The HS3 plug-in is for a limited time available for a special price.
The HS3 RFXCOM plug-in supports for example:
- Weather sensors: Oregon, Alecto, Ambient Weather/Froggit F007TH, Cresta, Hideki, TFA ...
- Blind motors: Somfy RTS, A-OK, ASA, ASP, Bofu, BTX, Dooya, Rollertrol ...
- Security sensors: Atlantic, Chuango, Kerui, KD101 smoke detectors, Meiantech, Visonic, X10 ...
- vThings: CO2, dust, high precision temperature sensor...
- Built in software alarm panel with Disarm, Home, Away and pin code.
- Receive Power usage: cent-a-meter, RFXMeter, OWL CM113/119/160/180, Revolt ...
- Appliance modules: Blyss, Chacon, Cotech, Flamingo, HomeEasy, Intertechno, KAKU, LightwaveRF, Livolo, Nexa, SilverCrest, X10 ...
- Radiator valve: Smartwares
- Fans: Lucci Air, Siemens SF01, Wave design ...
- Fire place/ stove: Mertik, MCZ ...
- Chimes: 1byOne, Byron SX, SelectPlus ...
- Battery sensor status with expected life time to get a warning message before the battery is fully exhausted.
- Configure hi/low levels on sensors. Receive a warning or alarm message on these levels.
- Warning and Alarm messages can also be send to NMA (Notify My Android)
- Virtual sensors for Daily: Temperature/humidity high-low, power/gas/water usage, rain fall
- Multiple virtual Thermostat devices.
It depends on the receiver, transmitter or transceiver which devices are supported.
The W800RF32 receiver can only receive X10 lighting and security sensors.
All devices supported by the older RFXCOM receivers and transmitters are supported by the plug-in.
For the RFXrec433 and RFXtrx433, all devices listed in chapter 2 of the RFXtrx User Guide are supported by this HS3 plug-in.
http://www.rfxcom.com/WebRoot/StoreN...User_Guide.pdf
The HS3 User Guide.pdf contains a very detailed description of all functions and configuration options.
This pdf is installed in the Homeseer Docs directory when the plug-in is installed.
The procedure how to export RFXCOM HS2 devices to HS3 is described in the Export RFXCOM HS2 to HS3.pdf.
This pdf is also in the Homeseer Docs directory.
