Programming an event for double/triple tap
    I am trying to use double/triple tap features using Home Troller Zee S2 program. I installed about 20 different devices with primary objective for security. To program random timing on and off I used events, there could be a better way to do it but I did not master it yet.
    I would like to use the double/triple tap features but am struggling with how. I know I need to program an event, is it a manual trigger? Is there an instruction of how to do it, I found a nice video of using double tap but no instruction how to program Zee S2? An example would be helpful. I am posting it under Home Troller Zee S2 because this is the unit I have, I am not sure I know which software the unit is using.
    Thank you for help.
    George.
    Are you using the new HS HS-WD100+ switches? If not what switch are you using that reports local multi-taps?
      Yes, all switches are from 2016 from HomeSeer, most are HS WA100+, one is WD100+ and a few of WS100.
      George.
        Your event trigger will be:
        If a device had its value set and
        Central scene [of device] is [one of the below]
        Then [do something]
        You will be provided with some options:
        Scene 001 Key pressed
        Scene 001 Key released
        Scene 001 Key held
        Scene 001 Key pressed twice
        Scene 001 Key pressed 3 times
        Scene 002 Key pressed
        Scene 002 Key released
        Scene 002 Key held
        Scene 002 Key pressed twice
        Scene 002 Key pressed 3 times
        Scene 001 means the top paddle, i.e. On
        Scene 002 means the bottom paddle, i.e. Off
        Michael
        Michael
          George.
          George. The WA version is a companion switch and can only be used in a 3 (or more) way combination with either a WD (dimmer) or WS (switch).
          To program your event you need to monitor the change in the Central Scene device value for the master (WD or WS) switch.
          Choose: Device Changes and is set to
          Then Choose the Central Scene device for your switch
          Then choose the sub option (Scene 1s are top paddle presses; scene 2s are bottom paddle presses)
          Here's an event that I use to turn off all lights in the basement. I can use a double press on the bottom paddle for either the stair light at the top, or the playroom at the bottom to launch another event that turns off all lights - with a delay for the stair light
          cheeryfool
            I read your instructions again an successfully programmed the double tap events. Thank you all. Home Seer has a very high quality product but instructions need to be better tuned for new folks. Programming is still a little like machine language.
            Thank you all again,
            George.
