my problem is how to add the keypad linc to my HS system with your plug in, there is no address. and the tap system seems confusing. i have a tabletop unit that i used in another home with x 10- now i have insteon in my new home and i want to use it to have the scenes trigger separate HS events...
Keypadlinc - Example usage with the Insteon Plugin
Originally posted by gfs View Postnow how do i erase the old x10 codes i have in these buttons from a new address for the keylinc. ....
Originally posted by gfs View Postmy problem is how to add the keypad linc to my HS system with your plug in, there is no address. and the tap system seems confusing. i have a tabletop unit that i used in another home with x 10- now i have insteon in my new home and i want to use it to have the scenes trigger separate HS events...
To link the two do the following: put the plm into linking mode by pressing the set btn once. then put the kpl into linking mode by pressing the up paddle for 10 seconds until it beeps.Mark
HS3 Pro 4.2.19.5
thanks mark. i found the ad dress and added it. then i did the factory reset by pulling out the set tab, waited 10 secs, then pushed in and held... it never beeped but eventually the ON button lit up so i assumed it was reset?HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
also mark, what do i need to boost the range/reception in my house... i have an access point unit... do i use that? i have the PLM in basement at my panel... sorry, new to insteon... use zwave but need insteon for some items. its fast!HS3 , Zwave, HometrollerS6, ELK M1G Ultra; mcs sprinklers; WGL800; BLRF; BLNetCallerID; BLSpeech
Originally posted by gfs View Postthanks mark. i found the ad dress and added it. then i did the factory reset by pulling out the set tab, waited 10 secs, then pushed in and held... it never beeped but eventually the ON button lit up so i assumed it was reset?
Originally posted by gfs View Postalso mark, what do i need to boost the range/reception in my house... i have an access point unit... do i use that? i have the PLM in basement at my panel... sorry, new to insteon... use zwave but need insteon for some items. its fast!
You can run the Test Comm feature in the plugin to figure out if the placement of the AP is helping.Mark
HS3 Pro 4.2.19.5
Originally posted by gfs View Posthere is my screen it doesnt show the homeseer in fo for toggl;ing buttons.
also please post the devicetype= entry from the insteon.ini for this device. the ini is in the homeseer\config folderMark
HS3 Pro 4.2.19.5
Protocol i1 is very old. You will have to manually configure toggle btns. See the manual
If you just bought this kpl as new, I would return itMark
HS3 Pro 4.2.19.5
Volume Control?
Two questions...
1) I noticed that there isn't an option for "Toggle Off" (only Toggle On). I am still playing around with my configs so I'm not sure what I need/want but just thought I'd mention it since I do see that setting in the HouseLinc software
2) Any thoughts on how to set a button up to control volume? For example, I have a HS device set up to control the volume on my audio matrix. I am hoping to use this keypad so that each time I press a button, it increases the volume. For example, if I press button D 4 times, it increases the volume by 4 steps. My biggest hurdle is when I press the button 4 times in a row, Homeseer seems to only register one of those button presses. When I do the same in HouseLinc, I can see a 4 button presses in the log. I know this is possible because Insteon has this set up with Sonos (using their own hub).
