I satrted setting up weatherbug for HS3 today and I entered the API info but I get alot of errors in the Hs log not sure what went wrong.
Here are the errors can some one help
May-20 4:27:44 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
GetAlertsWeather
GetAlertsWeather
May-20 4:27:43 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
GetForecastWeather
May-20 4:27:43 PM 1 Error System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---{0x3E} System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
GetLiveWeather
GetLiveWeather
GetForecastWeather
May-20 4:27:43 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetAlertsWeather(String strStationNumber)
GetAlertsWeather
GetAlertsWeather
May-20 4:27:42 PM 1 Error System.NullReferenceException: Object reference not set to an instance of an object. at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetForecastWeather(String strStationNumber)
GetForecastWeather
GetForecastWeather
May-20 4:27:42 PM 1 Error System.InvalidCastException: Conversion from string "" to type 'Double' is not valid. ---{0x3E} System.FormatException: Input string was not in a correct format. at Microsoft.VisualBasic.CompilerServices.Conversions.ParseDoub le(String Value, NumberFormatInfo NumberFormat) at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) --- End of inner exception stack trace --- at Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble( String Value, NumberFormatInfo NumberFormat) at HSPI_ULTRAWEATHERBUG3.hspi_plugin.GetLiveWeather(String strStationNumber)
Cheers Ken
GetAlertsWeather
GetAlertsWeather
GetForecastWeather
GetLiveWeather
GetLiveWeather
GetForecastWeather
GetAlertsWeather
GetAlertsWeather
GetForecastWeather
GetForecastWeather
Cheers Ken
