12th of September, 2015 Update
The plugin is running fine this morning. I see no errors in the Homeseer logs. (debug though would be a nice option).
While getting to YR plugin configuration is a bit slow it is working today just fine.
Note too that I am running the plugin on Homeseer 3 Pro v.199 Homeseer 3 Pro Touch server V.72, Homeseer 3 touch clients V.32 (and designer V.32).
Hardware base is a Haswell iSeries mITX board with 16Gb of memory. OS base is Ubuntu 14.04 64 bit.
It looks like the GIF file stuff is working fine using the device images in Homeseer touch in Wintel. I still have yet to test on an Android tablet.
Did some quickie speed testing and the latency here to there could be an issue when configuring the plugin.
Chicago to Norway (132-151ms)
Chicago to a variety of US locations average (19-31ms)
Norway internet router traceroute shows.
7 xe-5-3-0.0.chic0.tr-cps.internet2.edu (162.252.69.149) 41.684 ms 42.860 ms 42.690 ms
8 et-10-0-0.1001.asbn0.tr-cps.internet2.edu (64.57.20.2) 38.239 ms 38.205 ms 37.245 ms
9 64.57.21.54 (64.57.21.54) 56.096 ms 57.062 ms 57.048 ms
10 uk-hex.nordu.net (109.105.97.140) 119.320 ms us-man.nordu.net (109.105.97.142) 43.455 ms 43.435 ms
11 dk-uni.nordu.net (192.38.7.50) 132.267 ms 133.297 ms 133.231 ms
12 stolav-gw2.uninett.no (109.105.102.26) 142.965 ms dk-ore.nordu.net (109.105.97.136) 127.621 ms stolav-gw2.uninett.no (109.105.102.26) 139.249 ms
13 dk-uni.nordu.net (192.38.7.50) 131.040 ms 127.217 ms ifi2-gw.uninett.no (128.39.254.174) 135.129 ms
14 stolav-gw2.uninett.no (109.105.102.26) 140.899 ms met-gw2.met.no (128.39.46.122) 140.706 ms 139.688 ms
15 ifi2-gw.uninett.no (128.39.254.174) 140.803 ms 157.249.83.66 (157.249.83.66) 140.636 ms ifi2-gw.uninett.no (128.39.254.174) 140.756 ms
16 157.249.84.84 (157.249.84.84) 135.750 ms 135.549 ms met-gw2.met.no (128.39.46.122) 140.115 ms
17 157.249.83.66 (157.249.83.66) 140.992 ms 157.249.84.91 (157.249.84.91) 141.372 ms 141.355 ms
18 157.249.84.84 (157.249.84.84) 141.192 ms 141.172 ms 141.140 ms
19 157.249.84.91 (157.249.84.91) 141.273 ms 141.268 ms *
Ping shows...
--- 157.249.32.15 ping statistics ---
14 packets transmitted, 14 received, 0% packet loss, time 13013ms
rtt min/avg/max/mdev = 134.522/135.460/137.352/0.766 ms
nn.uninett.no >> 158.38.0.181
tell.oslo.dnmi.no >> 157.249.32.15
nac.no >> 128.39.2.22
ifi.uio.no >> 129.240.64.2
guide.oslo.dnmi.no >> 157.249.32.14
Updated HS3 Pro V.198 to HS3 Pro V.199 (using HSTouch Server V.72, HSTouch Windows client V.32 and HS3 Designer V.32)
Ping shows...
