OK here is the deal.
I need some help in determining the values for the following information:
Manufacturer ID
Manufacturer Product ID
Manufacturer Product Type
These exist in HomeSeer but they are only numbers and Rich cannot give me the table of what the manufacturers are because it is bound by the Z-Wave SDK license. I fully understand this but I need the information so this is why I need your help.
I am attaching a VB.Net script that will get this information for all thermostats assigned in HomeSeer. What I need from you is for anyone running BLStat I need you to do the following:
1. Unzip the script into your HS scripts folder
2. Go to the Control web page (/ctrl) and in the "Immediate Script Command" box type the following and click "Execute Command"
This will generate a report called Display_ZWave_Thermostat_Device_Info.log in your HS root folder. It should list a section for all Z-Wave thermostats that you have.
I then need you to reply back to this thread with the following information for each Z-Wave thermostat that you have:
Thermostat Make and Model (eg: Trane TZEMT400AB32MAA)
Z-Wave Manufacturer ID - this will be in the log
Z-Wave Product ID - this will be in the log
Z-Wave Product Type - this will be in the log
This will help me figure out what model of thermostat you are running with the plug-in.
You only need to do this if your thermostat information is not already listed by another user
I appreciate your help
Let me know if you have any issues.
Manufacturer ID
&hs.RunEx "Display_ZWave_Thermostat_Device_Info.vb", "Main", ""
