Go Back   HomeSeer Message Board > Developer Support > Programming & Plug-in Development
Programming & Plug-in Development All programming and plug-in development forums
  #21
Old February 9th, 2017, 01:12 PM
mrhappy mrhappy is offline
OverSeer
Quote:
Originally Posted by kriz83 View Post
OK. That is clear.
Am i correct in saying that the controller will just hit the 'toggle' button on the garage door ?
Yes that's my belief, there appears to be some sort of what might be an SSR (I don't know if the schematic is open) which I imagine is just pressing the button.
  #22
Old February 9th, 2017, 01:27 PM
garadget garadget is offline
Seer
Yes, stock Garadget uses a reed relay to simulate the opener's button click.
The info about hardware implementation can be found here.
  #23
Old February 11th, 2017, 03:29 PM
jlrichar's Avatar
jlrichar jlrichar is offline
Seer Master
Installed today
I received my garadget yesterday, and installed it today. Pretty easy setup, and works as advertised. The iOS app works well, and the plugin looks nice. A nice feature is the integration with Imperihome--it is integrated as a lock and pairs with the garage door icon. Since it is a lock to imperihome you can set it to require a PIN or touchID to open/close.
Now to setup a netcam in the garage to add to the imperihome garage page.
_______________________________________________
HS3 : HSpro (3.0.0.208) on Win2012 (vm on ESXi)
Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
WishList: Official Apple HomeKit Plugin, A modern iOS client w/ Location, Notifications, Watch
  #24
Old February 11th, 2017, 03:33 PM
Seer
Thumbs up
Awesome! Happy to hear it worked out nicely for you, @jlrichar!
If you have a moment, please share the pics of your setup including the opener model.
  #25
Old February 17th, 2017, 12:14 AM
philipi philipi is offline
Seer
Can't have a + sign in your password
I've found that having a + sign in my password prevented the plugin from connecting to the server.
+ in password was not a problem for the iOS, Android and Web App.
Thanks for making this plugin happen!
Log follows:
Feb-17 5:01:10 PM Garadget 3P Settings Table Reset Called
Feb-17 4:59:43 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (401) Unauthorized.
Feb-17 4:59:05 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (401) Unauthorized.
Feb-17 4:59:05 PM Garadget 3P *** Get List Of Devices ***
Feb-17 4:59:05 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (400) Bad Request.
Feb-17 4:59:03 PM Garadget 3P OAuth Token Not Found - Requesting
Feb-17 4:59:03 PM Garadget 3P *** Get OAuth Token ***
Feb-17 4:59:03 PM Garadget 3P Settings Table Reset Called
Feb-17 4:59:03 PM Garadget 3P Start The Connection Thread
Feb-17 4:57:30 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (401) Unauthorized.
Feb-17 4:57:29 PM Garadget 3P *** Get List Of Devices ***
Feb-17 4:57:29 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (400) Bad Request.
Feb-17 4:57:28 PM Garadget 3P OAuth Token Not Found - Requesting
Feb-17 4:57:28 PM Garadget 3P Settings Table Reset Called
Feb-17 4:57:28 PM Garadget 3P *** Get OAuth Token ***
Feb-17 4:57:28 PM Garadget 3P Start The Connection Thread
Feb-17 4:57:16 PM Garadget 3P Settings Table Reset Called
Feb-17 4:51:28 PM Garadget 3P Settings Table Reset Called
Feb-17 4:50:49 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (401) Unauthorized.
Feb-17 4:50:49 PM Garadget 3P *** Get List Of Devices ***
Feb-17 4:50:49 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (400) Bad Request.
Feb-17 4:50:49 PM Garadget 3P OAuth Token Not Found - Requesting
Feb-17 4:50:49 PM Garadget 3P *** Get OAuth Token ***
Feb-17 4:50:49 PM Garadget 3P Settings Table Reset Called
Feb-17 4:50:49 PM Garadget 3P Start The Connection Thread
Feb-17 4:50:13 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (401) Unauthorized.
Feb-17 4:50:13 PM Garadget 3P *** Get List Of Devices ***
Feb-17 4:50:13 PM Garadget 3P Garadget 3P Web Exception: The remote server returned an error: (400) Bad Request.
Feb-17 4:50:11 PM Garadget 3P OAuth Token Not Found - Requesting
Feb-17 4:50:11 PM Garadget 3P *** Get OAuth Token ***
Feb-17 4:50:11 PM Garadget 3P Settings Table Reset Called
Feb-17 4:50:11 PM Garadget 3P Start The Connection Thread
  #26
Old February 18th, 2017, 07:05 AM
OverSeer
Quote:
Originally Posted by philipi View Post
Log follows:
Thanks for spotting this one - could I ask if you could try this version please see if it helps?
https://drive.google.com/file/d/0B5D...ew?usp=sharing
  #27
Old February 20th, 2017, 06:26 PM
OverSeer
I've put version .3 in the updater that should fix this issue, it was with the URL encoding.
Tags
controller, developer, garage door, open source, plugin
HTML code is On
Chamberlain MyQ Garage door controller PLUGIN VikingCoder HS3 / HS3PRO Discussion 108 October 24th, 2016 05:41 PM
Using a module in your car to open the garage door? U5tabil HomeSeer Z-Wave Plug-in 6 June 4th, 2015 11:35 AM
What is the best way to detect that a garage door is open? Ericryherd HomeSeer Z-Wave Plug-in 75 January 11th, 2015 06:48 PM
Open/Close Garage Door nugentgl HomeSeer General Discussion Area 36 September 21st, 2010 05:48 PM
How to Open my Garage Door Automatically robc65 HomeSeer General Discussion Area 13 November 8th, 2006 02:38 PM
Untitled Document
NEW!
New Products
