Hi, I need your help!
I need some infos about setup and configuration of the Zwave EUropean usb dongle (868,4 MHz / 869,8 MHz; All European Countries (CEPT); UAE) on my controllez HTZ (US zwave).
Does the HTZ provides the linux driver for this device? is it the same as the onboard internal z-wave interface?
According to the references, "The device implements a virtual serial interface used by the Z-Wave application. Linux has a built in device driver for the stick and will create a new device named /dev/ttyACM0 (Linux)"
Does anyone know if it procedure works out of the box on the HTZ? Do I need to edit some files or configure the HS web control? Do I need to deactivate the onboard zwave interface
Any hint or advice is appreciated!!
Thanks in advance
Tommy
Current Date/Time: 4/3/2017 4:56:50 PM
HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.313
Linux version: Linux HomeTrollerZeeS2V2 4.1.19-v7+ #858 SMP Tue Mar 15 15:56:00 GMT 2016 armv7l GNU/Linux System Uptime: 2 Days 23 Hours 33 Minutes 43 Seconds
IP Address: 192.168.0.122
Number of Devices: 21
Number of Events: 1
Available Threads: 393
Enabled Plug-Ins
3.0.0.68: HSTouch Server
3.0.1.13: izKNX
3.0.1.83: Z-Wave
Thanks in advance
Tommy
Number of Events: 1
Enabled Plug-Ins
3.0.1.13: izKNX
3.0.1.83: Z-Wave
