Go Back   HomeSeer Message Board > Media Plug-ins > Media Discussion > DirecTV for HS3 (3P)
DirecTV for HS3 (3P) Descriptions related to the DirecTV plug-in for HS3.
Old March 20th, 2017, 07:07 PM
olag00 olag00 is offline
Seer Deluxe
How to Get Plugin to see config files
I was updating a different plugin and it froze Homeseer. I restarted and all my plugins were disabled. When I enable DirecTV, it doesn't remember all the different instances so I would have to redo all configurations.
I can still see the different instances in config folder, the plugin just doesn't "see" them.
Any Idea how I can get the instances to show back up without creating them again. I have 7 boxes so it is quite a chore to add them and I have to rename each box as before or I have to update all the HSTouch screens.
Old March 20th, 2017, 07:23 PM
spud's Avatar
spud spud is offline
Moderator
what do you mean by "it doesn't remember all the different instances" ?
if the ini files for the DirecTV instances are still in the Config folder, and if you start one instance with a name that already existed, it should read the config from the existing ini file.
Old March 20th, 2017, 07:30 PM
Seer Deluxe
When I restarted Homeseer, the directv plugin was disabled. I enabled and all that showed up was below:
The config files are still in folder:
I am going to try to label it the same and see if it works.
Old March 20th, 2017, 07:38 PM
Seer Deluxe
Thumbs up
Ok, adding the instances back worked. I wish I would have known that last time but I didn't ask so can't fault you. I have 7 boxes so it was a lot of updating since I named the instances different as to not overwrite them.
HTML code is Off
Config files gd1210 HS3 / HS3PRO Discussion 1 June 11th, 2016 08:19 AM
Phone Specific Default Config Files TeleFragger Designer 0 October 29th, 2013 01:41 PM
Here is a vb .net script that will backup config files for you Blade HS2 / HSPRO 0 August 17th, 2005 03:22 PM
Config Files johnf Homevision 2 June 14th, 2002 05:11 AM
Config Files johnf Homevision 0 January 1st, 1970 12:00 AM
