Hi
Mark has changed a small thing in his plugin which now causes issue with HStouch and HSTouch designer.
Until his recent change, the open/close modules used the values on/off
now it is open/close which makes a lot more sense.
the problem is now the on/off in the hstouch app doenst work, only the slider.
i had to create a virtual device so i can run events like : if virtual device goes "on", change windows shade to "open" and etc.
is this something that will be changes in HS touch?
since now i cannot use "toggle on/off" in the designer.
thanks
thanks
