Does ApplianceLinc support 'Local Control Reporting'?
    I added a new ApplianceLinc and noticed that it did not have a link that says 'Switch/Load has local control reporting to Homeseer'. My other switches like SwitchLinc have this entry. Sure enough, when I turned on the ApplianceLinc from the module itself, its status in Homeseer was not updated.
    I can control the ApplianceLinc from homeseer though, so this is not a signal issue.
    Is it possible to have the ApplianceLinc report its status to Homeseer when it's turned on or off from the module? Thanks.
    As far as i know ApplLincs do not transmit status status when they are changed locally thus no need for the link. And I don't think this is configurable. You should set a polling interval to maintain status.
    Mark
    HS3 Pro 4.2.19.5
