Hi All -
I'm having some issues with my homeseer switches. Everything was working fine until I erased my Z-wave network and rebuild it on a more powerful pc (running HS3Pro). I stopped getting instant status updates after doing this.
I've been doing some testing and here is where it gets interesting - I get instant status updates when the Scene 1 Key Pressed or Scene 2 Key Pressed Central Scenes fire. But I do not get them on any other scene (Scene 1 Key Released, Scene 2 Key Released).
So in order to get the status to update I have to set the on/off/dim level from the light switch, and then click the top or bottom of the switch a second time to fire the Scene 1/2 Key Pressed (bc Scene 1/2 Key Released is what is most often fired when dimming).
Any ideas whats going on here? I've looked in my logs and its clear HS3 is only polling for status updates when the Scene is set to 1000 or 2000. Any ideas on how do I fix this? I've purchased over 20 of these lights and instant status not working is really impacting the lighting in my home.
Tornadoslims
Dec-29 10:47:25 PM Z-Wave Device: Lighting Master Bedroom Master Bath Recessed Central Scene Set to 1001
Dec-29 10:47:25 PM Z-Wave ApplicationCommandHandler from node 20 HANDLING: COMMAND_CLASS_CENTRAL_SCENE Frame(7)=3
Dec-29 10:47:24 PM Z-Wave ApplicationCommandHandler from node 20 HANDLING: COMMAND_CLASS_CENTRAL_SCENE Frame(7)=3
Dec-29 10:47:24 PM Z-Wave Device: Lighting Master Bedroom Master Bath Recessed Central Scene Set to 1002
Dec-29 10:47:21 PM Z-Wave ApplicationCommandHandler from node 28 HANDLING: COMMAND_CLASS_METER_V2 Frame(7)=2
Dec-29 10:47:20 PM Z-Wave Device: Lighting Master Bedroom Watts Set to 6.993 (6.993 Watts)
Dec-29 10:47:20 PM Z-Wave ApplicationCommandHandler from node 39 HANDLING: COMMAND_CLASS_METER_V2 Frame(7)=2
Dec-29 10:47:13 PM Z-Wave ApplicationCommandHandler from node 5 HANDLING: COMMAND_CLASS_METER_V2 Frame(7)=2
Dec-29 10:47:10 PM Z-Wave ApplicationCommandHandler from node 20 HANDLING: COMMAND_CLASS_SWITCH_MULTILEVEL_V2 Frame(7)=3
Dec-29 10:47:10 PM Z-Wave Device: Lighting Master Bedroom Master Bath Recessed Switch Set to Dim 25%
Dec-29 10:47:10 PM Z-Wave Z-NetUpstairs: Sending to node 20 (UnSecured) CC=COMMAND_CLASS_SWITCH_MULTILEVEL_V2
Dec-29 10:47:10 PM Z-Wave Polling device: Master Bath Recessed Root
Dec-29 10:47:10 PM Z-Wave Device: Lighting Master Bedroom Master Bath Recessed Central Scene Set to 1000
Dec-29 10:47:10 PM Z-Wave ApplicationCommandHandler from node 20 HANDLING: COMMAND_CLASS_CENTRAL_SCENE Frame(7)=3
Tornadoslims
