I want to have a group condition with
If Window 1 is open
OR Window 2 is open
OR Window 3 is open
However, I am not able to create this. Each time I want to add a new condition it default to "And If". I then switch this to "Or If". When I do that, I get kicked back to a new "If" and all my previous "Or" conditions are converted to "And" conditions.
Here is what I am doing:
* Create a new group (click on the green + under the menu "plug-ins"
* In the newly created group click on the yellow arrow left to "Group Conditions"
* It now shows "IF" "(Choose a Trigger or Condition)". For the latter I select "A Device's Value is..."
* My next selection is for "(Choose Another)". Here I select "This device has a value equal to..."
* Now I am prompted with "(Select A Device)". I select "Main Door".
* Then I get "is" where I select "Zone opened"
* !!! So now I end up with a line "IF "Main Door" has a value equal to "Zone opened"
Now I want to add another OR(!!) condition. So I click on the green + to the right of the line mentioned above.
Now I get a new line that says "AND IF The Time IS... (Choose Another)"
I don't want the "AND IF" but "OR IF". So I change "AND IF" to "OR IF". When I make that selection I don't get "OR IR" but "IF". That's strange. In any case, now I am changing "The Time Is..." to "A device's Value Is". Now suddenly my 'or if' goes to the top but still showing "The Time Is...". The previous condition now changes to "AND IF".
So even when I continue from here everything ends up as "AND IF" instead of "OR IF". How can I get "OR IF"??
If Window 1 is open
OR Window 2 is open
OR Window 3 is open
