This version is Linux and Windows compatible.
Homeseer 3.0.0.152 is required for this version for the best experience with the plugin during programming.
Please post issues with this Beta here:
New Features
- Added a "Reprogram Device" feature. This will reprogram a device with the existing links after manually resetting the device. Op flags and Settings are reprogrammed as well.
- Added device support for new Range Extender, Morninglinc, and Remotelinc
- Added error blink op flag for KPLs
- A few basic UI improvements
- Added settings and op flags to Reprogram Device feature above (3.0.5.26)
- Added Reset btn to low battery level device for Hidden door sensors (3.0.5.26)
- Change On level and ramp rate settings for any link in a device from the Edit Links page: make the changes using the new drop downs and press Update Selected Links
- Allows you to change the status text of a device without it being overwritten by the plugin (3.0.5.35). See the following thread/post for more details:
http://board.homeseer.com/showpost.p...3&postcount=10
- Allows you to change the status text of devices that have On/Off buttons. This will change the button text too if its a status & control entry (3.0.5.36)
- Allows you to change the optional controller device in a Group (3.0.5.43)
- Added Copy Selected Group function (3.0.5.55)
- Added 022B in-linelinc on/off device; (3.0.5.56)
- Added Heartbeat device and tracking for Motion Sensors fw 44+; please delete and re-register the MS (3.0.5.61)
- Added Backup Configuration event action that will copy the current insteon.ini to an insteonX.ini where X is 1..5 (3.0.5.74)
- Added a Configuration Changed trigger that will fire whenever a change is made to a device via the plugin (3.0.5.75)
- Revised the Window/Door sensor (1009) to use an Open/Close status, and the default HS icons (3.0.5.74)
- Revised the Hidden Door Sensor (1011, 10CF) battery voltage level reading to occur after a heartbeat (3.0.5.80)
- Added Alert Module support (3.0.5.82)
- Added Poll Device Event Action (3.0.5.84)
Fixes
- Fixed issue with smoke bridge (3.0.5.35)
- Fixed link edit issue for responder links associated with KPL buttons (3.0.5.37)
- Fixed RemoteLinc2 8 button devices and option to switch from 8 to 4 btn setup; polling issue with Outletlincs (3.0.5.43)
- Fixed heartbeat for Leak Sensors fw<0x89 (3.0.5.44)
- Fixed Motion Sensor and iMeter polling (3.0.5.47)
- Fixed Hub 2 support when linking new devices; leak sensor fix (3.0.5.51)
- Fixed kpl sync saving, remotelinc2 001C, updated i1 settings msg (3.0.5.54)
- Fixed load sense programming for Outletlinc dimmer (3.0.5.56)
- Fixed i1 device registration error (3.0.5.57)
- Fixed KPL status update (3.0.5.60)
- Fixed i1 KPL registration issue (3.0.5.65)
- Fixed 2-Wire switch programming (3.0.5.66)
- Fixed On Level issue with new devices (3.0.5.67)
- Potential Fix for Inlinelinc (fw 44) registration (3.0.5.68)
- Fixed Test Detected to Normal status issue with Smoke Bridge (3.0.5.75)
- Fixed SyncLinkedDevices disappearing ini settings after deleting another device (3.0.5.76)
- Fixed Hidden Door Sensor battery voltage level (3.0.5.78, 3.0.5.81)
- Fixed a comm issue with the Insteon Hub 2 (3.0.5.79)
- Fixed the Reset & Reprogram routine for the the Hub 2 (3.0.5.80)
- Fixed heartbeat status update issue for open/close sensor with fw 43 (3.0.5.83)
- Fixed status change on low battery message from hidden door sensor fw 44 (3.0.5.86)
- Fixed polling issue with IOLincs (3.0.5.88)
Important: Make a backup of your insteon.ini before you do this in case something goes wrong. You can revert the ini and restart HS and try again
You may need to add RecreateDevices=1 to the [config] section of the insteon.ini to update the hs device definitions. This is a one time fix.
You can now update via the Updater, but i would recommend first shutting down and backing up your current hs database and config\insteon.ini
To install the older versions below:
1. Shutdown HS
2. Backup your current hs database and config\insteon.ini
3. Copy all the DLLs to the homeseer root folder (not the config folder)
4. Copy image files to a new folder: html\images\insteon
5. restart HS
Linux Info:
Use the following for the Port name:
/dev/ttyS0 is COM1
/dev/ttyS1 is COM2
/dev/ttyUSB0 is USB
Do not attempt to set Port=USB in the insteon.ini. This is not supported on linux.
New Features
Fixes
1. Shutdown HS
5. restart HS
Linux Info:
/dev/ttyS0 is COM1
/dev/ttyS1 is COM2
/dev/ttyUSB0 is USB
