This plugin is designed to allow HomeSeer to control DirecTV set top box models H21, HR20 and newer.
It is based on the DirecTV SHEF API Rev. 1.3.C.
It's an HTTP API, Your DirecTV box needs to be connected to your network either via an Ethernet Port or a Coax connection.
Please report any bug.
Please read the User Guide before installing.
Installation:
Changes to v3.0.0.19
- Added "Episode Title" and "Duration" devices
- Channel device value is now set, not just the string
Changes to v3.0.0.18
- Added devices for Music Artist, Music Album and Music Song
Changes to v3.0.0.16
- Added refresh button on config page to refresh the list of Genie clients
Changes to v3.0.0.15
- Fixed issue when selecting power key from a "Press Remote Key" event action
Changes to v3.0.0.14
- Added possibility to resize remote control web page so that it can be integrated in HSTouch
Changes to v3.0.0.13
- Fixed polling of Genie clients
Changes to v3.0.0.12:
- Support for Genie clients
- Cosmetic changes
Changes to v3.0.0.10:
- Possibility to suppress hs header and footer on remote page.
Changes to v3.0.0.9:
- Support for Linux
Changes to v3.0.0.8:
- Support for multiple instance actions
Changes to v3.0.0.7:
- Support for multiple instances (actions not working yet)
Installation:
- download the zip attached to this post and save it in the HS3 application folder /Updates3/Zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the DirecTV line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
- Cosmetic changes
- Support for Linux
