Originally posted by spud
View Post
IFTTT Plug-in - Beta Testing
Originally posted by Rotech View PostSpud, can you explain, why is Dropbox necessary for this work, I am missing part of the picture.
Originally posted by spud View PostJason, did you see my email about this problem?
Question about trigger file name: Does the name matter at all?
Also, can you think of anyway of using this plugin to determine if HS3 is up, and if it stops to perform an IFTTT action?
Last question: Is the 15 minute processing time on IFTTT just related to google calendar, or are all IFTTT recipes run at minimum of 15min intervals?
BTW--nice plugin!_______________________________________________
Originally posted by jlrichar View PostQuestion about trigger file name: Does the name matter at all?
Originally posted by jlrichar View PostAlso, can you think of anyway of using this plugin to determine if HS3 is up, and if it stops to perform an IFTTT action?
Originally posted by jlrichar View PostLast question: Is the 15 minute processing time on IFTTT just related to google calendar, or are all IFTTT recipes run at minimum of 15min intervals?
Originally posted by jlrichar View PostBTW--nice plugin!
not working
plugin isnt working for me, I am getting the following error:
PHP Code:Feb-20 5:44:37 PM IFTTT ERROR Exception of type 'DropNet.Exceptions.DropboxException' was thrown.
PHP Code:This session has expired. Please return to the app to try again.
what am i doing wrong?HS Install Date: Feb. 16, 2007
HS3 Pro, Z-Wave, Insteon, BLStat, HS Touch Server, MyQ
WeatherXML, BLBackup, BLLAN, BLLock, Restart, CaddX, OpenSprinkler
try to restart everything from scratch
- stop the plugin
- delete IFTTT.ini from your config folder
- in your dropbox account, click on your nickname in the top right corner, then click settings, go to the security tab, and in the Apps Linked section at the bottom check if you see HSPI_IFTTT, if you have it delete it
- stay logged to your dropbox account
- restart the plugin
- go to the config page and click on "Dropbox Authorize" button
- give your authorization on the dropbox page
- go back to the config page and click the "Done" button
Linux support for IFTTT plugin?
Hi Spud
Thought I would give this interesting sounding plugin a go. I am running HS3 Pro on Ubunutu 13.10. I think I have followed all the steps correctly, but when I try and bring up the config page it just shows "Error" on an otherwise blank page. As this failed several times even though I had disabled and then re-enabled the plugin, I tried deleting the ini file per the post below, but that then caused the additional errors in the log below and didn't recreate the file.
PHP Code:Feb-24 13:02:02 IFTTT ERROR Argument cannot be null.{0xA}Parameter name: userLogin
Feb-24 13:01:50 IFTTT ERROR Exception of type 'DropNet.Exceptions.DropboxException' was thrown.
Feb-24 13:01:48 Plug-In Finished initializing plug-in IFTTT
Feb-24 13:01:48 Warning Cannot find requested INI file: /home/homeseer/Downloads/HomeSeer/Config/IFTTT.ini
Feb-24 13:01:47 Info Plug-in IFTTT has connected successfully
Feb-24 13:01:47 Info Remote application or plugin has connected: 127.0.0.1:43670
Feb-24 13:01:47 Info Remote application or plugin has connected: 127.0.0.1:43669
Not sure if this is a Linux problem or something else.
Let me know if there's anything I can try
Many thanks
Jamescheeryfool
Many thanks
James
Thank you for reporting.
The Linux issue is fixed in version 3.0.0.1 available here: http://board.homeseer.com/showthread...48#post1106948
Note: you need to wait a few seconds after you enable the plugin, before you can go to the config page.
Originally posted by spud View PostThe Linux issue is fixed in version 3.0.0.1 available here: http://board.homeseer.com/showthread...48#post1106948
Note: you need to wait a few seconds after you enable the plugin, before you can go to the config page.cheeryfool
Originally posted by cheeryfool View PostThat fixed the dropbox auth issue. Will play with this later. Thanks
A couple of comments:
1. The /public folder is no longer created automatically when you open a DropBox account. I think they added the ability to add the equivalent parameters to any folder now, but they still allow for this to be created if you really want it.
2. I struggled for some time to actually get the plugin to read the files that were successfully being created on DB from the location recipe in IFTTT. I am not entirely sure which of the changes I made fixed it, but I definitely missed the mandatory .txt file extension initially. Oops. Even after that I wasn't able to get it working and I tried dumbing down the path to ensure that there were no spaces and that the case matched on every letter in the HS Event and the actual DB location. Not sure if this last piece was required or not
3. Eventually, I disabled the plugin and re-enabled it and suddenly it picked up multiple files from the correct location and I was then able to trigger off them. Subsequently I modified the location again and the plugin is definitely not picking this up dynamically. Obviously this is not a major issue (as long as you know about it) and it may well be an HS feature, vs a plugin problem.
Thanks again
Jamescheeryfool
License Expiring
Spud, what's up next for this plug-in? The trial is expiring in a couple days, are you going to continue testing and move that date out, or is it getting posted as a free or paid plug-in?HS Install Date: Feb. 16, 2007
Originally posted by misraels View PostSpud, what's up next for this plug-in? The trial is expiring in a couple days, are you going to continue testing and move that date out, or is it getting posted as a free or paid plug-in?HS Install Date: Feb. 16, 2007
