When I run Z-Seer+, whether from the local PC or another on my network, the only node identified on the node map is Node 1, the Z-wave controller, which is a Z-Net.
The node map does not show any of my numerous other Z-wave devices.
Any idea why this might be?
When I run Z-Seer+ from a network PC, the log section occasionally reports 'Cannot access HomeSeer: Object reference not set to an instance of an object.' (Despite the fact that it has successfully located the Z-wave controller).
When I run Z-Seer+ from the PC that is running HomeSeer, neither the Log section nor the Actions section of the Z-Seer window are visible below the Search section, and the lower part of the window is not resizeable to allow those sections to be seen!!
System info:
Current Date/Time: 20/05/2018 20:21:18
HomeSeer Version: HS3 Pro Edition 3.0.0.435
Operating System: Microsoft Windows 10 Pro - Work Station
System Uptime: 1 Day 21 Hours 39 Minutes 45 Seconds
IP Address: 192.168.1.14
Number of Devices: 654
Number of Events: 312
Available Threads: 200
HSTouch Enabled: True
Event Threads: 1
Event Trigger Eval Queue: 0
Event Trigger Priority Eval Queue: 0
Device Exec Queue: 0
HSTouch Event Queue: 0
Email Send Queue: 0
Anti Virus Installed: BullGuard Antivirus Windows Defender
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.61.0: BLDSC
2.0.54.0: BLOnkyo
2.0.6.0: BLPlugins
2.0.139.0: BLRadar
1.0.3.0: BLShutdown
2.0.5.0: BLTouchString
2.0.22.0: BLUPS
1.2.3.0: Device History
3.0.0.14: NetCAM
3.0.0.21: Sonos
3.0.6551.16959: UltraGCIR3
3.0.1.212: Z-Wave
System info:
Event Threads: 1
Email Send Queue: 0
Enabled Plug-Ins
2.0.54.0: BLBackup
2.0.61.0: BLDSC
2.0.54.0: BLOnkyo
2.0.6.0: BLPlugins
2.0.139.0: BLRadar
1.0.3.0: BLShutdown
2.0.22.0: BLUPS
3.0.0.14: NetCAM
3.0.0.21: Sonos
3.0.1.212: Z-Wave
