I have a pair of older Simply Automated UCT-08 devices (Tabletop Controller 8-Button) and when I was using HS2 these showed up as devices that I could control. At the time, I wasn't using your UPB plugin, but HS's--so that's the next thing that different.
Anyway, is there any chance that I can tweak something with your plug-in or upe file to get these to show up as devices? The downside to these is that they are only an output-only controller normally, except that they have status lights that can be controlled. Unfortunately its easy to get the status lights out of sync with the controller, so I was using HS to keep them in sync (happens, for example, when All Lights Off is activated).
I don't mind if I need to manually tweak something, like in the upe file, nor do I mind if they show up with the wrong device type, etc.
Below is what one looks like in the upe file.
If there's anything I can do to get these to show up in HS3, that would be great.
3,30,120,4,15,4,15,1,1,8,8,Master Bedroom,Jim's Control,1
12,0,1b,0e,10,11,12,ff,ff,1e,1b,66,55,32,44,0e,65,87
12,16,32,44,10,65,87,32,44,11,65,87,32,44,12,55,77,55
12,32,ff,ff,65,87,32,44,ff,65,65,65,ff,1e,55,55,ff,ff
12,48,92,81,81,81,81,00,00,81,ff,ff,ff,ff,ff,ff,ff,ff
12,64,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,ff,2f,84,ff
12,80,22,00,ff,22,64,ff,23,00,05,23,64,05,24,ff,ff,21
12,96,ff,ff,20,ff,ff,22,00,00,22,64,00,22,00,01,22,64
12,112,01,22,00,08,22,64,08,25,1e,ff,00,00,00,ff,ff,ff
12,128,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
12,144,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
12,160,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
12,176,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
19,30,0,1,Jim's Control,Keypad6
8,0,30,0,0
6,0,0,30,27,6,5,3,4,6,5,2,4,27,146
6,0,1,30,14,6,8,3,4,5,7,2,4,14,129
6,0,2,30,16,6,8,3,4,5,7,2,4,16,129
6,0,3,30,17,6,8,3,4,5,7,2,4,17,129
6,0,4,30,18,5,7,5,15,5,7,5,15,18,129
6,0,5,30,255,6,8,3,4,5,7,2,4,255,0
6,0,6,30,255,6,6,6,15,5,5,5,15,255,0
6,0,7,30,30,5,5,15,15,5,5,15,15,30,129
17,0,0,30,E
17,0,1,30,F
17,0,2,30,G
17,0,3,30,H
17,0,4,30,I
17,0,5,30,J
17,0,6,30,K
17,0,7,30,L
8,0,30,0,0
17,0,0,30,E
17,0,1,30,F
17,0,2,30,G
17,0,3,30,H
17,0,4,30,I
17,0,5,30,J
17,0,6,30,K
17,0,7,30,L
