Originally posted by integlikewhoa
View Post
ImperiHome Plug-in - Feature Requests
Originally posted by spud View PostI think I can show the "last change time" associated to a HS device, but not sure this is what you want?
Originally posted by spud View PostYes support for graphs of historical values are on my list (see first post of this thread). However I don't know yet if I will implement myself the recording of historical values in a database or if I will leverage another plugin that can do this already.
I currently use Jon00's graphing plugin. It is a well written plugin, though not sure how it would work if you used another authors plugin db. Were you thinking of writing your own full fledged charting plugin, or do you have one already?_______________________________________________
bump. Any news on how you would implement a db so you can enable the graphing feature?_______________________________________________
Originally posted by jlrichar View PostI currently use Jon00's graphing plugin. It is a well written plugin, though not sure how it would work if you used another authors plugin db. Were you thinking of writing your own full fledged charting plugin, or do you have one already?
Originally posted by spud View PostI don't plan to write my own full fledged charting plugin. I need to investigate how easy it would be to use the data recorded by other plugins such as Jon00's one, if this is too much problem I will implement the recording of data in my own DB._______________________________________________
Originally posted by integlikewhoa View PostYes that would be perfect. Icon above displays the current state right now (open, closed, locked, unlocked, motion, no motion) that last changed time would just show us at a quick glace the last time sensor not in it's current state.
Hi spud,
I made some feature requests in the Beta thread, so transferred them here:
- For the events tab, would it be possible to have an option to deselect them all, or deselect all in an event group?
- New events get enabled by default. I would prefer to have them disabled by default. Would it be possible to add an option to set the default behaviour?
- Empty Event groups show up in ImperiHome. Would be great not to see them there, or an option to allow them not to be seen.
AlHS 4.2.8.0: 2134 Devices 1252 Events
Al
Originally posted by spud View Postin version 3.0.0.6 (available in Beta Testing thread) you can select/deselect event groups. If an event group is unselected, none of the events included in this group will show up in ImperiHome, the group itself won't show up, and any new event added to this group won't show up either.HS 4.2.8.0: 2134 Devices 1252 Events
Installed it and the event group deselect is great, thanks for adding that. However, I still see those event groups in the Imperihome app. Do I need to remove HS3 as a system and re-add it? Or should a refresh get rid of them? I've restarted the plugin after disabling the event groups, and re-launched the ImperiHome app and did a refresh, but they are still present after doing that. Thoughts? Also, there are a couple of Event Groups that get dynamically created as needed (Delayed Actions Delayed Events). Will they stay disabled if they disappear and come back?
