Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help
HomeSeer Help Help, How-to's and Documentation
Old February 12th, 2017, 05:34 PM
akirkby akirkby is offline
Viewer
Aeon Multisensor - Gen 5 & Multisensor 6
I am just getting started with HomeSeer - what I have seen so far leads me to believe its a really power and flexible system.
I've purchased a number of Z-Wave nodes to get started -
5 x Greenwave 1 Port Powernode
2 x Aeon Multisensor Gen 5
1 x Aeon Multisensor 6
I've got the Greenwave Powernodes connected and running without issue, i've set 60 second polling to see the power usage - great :-)
However, I'm having problems getting the Multisensors to report in a timely manner, namely providing movement alerts in real time and temperature/light/humidity every ten minutes...
I've gone through the process of setting the parameters as mentioned on several sites -
Parameter Value Size Function
3 240 2 PIR Detection timeout
4 1 1 Enable Motion Sensor
101 128+64+32+1 (225) 4 Items to report - Lux, Humid, Temp, Batt
111 600 4 Reporting interval - Seconds
However, I also see in the HomeSeer log file that it appears to be setting these values to some other preset e.g. reporting interval, 60 minutes...?
I am assuming that because HomeSeer is sending other values then this is resetting the node to something else and therefore it's not reporting as expected?
I wondered if anyone could share their experience of using these devices with HomeSeer?
Many thanks,
Andrew
HTML code is On
Aeon Multisensor 6 - no motion mdavison HS3 / HS3PRO Discussion 22 January 2nd, 2017 07:25 PM
aeon multisensor help bennydavidovich HS3 / HS3PRO Discussion 3 February 12th, 2015 12:04 PM
Aeon Labs Multisensor antoon HomeSeer Hardware 5 October 3rd, 2014 09:04 AM
aeon multisensor phillb Lighting & Primary Technology Discussion 11 February 16th, 2014 11:54 AM
Aeon MultiSensor and Lux values surovich HS3/PRO Beta Releases 9 July 15th, 2013 09:03 AM
Untitled Document
NEW!
New Products
