Old March 19th, 2007, 08:45 PM
jdls
Guest
Posts: n/a
Motion detector overwrite
I have a motion detector on the patio that turns on lights when motion detected and turns off after 10 minutes. Problem I am having is let say I go back after 8 minutes. Motion detector picks up the motion yet the lights turn off after only 2 minutes due to the original comand. Is there anyway to have it overwrite the previous command so the lights remain on for the full 10 minutes everytime the motion dector picks up motion?
Old March 19th, 2007, 09:15 PM
Stuart Stuart is offline
you could add a script line after you set the light on such as
&hs.setdevicetime "A10", 0
or whatever you use for the patio lights code, so it resets the time and it gets to go the full 10 minutes.
Stuart
Old March 20th, 2007, 12:51 AM
drozwood90 drozwood90 is offline
<TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tablecellscript noWrap align=right width=160>
            Run script:
</TD><TD class=tablecellscript align=left>&hs.DeleteEvent "Closet (delayed action)"</TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tablecelldevice noWrap align=right width=160>        Device Command: </TD><TD class=tablecelldevice align=left>Library Closet On</TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=tablecelldevice noWrap align=right width=160>        Device Command: </TD><TD class=tablecelldevice align=left>Library Closet Off Delay: 00:00:30</TD></TR></TBODY></TABLE>
when I open the closet, a motion sensor trips this event. The event Closet (delayed action) is created. As I move, the light it re-turned on and a new delayed event is made. Just do that, simple.
Or you can get really complex using mcs Movement or Doo Motion PLugins.
--Dan
Old March 20th, 2007, 01:01 AM
jasv's Avatar
jasv jasv is offline
Super Seer
You don't need a script...
There is an action that can delete a previously created delayed action or event and thus you don't need a script. You can create an event that has the following actions
1. Delete delayed action for the device (if it exists)
2. Turn on light
3. Turn off light in 10 minutes
At 8 minutes when motion is detected again, the event will fire; delete the existing delayed action and create new one to turn off the light 10 minutes later.
See the example below
James
Running HS 3 on Win10 .
Old March 20th, 2007, 01:55 AM
James,
does that work now? I used that in the past, it never did work for me...as it couldn't find items with (delayed event) tagged on...my guess...but it couldn't delete delayed events, so I started using the script method...
--Dan
Old March 20th, 2007, 07:53 AM
jdls
Guest
Posts: n/a
Gentlemen----Thank you for the quick response. I am going to try both however where exactly would I put the script line? I have no experience with scripts.
Old March 20th, 2007, 09:46 AM
jasv's Avatar
Super Seer
Originally Posted by drozwood90 View Post
James,
--Dan
There was problems in the past but it does work now. After the event triggers you can go to the events page and see "Delayed Actions" and you can the delayed events with the expected run time. And you will see that the expected run time will change after it has been deleted and re-added.
Old March 20th, 2007, 09:48 AM
jasv's Avatar
Super Seer
In the event action, you will need to select "Run Script|Advanced View" and since this is a one line script you should put it in the box labeled
"OR Script Statement:
ie: &hs.speak "hello"
