y=0.09534349 Z=0.9476962
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02641097 Y=0.09704567 Z=0.9486209
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02689924 Y=0.09620926 Z=0.9502162
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02644279 Y=0.09636619 Z=0.9508045
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02562958 Y=0.09496773 Z=0.950839
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02818422 Y=0.09652348 Z=0.9523866
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02797717 Y=0.09652305 Z=0.9528328
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02809521 Y=0.09629964 Z=0.9529333
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02925744 Y=0.09538665 Z=0.9536608
          Oct-10 08:49:10 Kinect TRACE TrackedX=0.02940863 Y=0.09691492 Z=0.9548982
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.0282661 Y=0.09717166 Z=0.9558003
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02889011 Y=0.09637821 Z=0.9571913
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02966153 Y=0.09641439 Z=0.9585044
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02796083 Y=0.09671555 Z=0.9576643
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02652241 Y=0.09658525 Z=0.9577516
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02856429 Y=0.09528565 Z=0.9580747
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02611507 Y=0.09586116 Z=0.9568349
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02761823 Y=0.09569503 Z=0.9569302
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02570499 Y=0.09656906 Z=0.9566534
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02588211 Y=0.09667604 Z=0.9557303
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02491996 Y=0.0968674 Z=0.9552422
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02555602 Y=0.09658793 Z=0.9550962
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02502965 Y=0.09715197 Z=0.9541434
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02247988 Y=0.09750021 Z=0.9529097
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02152035 Y=0.09675802 Z=0.9519387
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02070708 Y=0.09687789 Z=0.9503644
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01978046 Y=0.09794883 Z=0.94994
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01880801 Y=0.09723327 Z=0.9492428
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01905742 Y=0.09770526 Z=0.9476851
          Oct-10 08:49:09 Kinect TRACE Phrase hypothesized = computer, Confidence=0.01512241
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01774805 Y=0.09848004 Z=0.9464883
          Oct-10 08:49:09 Kinect TRACE Speech Detected:
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01906831 Y=0.0983242 Z=0.9447968
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01767519 Y=0.09843516 Z=0.9423552
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01774474 Y=0.0995859 Z=0.9403342
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01812778 Y=0.09800902 Z=0.9388812
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01882212 Y=0.09848431 Z=0.936732
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01839105 Y=0.09922607 Z=0.9359221
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.01972364 Y=0.09801871 Z=0.9352316
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.0201759 Y=0.09772427 Z=0.9337235
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02125756 Y=0.09832615 Z=0.9320936
          Oct-10 08:49:09 Kinect TRACE TrackedX=0.02169201 Y=0.09766736 Z=0.9318301
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.02258969 Y=0.09748322 Z=0.9311411
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.02402594 Y=0.09588137 Z=0.929957
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.02498887 Y=0.0962979 Z=0.9307783
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.02672169 Y=0.09797518 Z=0.9299352
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.02890745 Y=0.09670188 Z=0.9320171
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.02979442 Y=0.09660307 Z=0.9340475
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.0304378 Y=0.09803259 Z=0.9354994
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03131528 Y=0.0974449 Z=0.9382877
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03098745 Y=0.09781885 Z=0.9426097
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03158031 Y=0.09862059 Z=0.9460434
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03251373 Y=0.09911114 Z=0.9498076
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03334514 Y=0.09938316 Z=0.9534679
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.0340486 Y=0.1006212 Z=0.9568986
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03386715 Y=0.0995101 Z=0.9586791
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03367231 Y=0.09974588 Z=0.9607967
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03493518 Y=0.09972241 Z=0.961915
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03765411 Y=0.1001011 Z=0.963454
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.03861207 Y=0.09964341 Z=0.9638749
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04030972 Y=0.1003961 Z=0.963659
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04154866 Y=0.100057 Z=0.9621614
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04276702 Y=0.09937717 Z=0.961291
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04356073 Y=0.09985498 Z=0.9610697
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04403411 Y=0.1001558 Z=0.9609976
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04658927 Y=0.0995774 Z=0.9612498
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04761935 Y=0.09917581 Z=0.9604573
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04918584 Y=0.09960125 Z=0.9600752
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.0495575 Y=0.09905763 Z=0.9603453
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.04908868 Y=0.09806018 Z=0.9589853
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.05128834 Y=0.09832932 Z=0.9596503
          Oct-10 08:49:08 Kinect TRACE TrackedX=0.0497864 Y=0.09789561 Z=0.9588433
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04947716 Y=0.09796666 Z=0.9589676
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04917014 Y=0.09917478 Z=0.9593759
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04975921 Y=0.09820251 Z=0.9590817
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.0483124 Y=0.09851891 Z=0.9588691
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04788148 Y=0.09925053 Z=0.9578624
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04710601 Y=0.1005959 Z=0.957939
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04704085 Y=0.1002947 Z=0.9564623
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04851283 Y=0.09983305 Z=0.9556153
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04860832 Y=0.1005941 Z=0.953456
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04871222 Y=0.1003698 Z=0.9507011
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.0485719 Y=0.100441 Z=0.9472664
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04789359 Y=0.1001207 Z=0.9433849
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04674311 Y=0.1002316 Z=0.939225
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.04832388 Y=0.09928105 Z=0.9358062
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05083167 Y=0.09992046 Z=0.9329442
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05045706 Y=0.1005816 Z=0.9284206
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05168572 Y=0.09965616 Z=0.924516
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05324926 Y=0.1008245 Z=0.9218135
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05346022 Y=0.09939819 Z=0.9205556
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05163473 Y=0.1012347 Z=0.9194246
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05258447 Y=0.1010603 Z=0.9218205
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05662753 Y=0.1002335 Z=0.9291949
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05704302 Y=0.1000242 Z=0.935762
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05624757 Y=0.1017273 Z=0.9427387
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05651964 Y=0.1014558 Z=0.949401
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05623642 Y=0.101895 Z=0.9565634
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05516719 Y=0.1034206 Z=0.9610489
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05358191 Y=0.1026346 Z=0.9644844
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05258596 Y=0.1019961 Z=0.967074
          Oct-10 08:49:07 Kinect TRACE TrackedX=0.05172329 Y=0.1053728 Z=0.9697668
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04988134 Y=0.1062785 Z=0.9703004
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04562315 Y=0.1063456 Z=0.9722912
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04454613 Y=0.1049486 Z=0.9753418
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04422561 Y=0.1012205 Z=0.9810692
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.0435351 Y=0.09915527 Z=0.9856409
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04378881 Y=0.0980435 Z=0.9921291
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04322727 Y=0.09627452 Z=0.9965479
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04388367 Y=0.09683582 Z=0.9999886
          Oct-10 08:49:06 Kinect TRACE STABLE
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04560363 Y=0.09361696 Z=1.00079
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04564903 Y=0.09233487 Z=1.000426
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04706308 Y=0.09482643 Z=0.9981782
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04796023 Y=0.09669377 Z=0.9940612
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04700646 Y=0.101227 Z=0.9886955
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04512419 Y=0.1045386 Z=0.9829265
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04384796 Y=0.1045627 Z=0.9758912
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04409921 Y=0.1060489 Z=0.9729208
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04323583 Y=0.1039724 Z=0.9733979
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04529553 Y=0.09979265 Z=0.9768563
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04781722 Y=0.09395169 Z=0.9850013
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.04812302 Y=0.09049615 Z=0.9941791
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.07316336 Y=0.07617962 Z=1.020456
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.06185302 Y=0.07848825 Z=1.028017
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.02985232 Y=0.08386628 Z=1.027143
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.0127591 Y=0.08899211 Z=1.021705
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.008346823 Y=0.09292626 Z=1.018359
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.008808543 Y=0.09628098 Z=1.016593
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.01056221 Y=0.09994597 Z=1.015095
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.009594908 Y=0.1018666 Z=1.012968
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.01014338 Y=0.104472 Z=1.010674
          Oct-10 08:49:06 Kinect TRACE TrackedX=0.009779642 Y=0.1100972 Z=1.011023
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.005761613 Y=0.1185373 Z=1.012059
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.01003329 Y=0.1254027 Z=1.012168
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.001929357 Y=0.1363782 Z=1.012648
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.0005938435 Y=0.1478752 Z=1.014058
          Oct-10 08:49:05 Kinect TRACE TrackedX=-0.003795018 Y=0.1625799 Z=1.017541
          Oct-10 08:49:05 Kinect TRACE STABLE
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.00724083 Y=0.1727207 Z=1.02232
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.02728519 Y=0.1772068 Z=1.02624
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.03967225 Y=0.1808408 Z=1.029848
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.04016798 Y=0.1802761 Z=1.028884
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.04103727 Y=0.173859 Z=1.026039
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.04370497 Y=0.1752646 Z=1.02766
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.04583329 Y=0.173083 Z=1.026994
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.04700639 Y=0.1720619 Z=1.027659
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.04741647 Y=0.1702054 Z=1.026892
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.05118872 Y=0.1698008 Z=1.027577
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.05391755 Y=0.1694323 Z=1.028371
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.05501626 Y=0.1701015 Z=1.028693
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.05735428 Y=0.1695203 Z=1.028761
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06065544 Y=0.1717299 Z=1.02986
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06288803 Y=0.1728098 Z=1.030643
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06703352 Y=0.1728341 Z=1.031229
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06781448 Y=0.1746873 Z=1.032695
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06903368 Y=0.1738912 Z=1.03111
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.07097172 Y=0.1750515 Z=1.030992
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.07332217 Y=0.1769502 Z=1.032361
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.07179117 Y=0.174767 Z=1.031125
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06785575 Y=0.1728963 Z=1.028566
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06670363 Y=0.1724952 Z=1.027023
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06623396 Y=0.1729225 Z=1.026405
          Oct-10 08:49:05 Kinect TRACE TrackedX=0.06391101 Y=0.1746328 Z=1.025881
          Oct-10 08:49:04 Kinect TRACE STABLE
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.06112266 Y=0.1765289 Z=1.025633
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05969385 Y=0.1809742 Z=1.027321
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05948851 Y=0.1858012 Z=1.029916
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05835656 Y=0.1883637 Z=1.028903
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05790081 Y=0.1885144 Z=1.027856
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05783341 Y=0.1879069 Z=1.027452
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05664672 Y=0.1873617 Z=1.028932
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.0569644 Y=0.183393 Z=1.027454
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05650954 Y=0.1799629 Z=1.024787
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05549989 Y=0.1802204 Z=1.023919
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05363579 Y=0.1811376 Z=1.023449
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.05230754 Y=0.179631 Z=1.02336
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.04820254 Y=0.1788595 Z=1.021872
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.04538334 Y=0.1790782 Z=1.020744
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.0442115 Y=0.1777189 Z=1.020492
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.04315253 Y=0.1779847 Z=1.020425
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.04295805 Y=0.1791304 Z=1.019911
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.04184502 Y=0.1807272 Z=1.019482
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.04100899 Y=0.1791575 Z=1.019668
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.0398329 Y=0.1791317 Z=1.019527
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.03954703 Y=0.1800896 Z=1.019747
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.03867681 Y=0.1795252 Z=1.020296
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.03694812 Y=0.1799009 Z=1.021612
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.03430016 Y=0.1789539 Z=1.021774
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.03131102 Y=0.1783379 Z=1.02319
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.02958847 Y=0.1766092 Z=1.024728
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.02609864 Y=0.1768046 Z=1.02634
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.02216545 Y=0.1783248 Z=1.028577
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.01905367 Y=0.1766682 Z=1.02908
          Oct-10 08:49:04 Kinect TRACE TrackedX=0.01557304 Y=0.1775833 Z=1.030086
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.0139903 Y=0.1771944 Z=1.032612
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.008279576 Y=0.177521 Z=1.032151
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.00626457 Y=0.1775414 Z=1.033784
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.003563365 Y=0.1764306 Z=1.033979
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.0003554185 Y=0.175482 Z=1.033558
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.00313845 Y=0.1726781 Z=1.034281
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.004558296 Y=0.1694375 Z=1.033942
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.006880744 Y=0.1693362 Z=1.034496
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.008202072 Y=0.1673483 Z=1.034398
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.008499934 Y=0.1669587 Z=1.034995
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.009455336 Y=0.1664704 Z=1.034229
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.0119721 Y=0.1661505 Z=1.034568
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.0118177 Y=0.1647767 Z=1.035479
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.01272816 Y=0.1635092 Z=1.036771
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.015523 Y=0.159566 Z=1.036807
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.01993238 Y=0.1545465 Z=1.036795
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.02501949 Y=0.1478828 Z=1.036121
          Oct-10 08:49:03 Kinect TRACE TrackedX=-0.02817033 Y=0.1419555 Z=1.035994
          Oct-10 08:49:03 Kinect TRACE STABLE
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.04987636 Y=0.08929126 Z=1.045062
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.04587973 Y=0.08604282 Z=1.042241
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.04172376 Y=0.08764558 Z=1.040133
          Oct-10 08:49:03 Kinect TRACE TrackedX=0.04038307 Y=0.08643988 Z=1.039737
          Oct-10 08:49:02 Kinect TRACE STABLE
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.03329806 Y=0.08648663 Z=1.03747
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.03554265 Y=0.0860092 Z=1.040094
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.03002243 Y=0.08670276 Z=1.037122
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.02834761 Y=0.08892305 Z=1.037192
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.02277456 Y=0.08844461 Z=1.03636
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.01940167 Y=0.09035277 Z=1.035306
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.01770791 Y=0.08667379 Z=1.035829
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.009887177 Y=0.08718058 Z=1.029855
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.00988898 Y=0.08500577 Z=1.028105
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.007831501 Y=0.08541217 Z=1.026605
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.005220143 Y=0.08379254 Z=1.022349
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.0003886241 Y=0.08590744 Z=1.015404
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.0103434 Y=0.08899374 Z=1.002777
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.01307526 Y=0.09282015 Z=0.9976091
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.01485789 Y=0.09212448 Z=0.992351
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.01578251 Y=0.09388022 Z=0.9885442
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.01480957 Y=0.09483695 Z=0.9857838
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.01236084 Y=0.09772664 Z=0.9840479
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.009695658 Y=0.09809306 Z=0.9815227
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.00558413 Y=0.09778727 Z=0.9812
          Oct-10 08:49:02 Kinect TRACE TrackedX=-0.0006188778 Y=0.09869255 Z=0.9809521
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.007096046 Y=0.09649233 Z=0.9817094
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.01399798 Y=0.09800997 Z=0.9840925
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.01997547 Y=0.09889241 Z=0.9846672
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.02923398 Y=0.09910265 Z=0.9869794
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.03620697 Y=0.09819488 Z=0.988356
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.04537522 Y=0.09830868 Z=0.990795
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.0547976 Y=0.09922654 Z=0.9928443
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.06453521 Y=0.09960364 Z=0.9947117
          Oct-10 08:49:02 Kinect TRACE TrackedX=0.07444623 Y=0.0981051 Z=0.9977423
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.08866878 Y=0.09551744 Z=1.001705
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.1011174 Y=0.09448331 Z=1.005245
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.118929 Y=0.09196578 Z=1.013164
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.1368071 Y=0.08910371 Z=1.019902
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.1559761 Y=0.08793686 Z=1.027637
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.197897 Y=0.05911625 Z=1.04527
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.2457339 Y=0.0315843 Z=1.063356
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.286175 Y=0.009842771 Z=1.078261
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.3085287 Y=0.0172887 Z=1.089965
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.3310846 Y=0.0265397 Z=1.101856
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.3533677 Y=0.03443657 Z=1.113349
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.3814468 Y=0.02768333 Z=1.118307
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4024082 Y=0.01617018 Z=1.125946
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4205217 Y=0.01326539 Z=1.133176
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4353938 Y=0.008148484 Z=1.141296
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4508298 Y=-0.0003451188 Z=1.149494
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4656006 Y=-0.00607763 Z=1.159294
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4782964 Y=-0.01622796 Z=1.167999
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4889765 Y=-0.01847432 Z=1.176789
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.4967487 Y=-0.01721906 Z=1.185852
          Oct-10 08:49:01 Z-Wave Device: Energy House Amperes 2 Set to 9.698 (9.698 Amperes)
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.505797 Y=-0.0248843 Z=1.193123
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5121835 Y=-0.024365 Z=1.19999
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5179579 Y=-0.02690381 Z=1.204418
          Oct-10 08:49:01 Z-Wave Device: Energy House Amperes 1 Set to 4.427 (4.427 Amperes)
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5224262 Y=-0.02955144 Z=1.210115
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5270224 Y=-0.02960468 Z=1.214736
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5323377 Y=-0.0293602 Z=1.218539
          Oct-10 08:49:01 Z-Wave Device: Energy House Volts 2 Set to 124.385 (124.385 Volts)
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5361091 Y=-0.02869973 Z=1.223686
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5395597 Y=-0.02970508 Z=1.22719
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5420712 Y=-0.03095947 Z=1.230716
          Oct-10 08:49:01 Z-Wave Device: Energy House Volts 1 Set to 124.385 (124.385 Volts)
          Oct-10 08:49:01 Kinect TRACE TrackedX=0.5444027 Y=-0.03222385 Z=1.235317
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5464782 Y=-0.03176551 Z=1.239771
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.547938 Y=-0.03396724 Z=1.24481
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5495113 Y=-0.03590672 Z=1.250235
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5515221 Y=-0.03774868 Z=1.255925
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5515602 Y=-0.03925794 Z=1.263266
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5534741 Y=-0.04021711 Z=1.268932
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5540728 Y=-0.03980294 Z=1.274133
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5547197 Y=-0.04084095 Z=1.278345
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.5557426 Y=-0.04450462 Z=1.279042
          Oct-10 08:49:00 Kinect TRACE TrackedX=0.55628 Y=-0.0438948 Z=1.278759
          Oct-10 08:49:00 Kinect TRACE PositionOnlyX=0.5574659 Y=-0.04732823 Z=1.274183
          Oct-10 08:49:00 Kinect TRACE PositionOnlyX=0.558013 Y=-0.04535689 Z=1.271117
          Oct-10 08:48:39 Z-Wave Device: Energy House Watts 2 Set to 1103.885 (1103.885 Watts)
          Oct-10 08:48:18 Web Server Web Server authorized local login successful from: 172.16.0.10 User: admin
          Oct-10 08:48:09 Z-Wave Device: Energy House Watts 2 Set to 1164.21 (1164.21 Watts)
          Oct-10 08:48:01 Z-Wave Device: Energy House Amperes 2 Set to 10.09 (10.09 Amperes)
          Oct-10 08:48:01 Z-Wave Device: Energy House Amperes 1 Set to 4.437 (4.437 Amperes)
          Oct-10 08:48:01 Z-Wave Device: Energy House Volts 2 Set to 124.492 (124.492 Volts)
          Oct-10 08:48:01 Z-Wave Device: Energy House Volts 1 Set to 124.492 (124.492 Volts)
          Oct-10 08:47:42 Speaker Speaker host added, Name: Media-Qu8X Instance: Default IP address: 172.16.0.99
          Oct-10 08:47:35 Speaker Speaker host added, Name: HAS-00 Instance: Default IP address: 127.0.0.1
          Oct-10 08:47:20 TTS Speak: ():Web server port number is 8080
          Oct-10 08:47:17 TTS Speak: ():Welcome to Home-Seer
          Oct-10 08:47:17 Speaker Speaker host added, Name: HAS-00 Instance: Android IP address: 172.16.0.20
          Oct-10 08:47:16 HSTouch Server Connecting speaker client to HomeSeer IP 127.0.0.1
          Oct-10 08:47:16 HSTouch Server Client Android (172.16.0.101/58665) named Android has CONNECTED.
          Oct-10 08:47:16 HSTouch Server Opening connection from:172.16.0.101/58665
          Oct-10 08:47:12 BLStat Info 1 Thermostat has been loaded
          Oct-10 08:47:05 Info System connected to MyHomeSeer Service successfully.
          Oct-10 08:47:05 Info System connected to MyHomeSeer Service, waiting for acknowledge...
          Oct-10 08:47:05 Startup Start up complete.
          Oct-10 08:47:05 Startup Starting the HS3 Sentry EXE
          Oct-10 08:47:05 Startup Starting HSSentry watchdog.
          Oct-10 08:47:05 Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
          Oct-10 08:47:05 Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
          Oct-10 08:47:05 Startup Starting Event Scheduler...
          Oct-10 08:47:04 Startup Running the startup script Startup.vb
            please disable "Gesture, Posture and Person Recognition" from the config page and redo the same test
            please post your logs from the following line: "Plugin Kinect has connected."
            and tell me what command you are trying to say
            thanks
              thanks
              just asking for the weather
              Oct-10 09:17:01 Z-Wave Device: Energy House Amperes 2 Set to 10.641 (10.641 Amperes)
              Oct-10 09:17:01 Z-Wave Device: Energy House Amperes 1 Set to 3.403 (3.403 Amperes)
              Oct-10 09:17:01 Z-Wave Device: Energy House Volts 2 Set to 124.615 (124.615 Volts)
              Oct-10 09:17:01 Z-Wave Device: Energy House Volts 1 Set to 124.615 (124.615 Volts)
              Oct-10 09:16:01 Z-Wave Device: Energy House Amperes 2 Set to 10.295 (10.295 Amperes)
              Oct-10 09:16:01 Z-Wave Device: Energy House Amperes 1 Set to 3.406 (3.406 Amperes)
              Oct-10 09:16:01 Kinect TRACE Phrase rejected =
              Oct-10 09:16:01 Z-Wave Device: Energy House Volts 2 Set to 124.764 (124.764 Volts)
              Oct-10 09:16:01 Kinect TRACE Phrase hypothesized = computer what is the weather, Confidence=0.01766924
              Oct-10 09:16:01 Z-Wave Device: Energy House Volts 1 Set to 124.764 (124.764 Volts)
              Oct-10 09:16:00 Kinect TRACE Phrase hypothesized = computer what is the, Confidence=0.01265836
              Oct-10 09:16:00 Kinect TRACE Phrase hypothesized = computer what is, Confidence=0.01171214
              Oct-10 09:15:59 Kinect TRACE Phrase hypothesized = computer, Confidence=0.0009994507
              Oct-10 09:15:59 Kinect TRACE Speech Detected:
              Oct-10 09:15:53 Z-Wave Device: Kitchen House Motion Sensor Set to On/Open/Motion
              Oct-10 09:15:50 Z-Wave Device: Living Room House Sensor Binary Reserved Set to On/Open/Motion
              Oct-10 09:15:49 Speaker Speaker host added, Name: HAS-00 Instance: Default IP address: 127.0.0.1
              Oct-10 09:15:41 Speaker Speaker host added, Name: HAS-00 Instance: Android IP address: 172.16.0.20
              Oct-10 09:15:41 HSTouch Server Connecting speaker client to HomeSeer IP 127.0.0.1
              Oct-10 09:15:41 HSTouch Server Client Android (172.16.0.101/51342) named Android has CONNECTED.
              Oct-10 09:15:40 HSTouch Server Opening connection from:172.16.0.101/51342
              Oct-10 09:15:24 Web Server Web Server authorized local login successful from: 172.16.0.10 User: admin
              Oct-10 09:15:18 Z-Wave Starting Z-Wave Polling for Network 018503AD...
              Oct-10 09:15:16 Kinect TRACE computer set House Door Lock to Lock
              Oct-10 09:15:16 Kinect TRACE Phrase recognized but confidence=0.3026782 is lower than threshold
              Oct-10 09:15:16 Kinect TRACE Phrase hypothesized = computer set House, Confidence=0.2240146
              Oct-10 09:15:15 Kinect TRACE Phrase hypothesized = computer set System Master, Confidence=0.2050243
              Oct-10 09:15:14 Kinect TRACE Phrase hypothesized = computer set House, Confidence=0.1985096
              Oct-10 09:15:14 Kinect TRACE Phrase hypothesized = computer set System, Confidence=0.2446557
              Oct-10 09:15:13 Kinect TRACE Phrase hypothesized = computer set, Confidence=0.2067722
              Oct-10 09:15:12 Kinect TRACE Phrase hypothesized = computer whats, Confidence=0.02468565
              Oct-10 09:15:12 Kinect TRACE Speech Detected:
              Oct-10 09:15:12 Speaker Speaker host added, Name: CyB3Rs-Qu83-X Instance: Default IP address: 172.16.0.10
              Oct-10 09:15:11 TTS Speak: ():Web server port number is 8080
              Oct-10 09:15:09 TTS Speak: ():Welcome to Home-Seer
              Oct-10 09:15:09 Speaker Speaker host added, Name: HAS-00 Instance: Default IP address: 127.0.0.1
              Oct-10 09:15:09 Speaker Speaker host added, Name: Media-Qu8X Instance: Default IP address: 172.16.0.99
              Oct-10 09:15:06 BLStat Info 1 Thermostat has been loaded
              Oct-10 09:15:01 Z-Wave Device: Energy House Amperes 2 Set to 10.437 (10.437 Amperes)
              Oct-10 09:15:01 Z-Wave Device: Energy House Amperes 1 Set to 3.403 (3.403 Amperes)
              Oct-10 09:15:01 Z-Wave Device: Energy House Volts 2 Set to 124.685 (124.685 Volts)
              Oct-10 09:15:01 Z-Wave Device: Energy House Volts 1 Set to 124.685 (124.685 Volts)
              Oct-10 09:14:57 Informational Ethernet connection established to 172.16.0.9:4998
              Oct-10 09:14:57 Z-Wave Device: Front Area House Temperature Set to 55.8 (F)
              Oct-10 09:14:57 Info System connected to MyHomeSeer Service successfully.
              Oct-10 09:14:57 email Initializing email, found 9 messages
              Oct-10 09:14:57 Info System connected to MyHomeSeer Service, waiting for acknowledge...
              Oct-10 09:14:56 Startup Start up complete.
              Oct-10 09:14:56 Startup Starting the HS3 Sentry EXE
              Oct-10 09:14:56 Startup Starting HSSentry watchdog.
              Oct-10 09:14:56 Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
              Oct-10 09:14:56 Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
              Oct-10 09:14:56 Startup Starting Event Scheduler...
              Oct-10 09:14:56 Insteon External Device Registration complete.
              Oct-10 09:14:56 Startup Running the startup script Startup.vb
              Oct-10 09:14:56 HSTouch Server Server started on port 10200
              Oct-10 09:14:56 Startup Starting DDNS service...
              Oct-10 09:14:56 Startup Updater services starting...
              Oct-10 09:14:55 Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files (x86)\HomeSeer HS3\Data\Energy\Energy.hsd
              Oct-10 09:14:55 Speech Listening for remote speaker connections on port 10401
              Oct-10 09:14:55 Startup Initializing Speaker Client Interface
              Oct-10 09:14:55 Startup Start automation engine...
              Oct-10 09:14:55 Kinect DEBUG Speech Recognition Started
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to Off
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to Low
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to Medium
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Front Fan - to High
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to Off
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to Low
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to Medium
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] Back Fan - to High
              Oct-10 09:14:55 Informational DiscoveryBeacon: Global Cache unit iTachWF2IR [172.16.0.9] discovered.
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Virtual] [System] Master Bedroom Motion Control to On
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Virtual] [System] Master Bedroom Motion Control to Off
              Oct-10 09:14:55 email Start checking server for email using Gmail
              Oct-10 09:14:55 Startup Creating ASP.NET application host...
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] [House] Door Lock to Lock
              Oct-10 09:14:55 Kinect DEBUG Rule (Devices) set [the] [Living Room] [House] Door Lock to Unlock
              Oct-10 09:14:55 Kinect DEBUG Rule: [] [] [the] [ days] [] []
              Oct-10 09:14:55 Kinect DEBUG Ruleget|tell|check|whats|what is) (me|the|this)* (todays|tonights|tomorrows|sundays|mondays|tuesdays|wednesda ys|thursdays|fridays|saturdays|next) (two|three|four|five)* (days)* (temperature|weather|forecast) (for|in)* (Willis Ranch)*
              Oct-10 09:14:55 Startup Initializing email, will check server for new email
              Oct-10 09:14:55 Kinect DEBUG Rule:Turn TV
              Oct-10 09:14:55 Web Server Web Server started on localhost, port 8080
              Oct-10 09:14:55 Web Server UPNP Discovery started
              Oct-10 09:14:55 Web Server Web server remote access is disabled. It can only be accessed from this computer
              Oct-10 09:14:55 Web Server The web server has been bound specifically to IP address 172.16.0.20
              Oct-10 09:14:55 Web Server Local IP address (subnet) is: 172.16.0.20 (255.255.255.0)
              Oct-10 09:14:55 Kinect DEBUG Building Grammars
              Oct-10 09:14:55 Plug-In Finished initializing plug-in Kinect
              Oct-10 09:14:54 Kinect DEBUG End Init
              Oct-10 09:14:54 Kinect INFO Kinect initialized
              Oct-10 09:14:54 Kinect DEBUG Web Pages Registered
              Oct-10 09:14:54 Kinect DEBUG Visual Recognition Initialized
              Oct-10 09:14:54 Kinect DEBUG Writing image file Kinect/zones/zones1.jpg
              Oct-10 09:14:54 Kinect DEBUG Deleting image file Kinect/zones/zones0.jpg
              Oct-10 09:14:54 Kinect DEBUG Drawing Zones File
              Oct-10 09:14:54 Kinect DEBUG Voice Recognition Initialized
              Oct-10 09:14:54 Kinect DEBUG USB\VID_0409&PID_005A\6&38A819A6&0&4 status=Connected
              Oct-10 09:14:54 Kinect INFO Kinect version 3.0.0.35
              Oct-10 09:14:54 Kinect DEBUG Logger Initialized
              Oct-10 09:14:54 Info Plugin Kinect has connected. IP:127.0.0.1:2776
              Oct-10 09:14:54 Plug-In Finished initializing plug-in Insteon
              Oct-10 09:14:54 Insteon Waiting to initialize External Devices...
              Oct-10 09:14:53 Insteon RF PLM contacted on COM3 with an Insteon address of 34.7A.85 and firmware version 9E
              Oct-10 09:14:52 Insteon Insteon Support library (Insteon.dll) version: 1.0.5.20
              Oct-10 09:14:52 Z-Wave ************************************************************ *******************
              Oct-10 09:14:52 Z-Wave STARTUP COMPLETE: All configured interfaces were successfully initialized.
              Oct-10 09:14:52 Info Plugin Insteon has connected. IP:127.0.0.1:2763
              Oct-10 09:14:52 Plug-In Finished initializing plug-in XBMC
              Oct-10 09:14:52 Blue-Iris Refreshing data from Blue Iris server
              Oct-10 09:14:52 Blue-Iris Connected to Blue Iris server Willis Ranch as Admin - polling every 300 seconds
              Oct-10 09:14:52 Blue-Iris Successfully logged in to BlueIris server: Willis Ranch (ver 4.1.9.2) as Admin.
              Oct-10 09:14:51 Info Plugin XBMC has connected. IP:127.0.0.1:2749
              Oct-10 09:14:51 Plug-In Finished initializing plug-in Blue-Iris
              Oct-10 09:14:51 Info Plugin Blue-Iris has connected. IP:127.0.0.1:2746
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: ............................................................ ..........
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: .............................. FINISHED ..............................
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: Z-Wave PC Controller is Type: Static Controller
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: Z-Wave PC Controller Library Version: Z-Wave 2.78 (ZDK 5.02.3 Patch 3)
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: Found 38 Z-Wave nodes in interface node ID 1 (AEOTEC Z-Stick S2)
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: Z-Wave interface node ID: 1, Home ID: 018503AD
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: Z-Wave Serial API version: 5
              Oct-10 09:14:51 Z-Wave AEOTEC Z-Stick S2: Z-Wave services for the SECURITY COMMAND CLASS were successfully started.
              Oct-10 09:14:51 Plug-In Finished initializing plug-in Restart
              Oct-10 09:14:50 Restart Checking for devices owned by Restart
              Oct-10 09:14:50 Restart InitIO called, plug-in is being initialized...
              Oct-10 09:14:50 Info Plugin Restart has connected. IP:127.0.0.1:2744
              Oct-10 09:14:50 Plug-In Finished initializing plug-in BLStat
              Oct-10 09:14:50 Z-Wave AEOTEC Z-Stick S2: Controller firmware version: 3.7
              Oct-10 09:14:50 Z-Wave AEOTEC Z-Stick S2: Controller Manufacturer: Aeon Labs, ID=0x1, Type=0x2
              Oct-10 09:14:50 BLStat start BLStat plug-in has been initialized
              Oct-10 09:14:50 BLStat Info No Schedules have been configured in the plug-in.
              Oct-10 09:14:49 Z-Wave Device: Energy House kW Hours 2 Set to 3575.705 (3575.705 kW Hours)
              Oct-10 09:14:49 Z-Wave Warning Failed to add energy data received for Energy House kW Hours 2 to HomeSeer.
              Oct-10 09:14:49 Z-Wave Adding Energy House kW Hours 2 as an Energy tracking device.
              Oct-10 09:14:49 BLStat start Loaded configuration successfully
              Oct-10 09:14:49 BLStat start BLStat version is: 2.0.63.0
              Oct-10 09:14:49 BLStat start Initializing BLStat...
              Oct-10 09:14:49 Info Plugin BLStat has connected. IP:127.0.0.1:2742
              Oct-10 09:14:49 Plug-In Finished initializing plug-in HSTouch Server
              Oct-10 09:14:49 Info Plugin HSTouch Server has connected. IP:127.0.0.1:2740
              Oct-10 09:14:49 Plug-In Finished initializing plug-in NetCAM
              Oct-10 09:14:48 Info Plugin NetCAM has connected. IP:127.0.0.1:2738
              Oct-10 09:14:48 Plug-In Finished initializing plug-in weatherXML
              Oct-10 09:14:48 Z-Wave AEOTEC Z-Stick S2: Getting node information from controller...
              Oct-10 09:14:48 Z-Wave AEOTEC Z-Stick S2: The Z-Wave API Execution Thread was Started or Restarted.
              Oct-10 09:14:48 Info Plugin weatherXML has connected. IP:127.0.0.1:2736
              Oct-10 09:14:48 Z-Wave Starting 'Z-Wave Health' Process Starter for (Z-Stick S2 Z-Wave Net)...
              Oct-10 09:14:48 Z-Wave AEOTEC Z-Stick S2: The Z-Wave Command Execution Thread was Started or Restarted.
              Oct-10 09:14:48 Z-Wave AEOTEC Z-Stick S2: ----------------------------------------------------------------------
              Oct-10 09:14:48 Z-Wave Initializing Z-Wave interface AEOTEC Z-Stick S2 (Aeon Labs Aeotec Z-Stick) on COM2
              Oct-10 09:14:48 Z-Wave AEOTEC Z-Stick S2: ============================================================ ==========
              Oct-10 09:14:48 Plug-In Finished initializing plug-in Z-Wave
              Oct-10 09:14:48 Z-Wave 0 event triggers were loaded from HomeSeer.
              Oct-10 09:14:48 Z-Wave 0 event actions were loaded from HomeSeer.
              Oct-10 09:14:47 Z-Wave 112 total Z-Wave Data Objects loaded.
              Oct-10 09:14:47 Z-Wave Network 018503AD has 112 device data elements.
              Oct-10 09:14:47 Z-Wave 1 Networks were restored from the data in the database... Building data connections.
              Oct-10 09:14:47 Z-Wave Loading Z-Wave Data Objects...
              Oct-10 09:14:47 Z-Wave 1 total Z-Wave Network Objects loaded.
              Oct-10 09:14:47 Z-Wave Loading Z-Wave Network Objects...
              Oct-10 09:14:47 Z-Wave Database: Opening (Mode=Read Only) up HomeSeer database C:\Program Files (x86)\HomeSeer HS3\Data\Z-Wave\Z-Wave2.db
              Oct-10 09:14:47 Z-Wave InitIO called, plug-in version 3.0.1.25 is being initialized...
              Oct-10 09:14:47 Info Plugin Z-Wave has connected. IP:127.0.0.1:2734
              Oct-10 09:14:47 Plug-In Finished initializing plug-in BLCpuAdvisor
              Oct-10 09:14:47 BLCpuAdvisor start BLCpuAdvisor plugin has been initialized
              Oct-10 09:14:47 BLCpuAdvisor start No applications have been assigned to BLCpuAdvisor!
              Oct-10 09:14:47 BLCpuAdvisor start Loaded configuration successfully
              Oct-10 09:14:47 BLCpuAdvisor start BLCpuAdvisor version is: 2.0.5.0
              Oct-10 09:14:47 BLCpuAdvisor start Initializing BLCpuAdvisor...
              Oct-10 09:14:47 Info Plugin BLCpuAdvisor has connected. IP:127.0.0.1:2731
              Oct-10 09:14:47 Plug-In Finished initializing plug-in BLBackup
              Oct-10 09:14:47 BLBackup start BLBackup plugin has been initialized
              Oct-10 09:14:47 BLBackup start Backup Folders have been loaded.
              Oct-10 09:14:46 BLBackup start Loaded configuration successfully
              Oct-10 09:14:46 BLBackup start BLBackup version is: 2.0.22.0
              Oct-10 09:14:46 BLBackup start Initializing BLBackup...
              Oct-10 09:14:46 Info Plugin BLBackup has connected. IP:127.0.0.1:2729
              Oct-10 09:14:46 Plug-In Finished initializing plug-in UltraGCIR3
              Oct-10 09:14:46 Info Plugin UltraGCIR3 has connected. IP:127.0.0.1:2726
              Oct-10 09:14:46 Startup Initializing Plug-Ins
              Oct-10 09:14:46 Plug-In Found plug-in: Z-Wave, version: 3.0.1.25
              Oct-10 09:14:46 Plug-In Found plug-in: XBMC, version: 3.0.0.33
              Oct-10 09:14:46 Plug-In Found plug-in: weatherXML, version: 3.0.0.38
              Oct-10 09:14:45 Plug-In Found plug-in: UltraGCIR3, version: 3.0.5584.29762
              Oct-10 09:14:45 Plug-In Found plug-in: Restart, version: 1.0.0.2
              Oct-10 09:14:45 Plug-In Found plug-in: NetCAM, version: 3.0.0.11
              Oct-10 09:14:45 Plug-In Found plug-in: MediaController, version: 3.0.0.22
              Oct-10 09:14:45 Plug-In Found plug-in: Kinect, version: 3.0.0.35
                you weather command phrase does not have a correct syntax:
                instead of:
                (get|tell|check|whats|what is) (me|the|this)*  (todays|tonights|tomorrows|sundays|mondays|tuesdays|wednesda   ys|thursdays|fridays|saturdays|next) (two|three|four|five)* (days)*  (temperature|weather|forecast) (for|in)* (Willis Ranch)*
                it should be:
                <get|tell|check|whats|what is>  [<me|the|this>] <todays|tonights|tomorrows|sundays|mondays|tuesdays|wednesdays|thursdays|fridays|saturdays|next> [<two|three|four|five>  days] <temperature|weather|forecast> [<for|in>] [Willis Ranch]
                  instead of:
                  it should be:
                  Okay. made the change. still nothing
                  Oct-10 09:51:36 Kinect TRACE computer whats todays weather
                  Oct-10 09:51:36 Kinect TRACE Phrase recognized but confidence=0.09090059 is lower than threshold
                  Oct-10 09:51:36 Kinect TRACE Phrase hypothesized = computer whats me weather, Confidence=0.02917499
                  Oct-10 09:51:35 Kinect TRACE Phrase hypothesized = computer whats, Confidence=0.01633833
                  Oct-10 09:51:35 Kinect TRACE Phrase hypothesized = computer what is the, Confidence=0.03984751
                  Oct-10 09:51:35 Kinect TRACE Phrase hypothesized = computer whats, Confidence=0.006568533
                  Oct-10 09:51:34 Kinect TRACE Phrase hypothesized = computer, Confidence=0.001025856
                  Oct-10 09:51:34 Kinect TRACE Speech Detected:
                  Oct-10 09:51:34 Z-Wave Device: Kitchen House Motion Sensor Set to On/Open/Motion
                  Oct-10 09:51:01 Z-Wave Device: Energy House Amperes 2 Set to 8.354 (8.354 Amperes)
                  Oct-10 09:51:01 Z-Wave Device: Energy House Amperes 1 Set to 3.398 (3.398 Amperes)
                  Oct-10 09:51:01 Z-Wave Device: Energy House Volts 2 Set to 124.675 (124.675 Volts)
                  Oct-10 09:51:01 Z-Wave Device: Energy House Volts 1 Set to 124.675 (124.675 Volts)
                  Oct-10 09:50:55 Kinect DEBUG Speech Recognition Started
                    could you please always post the entire logs, so that I can see what rules are loaded by the plugin
                    what is the exact phrase you are trying to say?
                    could you try another command like "set door lock to unlock"?
                      I got it working.. for some reason the confidence is waaayy low..
                        I am back to not being able to get this to work.
                        Mind you this is on a VM server. no physical connections are possible.
                          It would be nice to get something I paid money for to work. If that's not possible, let me know so I'm not wasting my time. I will move forward with something that will work
                            As I already told you if you want help please provide more details: what's not working? error messages? logs?
                            At some point you said you got it to work, so what did you change since then?
                            Are you saying you are running the Kinect from a virtual machine? the Kinect for Xbox 360 does not support to be run from a VM, (the Kinect for Windows seems to be supported depending of the kind of VM)
                              The homeseer server is a VM. The kinects are connected to physical computers. I setup the remote client as instructed. It did work really awesome until an update. I have kept everything up to date. also copied new files to remote systems.
                              I am unable to get the remote systems to do trace logging..
