I have a screen on HSTouch with a virtual keyboard. When I press the number 0 on that keyboard it triggers an event in HS which in return sends a virtual keypress. However, it seems the DSC alarm system doesn't get it. For instance, when the alarm system is armed and I open a door I type in the security code on the virtual keyboard. The alarm system does not get disarmed, though.
Interestingly, I can see that they HS actually sees that I did press the virtual key as under "Events" I see the "Last Run" date and time correctly listed. I can also arm the system by going to the partition and click on arm. So the connection seems fine but I can't disarm the system with my virtual key pressed. Why could that be?
