Using the Amazon Echo and the amazon-echo-ha-bridge with HomeSeer3
    Here are some quick instructions on how to use your Raspberry Pi and the amazon-echo-ha-bridge with HomeSeer3. This method emulates a Philips hue bridge and I found it to be the quickest and most reliable way to control your lights.
    Note1: The amazon-echo-ha-bridge appears to be limited to about 25 devices per instance. I simply run 2 instances using different ports to support 50 devices (see notes below).
    Note2: You must change the IP address in the examples from 10.0.0.74 to the IP address of your Raspberry Pi 2.
    • Log into your Raspberry Pi, then create a directory to hold the amazon-echo-ha-bridge software.
      cd ~pi
      mkdir echobridge1
      mkdir echobridge2
    • Change directory into echobridge1, then download the jar file from
      https://github.com/armzilla/amazon-e...ridge/releases
      cd ~pi/echobridge1
      wget [url]https://github.com/armzilla/amazon-echo-ha-bridge/releases/download/v0.2.1/amazon-echo-bridge-0.2.1.jar[/url]
    • Copy this jar file to echobridge2 if you have more than 25 devices.
      cd ~pi/echobridge1
      cp amazon-echo-bridge-0.2.1.jar ../echobridge2
    • Figure out what your IP address is by running ifconfig. If you're using wireless, then look under wlan0, otherwise, look under eth0.
      ifconfig
      eth0      Link encap:Ethernet  HWaddr b8:27:eb:00:00:00
                inet addr:10.0.0.74 Bcast:10.0.0.255  Mask:255.255.255.0
                UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
                RX packets:23630 errors:0 dropped:16 overruns:0 frame:0
                TX packets:6302 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:1000
                RX bytes:1912887 (1.8 MiB)  TX bytes:1337342 (1.2 MiB)
      lo        Link encap:Local Loopback
                inet addr:127.0.0.1  Mask:255.0.0.0
                UP LOOPBACK RUNNING  MTU:65536  Metric:1
                RX packets:1494 errors:0 dropped:0 overruns:0 frame:0
                TX packets:1494 errors:0 dropped:0 overruns:0 carrier:0
                collisions:0 txqueuelen:0
                RX bytes:165212 (161.3 KiB)  TX bytes:165212 (161.3 KiB)
      wlan0     Link encap:Ethernet  HWaddr 74:da:38:00:00:00
                UP BROADCAST MULTICAST  MTU:1500  Metric:1
                RX packets:0 errors:0 dropped:0 overruns:0 frame:0
                TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
                RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
    • For your first instance (supports about 25 devices), launch the program as follows.
      cd ~pi/echobridge1
       java -jar -Djava.net.preferIPv4Stack=true amazon-echo-bridge-0.2.1.jar --logging.level.com.armzilla.ha.upnp=INFO --logging.file=ha.log --upnp.config.address=10.0.0.74 --server.port=8080 --upnp.response.port=50000 >log.txt &
    • If you have more than about 25 devices, then launch a second instance of the program as follows. Please note: You must change the IP address from the example of 10.0.0.74 shown below.
       java -jar -Djava.net.preferIPv4Stack=true amazon-echo-bridge-0.2.1.jar --logging.level.com.armzilla.ha.upnp=INFO --logging.file=ha.log --upnp.config.address=10.0.0.74 --server.port=8081 --upnp.response.port=50001 >log.txt &
    The amazon-echo-ha-bridge take several minutes to start. Once you're have gathered the data for the next steps you should be ready to proceed.
    • Create an import.sh script for the echobridge1 directory and put the contents of the following file into the script. You *must* change the BRIDGE_IP and HS3_IP. Please also note that my HomeSeer lights use a 0 for off and a 100 for on. Your lights may be different.
      import.sh script for the ~pi/echobridge directory.
      #!/bin/bash
      BRIDGE_IP="10.0.0.74"
      HS3_IP="10.0.0.12"
      OFF_VALUE="0"
      ON_VALUE="100"
      IFS=","
      while read DEVICE_NAME REF_ID
      do
        echo "Adding ${DEVICE_NAME} with HS3 device ref ${REF_ID}"
        curl -H "Content-Type: application/json" \
             -X POST http://${BRIDGE_IP}:8080/api/devices \
             -d "{ \"name\" : \"${DEVICE_NAME}\", \"deviceType\" : \"switch\", \"onUrl\" : \"http://${HS3_IP}/JSON?request=controldevicebyvalue&ref=${REF_ID}&value=${ON_VALUE}\", \"offUrl\" : \"http://${HS3_IP}/JSON?request=controldevicebyvalue&ref=${REF_ID}&value=${OFF_VALUE}\" }"
        echo ""
      done < lights.csv
      import.sh script for the ~pi/echobridge2 directory. Please note the only difference is that it uses port 8081 instead of 8080.
      #!/bin/bash
      HS3_IP="10.0.0.12"
      OFF_VALUE="0"
      ON_VALUE="100"
      IFS=","
      do
             -X POST http://${BRIDGE_IP}:8081/api/devices \
        echo ""
      done < lights.csv
    • Now populate the lights.csv for each amazon-echo-ha-bridge you plan to run. In the example below, the file contains the light name, then the HomeSeer Reference Id.
      Basement Stairs Light,213
      Basement Table Lamp,167
      Basement Lights N1,189
      Basement Lights N2,190
      Basement Lights S1,191
      Basement Lights S2,192
      Basement Dehumidifier,172
      Dining Room Chandelier Lights,197
      Dining Room China Cabinet Lights,179
      Dining Room Table Lamps,178
      Family Room Overhead Light,173
      Garage Lights,224
      Kitchen Cabinet Lights,175
      Kitchen Desk Lights,184
      Kitchen Island Lights,195
      Kitchen Sink Light,182
      Kitchen Table Lights,186
      Deck Lights,236
      Back Door Lights,223
      Front Door Lights,220
      Landscape Lights,216
      Flood Lights,222
    • To import the lights, you simply do the following:
      cd ~pi/echobridge1
      ./import.sh
      cd ~pi/echobridge2
      ./import.sh
    If you are only running 1 instance, then you can simple ask your Alexa to "discover devices". However, if you're running multiple instances, you *must* do the following:
    • Stop all instances of the amazon-echo-ha-bridge as follows:
      pkill -f java
      - Start the first instance:
      cd ~pi/echobridge1
    • Wait until you get a response from http://10.0.0.74:8080/api/devices before proceeding.
    • Ask your Alexa to "discover devices"
    • Log into http://alexa.amazon.com/spa/index.ht...connected-home to make sure your devices were discovered.
      pkill -f java
      - Start the second instance:
      cd ~pi/echobridge2
    • Wait until you get a response from http://10.0.0.74:8081/api/devices before proceeding.
    • Restart the first instance:
      cd ~pi/echobridge1
    • Wait about 5 minutes before you ask your Amazon Alexa to control your lights.
    Ultrajones
    perfect timing, thank you
