Mounting bracket for an iPad
    Saw a reference to this today. I have no experience with it, but it looks like it might be useful.
    Looks simple enough but the iPad needs powered mounting brackets so they charge the batteries as well.
      Agreed. I think these are intended as short-term holders rather than semi-permanent installation. But, a powered bracket would require wiring to it, so if local power is needed, it may be just as easy to install a recessed outlet that will be hidden by the iPad.
        I have been searching for a powered wall mounted solution for the iPad for a while now and the best/cheapest solution I can find is following...
        http://www.dockalot.com/
        I like it because you can remove the ipad by simply sliding it out of the mount. Granted the price is not great but it's a ton better than the iport solution here.
        http://www.iportmusic.com/products/cm/CM-IW2000
          I am using the wall mount below:
          Great price!
          http://www.loxone.com/Pages/en/purch....aspx?id=APPLE
            Great price!
            That site's not showing up for me, any chance it's down?
            Joe (zimmer62)
            BLSecurtiy, AC-RF2, RCS Serial Thermostats, RFXCOM SMarthome SwitchLinc, mcsXap, Global Cache GC100, SqueezeBox, TWA_ONKYOINTEGRA, BLLogMonitor, BLPlugins, BLRadar, BLSpeech, BLZLog.aspx, HSTouch (Windows, iPhone, iPod), USB Mimo touchscreens, VMWare Server, Vortexbox, Windows Home Server, MyMovies, Windows Media Center, X10, ZWave, and much much much more.
              Working here but slow.
                Still no go here, I'll try it later from home.
                Joe (zimmer62)
                  It's a "foreign" web site so it may be getting blocked at your work place.
