Hi, I just built a new windows machine and I'm installed HSPRO and moved all my config files. I also installed the Windows 7 32 bit drivers for the Way2Phone USB/Desktop (I installed the most recent non-beta multi-driver package which says compatible with Win7 32bit).
Anyway, everything in my new Homeseer works except the connection to the Way2Call. I get the following errors. Has anybody seen this before? Is there a simple fix?
Also, I updated the firmware on the way to call, and the updater said "Run on XP only" which I assumed meant that the firmware installer needed to be run on XP, but I'm now wondering if the firmware itself should only be used with XP machines? That wouldn't make sense that the newest version only works with XP, so I figured it's just a note about the installer.
ALSO: I confirmed my firmware and drivers versions with way2call support today and they are current.
Tim
2/22/2010 12:10:34 AM ~!~HSPhone~!~HomeSeer Phone Web Interface initializing.
2/22/2010 12:10:34 AM ~!~HSPhone~!~Adding phone line 1, Name: Default, Modem: Way2Call Hi-Phone Desktop
2/22/2010 12:10:35 AM ~!~Phone Line 1~!~Initializing Hi-Phone device...
2/22/2010 12:10:35 AM ~!~HSPhone~!~Resetting line: Default
2/22/2010 12:10:35 AM ~!~Error~!~Initializing audio play/record support: Unable to cast COM object of type 'hsrecord2.hsrecordplayClass' to interface type 'hsrecord2._hsrecordplay'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{C9B8687D-F497-4520-98A0-ED20C8634473}' failed due to the following error: Error loading type library/DLL. (Exception from HRESULT: 0x80029C4A (TYPE_E_CANTLOADLIBRARY)).
2/22/2010 12:10:35 AM ~!~HSPhone~!~Error initializing Hi-Phone driver, possible corrupt or missing drivers, or Hi-Phone is not plugged in or powered on.
Tim
