also just tried upgrading to the latest FTDI drivers (November 16 2010) and plugged in a USB hub but still no luck. It fails as soon as the washer motor kicks in.
Washer/Dryer Breaks Insteon Plugin? - Fixed!
what about an old low end upsMark
HS3 Pro 4.2.19.5
woo! I ran an extension cord from my PLM over to an outlet closer to the breaker panel and a littl further away from the washing machine and after doing a load of laundry, my lights still seem to work. Crossing my fingers.
I thought I had tried this already but maybe not. 2 things are different now. 1) I have a filter on my washer/dryer. 2) I turned off my Leviton X10 coupler/repeater. I dont seem to need it anymore with the insteon devices.
i'll give it a week or so and report back here.
thanks for the help, guys.
Well that is good news Dan. Keep us posted.
i have a tv and fios box that i have on a ups and x10 noise filter to eliminate the noise they generate. both ups and noise filter are required; one by itself doesn't fix the problem.
sometimes its a combination of things.Mark
HS3 Pro 4.2.19.5
Do you know if Smarthome knows about this issue? Or is it not really their problem and has more to do with FTDI?
I really dont understand why these USB PLM and PLC devices need to be converted into a virtual serial port to work. Seems like its just adding a layer of complexity that can fail.
Originally posted by DanWheeler View PostDo you know if Smarthome knows about this issue? Or is it not really their problem and has more to do with FTDI?
i did check in with SH on this issue and they have had a few reports; but no solutions. Keep in mind they design their products in a lab (probably without a washing machine running) and then rely on beta testers to find issues using the products in the real world. Its probably hit or miss.
I believe the PLC is a different animal and doesn't use the FTDI chip that the PLMs do. Hense the SDM layer which is slow and has its own problems.
SH would have had to create a custom usb plm driver if they didn't use the FTDI chip which is $$ trade-off. And then there would be two different interfaces/protocols for people like me to deal with.
There is another PLM solution avail; its called an RF INSTEON USB Interface. It acts just like a plm but uses RF instead of the powerline and no x10 support. I beta tested it and support it in the plugin.
check it out
http://www.smarthome.com/2448A7/INST...Adapter/p.aspx
hope this helps
i would probably stick with what you have if you think you can install a permanent solution and ditch the extension cord.Mark
HS3 Pro 4.2.19.5
